Engine noise louder after egr & cooler clea
Discussion in 'Gen 3 Prius Main Forum' started by Rual, Dec 22, 2024.
  1. Rual
    Rual Junior Member
    47
    Uk
    ----UK----
    Hello
    Toyota Auris 2018 1.8 hybrid ( same as gen 3 Prius everything same setup .
    100k miles , no oil loss issues or any other issues
    after cleaning everything including egr , cooler throttle & maf & map sensors
    The car runs perfect no engine codes ,
    but the engine sounds louder now then before ,
    Like when choke is on
    what could it be please
    thanks
  2. ASRDogman
    ASRDogman Senior Member
    7,758
    3,967
    Perhaps you are listening louder?
    Or it's not as muffled....
    Rual likes this.
  3. Rual
    Rual Junior Member
    47
    Uk
    ----UK----
    It was quiter before work was done
    1 mistake I forgot to put the side coolant clamp on drove like that 2 weeks then realised & have bled it again , not lost any coolant very luck that .
    While driving the cabin sound has become louder
    When engine kicks in , like humming sound
    I cleaned the throttle body & maf sensor & map sensor
    Not sure if any of these culprit
    #3 Rual, Dec 22, 2024
  4. ChapmanF
    18,458
    My first guess would be a bit of exhaust leak, at one (or more) of the connections, exhaust manifold to cooler, cooler to valve, valve to pipe, to intake manifold.
    Johnny Cakes, Rual and Brian1954 like this.
  5. Rual
    Rual Junior Member
    47
    Uk
    ----UK----
    I will double check all those gaskets ,
    Is too tight an issue ?
    1 thing has me confusing the directions of the 2 gaskets on egr valve I always forget
    Any one kno which way they go
  6. Rual
    Rual Junior Member
    47
    Uk
    ----UK----
    I would just like to add
    I really appreciate all you guys advice & help
    thanks
  7. Rual
    Rual Junior Member
    47
    Uk
    ----UK----
    Ok I believe after checking diagram
    I have put the egr gaskets wrong way on at least one of them ,
    I will report back once I check them out
    Thanks guys
  8. Mendel Leisk
    41,826
  9. Mendel Leisk
    41,826
    Maybe even Toyota’s confused; I see this gasket in Repair Manual showing clips pointed in intake manifold direction, but I’m fairly certain when I first removed on mine the clips were towards EGR valve.
    Those clips are visible, without disassembly. Perhaps someone else can check and comment.
  10. Rual
    Rual Junior Member
    47
    Uk
    ----UK----
    Hi guys just
    Checked & found the egr to cooler gasket wrong way , turned it towards manifold ,
    Engine already feels smoother electric to gas ,
    I thinks the noise is gone also ,
    Will report after 24 hrs
    thanks
  11. Mendel Leisk
    41,826
    Still begs the question: which are the "wrong" and "right" orientations. The repair manual doesn't clarify.
    One thing occurs to me, if you have an interface where one flange has a machined face, and the other flange is stamped, with a fillet at the edge of the hole, it seems practical to place the gasket so the protruding side is towards the stampled flange.
    example attached:
    #11 Mendel Leisk, Dec 23, 2024
    james wang 20 and Rual like this.
  12. Rual
    Rual Junior Member
    47
    Uk
    ----UK----
    I. Placed all the gaskets towards the manifold direction flamed side ,
    As for the cooler to exhaust that seems flamed both sides
  13. ASRDogman
    7,758
    3,967
    "IF" that resolved your issue, it wasn't that the gasket was the incorrect way.
    It was likely you didn't tighten the bolts/nut tight enough...
    Main thing is you think there is less noise....
    Rual and Mendel Leisk like this.
  14. Mendel Leisk
    41,826
    Yeah I think I've done the gaskets two different ways, at least some of them, and it didn't seem to matter. I did see one video, maybe a south Asian guy, specifically checking. And I made the pdf sketch (in post #8) right after watching that, freezing the video to confirm. But I'm not 100% sure. Having the gasket protrusions all pointing downstream seems logical, fwiw, so they're acting (slightly) like funnels.
    Rual likes this.
