Has anyone used a EV Peak CQ3 Charger with a Gen 3 Prius C battery and know the settings?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by 9Shenandoah, Dec 19, 2024.
  1. 9Shenandoah
    9Shenandoah New Member
    22
    Washington State
    2014 Prius c
    In this video by Gregg Festo , the settings for a Prius battery are as follows. Does anyone know the settings for a GEN 3 Prius C battery?
    Wait Time before Charge and Discharge CHG>DSCHG 5 Minutes
    Temperature Cut off ON 80C(176F)
    Safety Timer ON 720 min
    Capacity Cut Off (High No. Capacity) ON 7500mAh
    NiMH Battery Cycle D->C (discharge then charge) C=3.0A D= 1.0A 3 times
  2. vvillovv
    vvillovv Senior Member
    4,321
    1,509
    NY
    @TMR-JWAP has the most posts on the CQ3 settings and quality of results, but I haen't seen any recent posts by him.
    I'll try to search out an older post or posts (if I can find them ) that might give you a few hints to start off.
    Main idea is to look for above 6500kw for capacity when finished cycling.
    Also look for the amount of kw recovery between cycle 1 and 3
    You can also cycle more than 3 times, if you think it's possible to get closer to 6500 kw capacity with another cycle of two. ;)
    Forum is saying the video not available today, no worries, I'll check back tomorrow to see if it been approved the forum moderators.
    #2 vvillovv, Dec 21, 2024
  3. 9Shenandoah
    22
    Washington State
    2014 Prius c
  4. vvillovv
    4,321
    1,509
    NY
    Here is one youtubers CQ3 settings with some more steps he uses. I'm not recommending starting off at a 3 amp charge though until you get an idea of what the modules capacity are.
  5. 9Shenandoah
    22
    Washington State
    2014 Prius c
  6. Magnetic
    Magnetic New Member
    Atlanta
    ampere-hour or amp-hour (Ah) not Kilowatts (kW).
    6500 milliamp-hour (mAh) or 6.5 Ah in this case.
    Doubt you’re getting to 6500, that’s what I understand the modules to be rated at new. I’ve read 4000 is sufficient.
  7. 9Shenandoah
    22
    Washington State
    2014 Prius c
    This is what I am getting, should i keep going?
