Hone cylinders and replacing rings
Discussion in 'Gen 3 Prius Technical Discussion' started by djimbuser, Jan 1, 2025.
  1. djimbuser
    djimbuser Member
    101
    36
    Henderson, Nevada
    I picked up a cheap 2010 with known head gasket issues. Head came off today and piston #1 doesn't reach the top of its cylinder so I definitely have to replace that piston/rod but why not remove all the pistons and hone the cylinders and replace all the rings while I'm at it...
    Question for the pro's is: Can I install higher tension piston rings so it doesn't have blow-by issues five years later? Are said rings even available?
    The common title on ebay for new rings is "Piston Rings SET 13011-37110 Fits 2010-2015 Toyota Prius Auris Lexus CT200h"
  2. ChapmanF
    18,149
    Do the cylinder walls still show crosshatch?
    For what it's worth, the Toyota manuals don't recommend honing at all. The cylinder sleeves are very thin. Toyota would replace the block if the original crosshatch doesn't show.
    Here on PriusChat you can of course find people choosing not to go strictly by-the-book, and getting away with light honing.
  3. ASRDogman
    ASRDogman Senior Member
    7,571
    3,905
    There is an update kit that they started using in mid 2014, and then 2015.
    Pistons and rings. You "might" still be able to get just the rings for the
    original pistons. According to other's who have tried, the new rings are not
    compatable with the old pistons.
    But, you'll have to measure the cylinders to make sure they are not oval.
    If they all check out okay, you would want to hone them out so the new rings
    will seat in correctly. If you want them to last a long time.
    Honing, if done correctly, only cleans up the surface, and makes new cross hatch paterns.
    You don't want to hone too long or too much.
  4. Tombukt2
    12,950
    2,324
    Check with Deves or jahns custom Pistons in California . I would think you would be able to use two ZZ Pistons from Corolla and the non- Atkinson cycle whatever it is engine and then aftermarket manufacturers probably make regular tension rings in the diameter you need for your pistons and thickness and all that I used to do all of this stuff 30 years ago quite a bit. Many of the companies and the suppliers have changed but most of the activities are still reasonable and achievable they weren't using really low tension rings when I was doing lots of engine work so it wasn't an issue or an option I know deves was an outstanding spring steel ring maker for many years they may be out of business but somebody's picked up where they left off Jahns had or has quite a bit of experience with Toyota He did a lot of work with Pistons and slugs for Toyota engine when TRD was on the come up that was a long time ago but I'm sure you can probably round up regular tension rings reasonable oil control rings and all of that that will fit the existing grooves on pistons you have I don't know if these engines are stamped on the oil pan mating surface with the necessary numbers that dedicate your bearing and piston sizes and all that they were doing that for a while I don't know what they do now as most engines today pretty much are throwaways unless there are other reasons to do something else
  5. Tombukt2
    12,950
    2,324
    I would think you'd have to do some hella honing to ruin the cylinder liners and of course you're going to be using a ball hone in the right size we hope not the straight three stone silly looking thing those are no longer recommended to be used.
  6. rjparker
    10,135
    6,297
    djimbuser and Mendel Leisk like this.
  7. djimbuser
    djimbuser Member
    101
    36
    Henderson, Nevada
  8. Mendel Leisk
    41,406
    The video linked in post 6 is just what you need for piston/ring replacement (the revised rings require revised pistons). Attached TSB has part no's for the revised pistons/rings, head bolts, and a gasket kit (includes head gasket).
    Someone here recently mentioned they did piston/ring replacement without engine removal, fwiw, just removing lower and upper oil pans from below.
    djimbuser likes this.
  9. frodoz737
    frodoz737 Top Wrench
    4,696
    2,495
    33
    "Piston #1 does not reach the top of the cylinder"? Are you referring to the stroke...as in the up and down movement of the piston?
  10. rjparker
    10,135
    6,297
    Bent rod from head gasket failure. Some blow holes in the block.
  11. djimbuser
    djimbuser Member
    101
    36
    Henderson, Nevada
    piston: 13101-37240
    rings: 13011-37260
    rod: 13201-39185
    The same as 2015 Prius and 1.8L Corolla
    Pd30242 likes this.
  12. djimbuser
    djimbuser Member
    101
    36
    Henderson, Nevada
    I got the piston out and rod is both bent & twisted. Wasn't my fault at least since I bought it this way for cheap. To look at the glass half full the rod didn't snap and destroy the block. New pistons & rings and rod and I'll see if I can get it running properly.
    mjoo, bisco and ASRDogman like this.
  13. djimbuser
    djimbuser Member
    101
    36
    Henderson, Nevada
    Correct. This started out as a head gasket replacement. Once I got the head off, the crank was at TDC and piston #4 was at the top of cylinder4 but piston #1 was about 3/16" below the top of cynlinder1. An oh-crap moment.
  14. ASRDogman
    7,571
    3,905
    How do the cylinder walls look?
  15. djimbuser
    djimbuser Member
    101
    36
    Henderson, Nevada
    They look good.. so do the rod bearings.
    ASRDogman likes this.
  16. ASRDogman
    7,571
    3,905
    Get a 3 stone hone, and lightly hone. I take it you know how to use a hone???
    And do just enough to get the glaze off.
    Then you can really see if they are correct.
    Measuring them is the smartest thing to do. You can't really "look" at the walls and
    tell of they are oval or not.
  17. frodoz737
    4,696
    2,495
    33
    If the stroke is 3/16" "short" on one cylinder...you better check the crank too. You should consider a full engine teardown/rebuild/replacement.
    V Sport Wagon likes this.
  18. djimbuser
    djimbuser Member
    101
    36
    Henderson, Nevada
    Sorry I haven’t checked this thread in a while. The rod was both bent and twisted. I replaced the rod and went with Corolla pistons and rings like the 2015 Prius has. I completed engine reassembly yesterday and started the car and drove it a few gentle miles and no codes or leaking oil/coolant yet :)
    CR94, Brian1954 and Mendel Leisk like this.
  19. Mendel Leisk
    41,406
    All that banging/shaking at cold-start (with pooling coolant in the cylinders) takes a toll. :(
    Was the damper between engine and transaxle ok? There's a plastic panel at the underside of that interface, pretty sure it's for inspection. It's loose I've noticed, but I've never tried to remove on ours for a look.
  20. ASRDogman
    7,571
    3,905
    The rod on the left doesn't look straight. Maybe it's just the photo?
    Glad it's working!
