What depth water safe to drive through?
Discussion in 'Prime Main Forum (2017-2022)' started by midpitts, Dec 15, 2024.
  1. midpitts
    midpitts New Member
    24
    Pensacola
    2018 Prius Prime
    Sorry if this has been answered before. I haven't figured out how to do a search inside the Prius Prime section of PriusChat.
    I have a 2018 Prius Prime Advanced. I live in Florida and we can get a lot of rain that will flood our streets. Can anyone tell me what depth is safe for the car to drive through before electronics, engine, motor etc are put at risk? Thanks for your guidance.
  2. PriusCamper
    PriusCamper Senior Member
    12,944
    5,261
    Pacific Northwest, USA
  3. BiomedO1
    3,937
    2,069
    SacTown, Ca
    General rule is, If you can't see the pavement through the water - Your not supposed to drive trough it. I don't even know how your going to figure out the depth of water in a 4ish inch ground clearance car - but if you want a number - it's 4 inches. Your engine intake snorkel is much higher, but you'll probably end up with water invading the car as it gets above the door sills.
  4. Isaac Zachary
    Isaac Zachary Senior Member
    2,622
    1,339
    Deep water could mean it's flooding out part of the road leaving a big sink hole. And if it's sea water, then any amount of that water is too deep as it will spray your car with corrosive salt water.
    midpitts and BiomedO1 like this.
  5. BiomedO1
    3,937
    2,069
    SacTown, Ca
    Salt water is also highly conductive, dirty water too
    You need to trade your Prime in for a BYD U8o_O:eek::whistle:
    #5 BiomedO1, Dec 16, 2024
    midpitts likes this.
  6. midpitts
    midpitts New Member
    24
    Pensacola
    2018 Prius Prime
    Wow! I love my Prius Prime and I'm not going to go into water you were close to that depth, I hope. Do you know if that is a plug in hybrid?
  7. midpitts
    midpitts New Member
    24
    Pensacola
    2018 Prius Prime
    Good rule and one I plan to abide by, but there are times when it is difficult to see how deep it is, at night or during heavy rains, for instance. I guess it isn't too much of an issue in normal rain driving, just worried about the heavy rains that are coming more often these days.
    I figured it might get the the carpets wet but wonder how much higher the vital electrical/ mechanical components might be if I am in a situation where I don't have a choice but to go through.
  8. Trollbait
    12,633
    The old Ranger once had a flotation option.
  9. Mendel Leisk
    41,747
    How fast you're going also a factor. Anything over an inch, I'd slow to a crawl.
  10. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    Move, as it will only get deeper:eek:
    Doug McC likes this.
  11. Prodigyplace
    12,617
    11,804
    Central Virginia
    Isaac Zachary and midpitts like this.
  12. kiwiscoot
    kiwiscoot Member
    60
    30
    Christchurch New Zealand
    2019 Prius Prime
  13. PriusCamper
    12,944
    5,261
    Saw one guy who went through high water in reverse and if you go fast enough the wake on rear of the direction you travel will keep water level lower than it is.
  14. Mendel Leisk
    41,747
    His exhaust might be steamy after that. :whistle:
  15. BiomedO1
    3,937
    2,069
    SacTown, Ca
    I believe there's a control board under the rear passenger seat. It's no more than an inch, if that, above the door sill. There's also a question of all the floor panel plugs being in place and how easily they can get dislodged.
    Just my 2-cents...
  16. midpitts
    midpitts New Member
    24
    Pensacola
    2018 Prius Prime
    Now that would be really cool, if they had a hybrid electric version.
    Now that is the kind of information I was looking for. I did take a measure tape and measured from my garage slab to just below the door sill and it looks like 11". Just a case of what other electrical type components are below the level of the door sill. I may double check the answer with my regular mechanic next oil chg.... or is this a Toyota service center type of question. Thanks so much.
    BiomedO1 likes this.
  17. PriusCamper
    12,944
    5,261
    Other strategy is to wait and see how other vehicles handle it and then if water looks low enough, closely follow the biggest vehicle that's displacing the most water.
    Isaac Zachary likes this.
  18. Doug McC
    Doug McC Senior Member
    1,080
    419
    Midwest
    2022 Prius
    I’m not sure I’d put to much faith in what the Toyota Service Department says (JMHO). But you might want to consider searching through your Owners Manual. I just did a word search on my version in Files on my phone and found a significant amount of information that was actually useful. Enough for me to suggest avoiding driving through flood waters unless you had absolutely no other option. Just my two cents.
  19. midpitts
    midpitts New Member
    24
    Pensacola
    2018 Prius Prime
    Now that another good idea! Thanks!
  20. midpitts
    midpitts New Member
    24
    Pensacola
    2018 Prius Prime
    I did try looking in my paperback owners manual, but didn't find anything under flood or water. What word did you use to search?
