Flashing gears and fuel gauge. Car Not Going Into Ready. Code B1260
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SaLKar, Dec 10, 2024.
  1. SaLKar
    SaLKar Junior Member
    Dallas
    Hello guys long time lurker, first time poster.
    I purchased a 2008 Prius that has the gear numbers and fuel gauge blinking. The vehicle has 240k miles with a recently replaced hybrid and 12 volt batteries.
    When you press the power up button, all the lights on the dash come on. At that point a normal car would go into ready mode, but in this case after 8 to 10 seconds, the gears and fuel gauge start flashing.
    Upon hooking up TechStream (although it does not read/display the VIN) and doing a health check. Under gateway, I have code B1260 (Transmission Control ECU Communication Stop).
    I have extensively gone through most of the information on these forums.
    Here is what I have done so far:
    -Made sure the 12 volt battery is good and fully charged with over 12.5 volts (It is).
    -Checked AM1 fuse (is good)
    -Replaced the TCM with a known good TCM. Before replacing the TCM, I unhooked the 12 volt battery and made sure the car had powered down, and the previous codes had cleared up. Replacing the TCM made no difference and the problem persisted.
    All in all, I am kinda stuck and not sure where to look from here.
    Couple of important notes.
    -IMP: Since replacing the TCM did not help, I powered down the car and unplugged the TCM wiring harness to see what that would do. When I powered the car up without the TCM wiring harness plugged in, to my surprise, that made no difference.
    - It makes no difference if the TCM wiring harness is plugged in the TCM or not. The symptoms remain the same. That was quite strange. Maybe some experienced members can shed some light on that.
    - For reasons unknown to me, the previous owner replaced the power on/off button of the car.
    - Also, In the car was sitting a spare (ordered from eBay) key fob slot/slide in assembly and just to check if it was good or not, I swapped that spare from eBay with the one already in the car and that did not change anything. I am not sure if they one currently in the car is the original key fob hole, or the one outside. Either one seems to work.
    - I was told by the previous owner that they had a key made for the car. So I'm thinking that since the key was made and apparently the car drove after that, and is powering up the car now (Although not in ready mode) the key is good?
    Could this be a key fob problem? Could this be a rodent issue?
    I am not sure what to do next.
    I would appreciate any input from the members in the forum.
  2. Tombukt2
    13,226
    2,392
    The condition is the same even if you slot the remote but the remote in the hole and that slot / amplifier is plugged up to the car with a plug It's connected correctly If you have your remote in your hand and you push a button do you see a red light light up on the remote It's up in the right hand corner I believe when the red button is down at the bottom if your remote silver on the back or black if it's silver is the key button pressed in under the steering wheel or is it out?
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,071
    1,988
    NJ-USA
    You need to have a copy of the vehicle wiring diagrams, and be comfortable reading them. Then go test for powers, grounds, and data network lines at the TCM connector.
  4. mr_guy_mann
    4,071
    1,988
    NJ-USA
    Thinking about it, you might want to check an electrical connection in the underhood fuse box, underneath the black plastic cover (top left).
    In particular there's a blue wire that often corrodes and causes various TCM problems. The usual fix is to splice the affected wires together, and bypass the connector.
  5. SaLKar
    Dallas
    Thank you @mr_guy_mann I will check that and report back.
    So what are your thoughts about the TCM the transmission control module unplugged and the car behaving like nothing changed? The symptoms remained the same whether the TCM is plugged in or not.
    The TCM plugged or unplugged not making a difference leads me to think that there may be a break in the connection between the TCM and whatever else is on the other side where the TCM connects to.
    Could something else, another module be involved here?
    Where can I get the schematics that you are alluding to?
    Can anyone help here who has access to this information?
    #5 SaLKar, Dec 11, 2024
  6. Tombukt2
    13,226
    2,392
    Some sites and some places have the whole repair manual in PDF form posted online I don't know who right now it changes like somebody's doing something criminal I don't understand it really I don't see who's going to come and get somebody in trouble for a PDF copy of a 20-year-old car manual but I guess it's a thing. You can even buy PDF copies of the complete three manual set or whatever it is I think after 2009 it's only in PDF you can't get a physical book so depending upon your year that's what you have to do some people here on this list I think have it maybe somebody will send you a link or something here in a minute
  7. mr_guy_mann
    4,071
    1,988
    NJ-USA
    One source is to get a short term (2 day) subscription to Toyota Information Service. Then download everything that you can access. It's the official most up to date info there is.
    An alternative is to search "cardiagn prius service manual". It's a pdf download of the 2006 manual - missing some bits for other year Gen2s but covers most things.
    As far as the TCM, if it is missing a power, ground , or comm lines, then it can't function at all. Effectively it IS "unplugged".
  8. yi3o8
    yi3o8 Junior Member
    usa
    I just got a car that’s doing the same thing. Swapped all the computers with no luck. Was hoping it was just a fuse. I have a donor car so I could swap the ecu/engine harness. What do you guys think ? One thing I didn’t check was fuse linkage inside of the fuse box.
  9. SaLKar
    Dallas
    OP here. One thing I was told by the previous owner is that (for whatever reason) they had the ignition switch (the power on/off button) replaced.
    I'm not sure if that's relevant but thought I'd throw this out there.
    Anyway, one thing's for certain, whatever's making the car non-responsive and not allowing it to go in ready mode is part of the very early process of a car going into ready mode. Whatever that routine is, is not being completed because it didn't matter when I plugged off the transmission control module or the hybrid battery, the behavior and/or the error remains the same.
    I'm in the same boat as you, but could be a wiring or connection 'loop' not being completed issue.
    Would love if someone can help with this.
  10. yi3o8
    yi3o8 Junior Member
    usa
    it’s an odd issue. I figure worst case replace the transmission. But the way I see it is that it’s either the part/computer/ or wiring. The fuse linkage might be responsible for not getting power to one of the systems. But that’s a shot out into left field. The wiring is always a possibility but would take troubleshooting. I’ve got the work up on the 1260 code that gives some electrical tests over my head. And a 3rd gen YouTube video
    For a 2012 can bus nightmare where he goes into a lot of troubleshooting techniques that might apply here.
  11. yi3o8
    yi3o8 Junior Member
    usa
    Fixed it by replacing fuse box and engine wiring harness that connect to all of the computers. Transmission ecu was not getting power and had high resistance pointing to wiring issue per the Toyota troubleshooting pdf.
  12. yi3o8
    yi3o8 Junior Member
    usa
    Any luck on your side ? Ours is up and running.
