Check below cargo area for rust
Discussion in 'Gen 5 Prius Main Forum' started by daisy555, Jan 1, 2025.
  1. daisy555
    daisy555 Senior Member
    1,715
    708
    CT
    I’ve seen several FB posts stating some Gen 5 Prius owners are finding blistered paint/rust spots on the floor of their cargo area. Looks like the surface wasn’t prepped properly maybe? Might be a good idea to check this on your car. One guy said dealership took his car to their autobody shop to get it repaired. I’ve attached photos.
    In the mean time I’m trying to diagnose the leak in my Gen 2 which I just posted on an old Gen 2 thread. : \
    #1 daisy555, Jan 1, 2025
    tovli and bisco like this.
  2. Paul Gregory
    Paul Gregory Senior Member
    2,122
    555
    Alberta
    2024 Prius Prime
    XSE
    I'm blessed to live in a dry climate, where such rust is rare.
  3. bisco
    51,835
    wow, salt air on the car carrier?
    maybe not a big deal, but i hate paying for a new car that has to go to the body shoppe
    daisy555 likes this.
  4. daisy555
    1,715
    708
    CT
    You are fortunate but it should be non existent in any location on a brand new car, shouldn’t it?
  5. Paul Gregory
    2,122
    555
    Alberta
    2024 Prius Prime
    XSE
    Right ch'ar.
  6. Toyotaworker
    Toyotaworker New Member
    2024 Prius Prime
    This is NOT rust this is weld spatter. This can happen when weld tips are dirty, misaligned etc. The car will go thru a dunk tank call ED to clean the car before paint. The orange rust colour you see could caused by the ED & oils that are used before it goes into the tank before paint causing it to stick and not come off. The area this is in is not something that could be deemed a defect as it’s not in an area that MOST people would see/worry about or they thought it would be covered up by the black rubbery stuff you see there (that is a sound deadening) adhesive to give it a thunk instead of a tink
    soft_r and Gorgonzola like this.
  7. Toyotaworker
    2024 Prius Prime
    My 2022 Lexus also has this. Without removing the spare tire this is what I could see
  8. Gorgonzola
    Gorgonzola Junior Member
    31
    New Hampshire, USA
    2024 Prius
    LE AWD-e
    I noticed this phenomenon on my gen5 as well — appears to be more of a discoloration/build-up of coating than rust. So your explanation makes sense to me
