Prius Prime Battery Degradation?
Discussion in 'Gen 5 Prime Charging' started by Marwan Luay, Dec 31, 2024.
  1. Marwan Luay
    Marwan Luay New Member
    unknown
    2024 Prius Prime
    SE
    Was curious about the batteries and whether they're similar to previous prius gens when it comes to degradation, did they use the same battery or something that's more durable. Do we have any idea what's a 'lifespan' for it?
  2. RandyPete
    RandyPete Active Member
    396
    163
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    Which battery ?
  3. bisco
    51,524
    you'll probably see a few percent after a few years. everyones experience is different. we don't have any official testing data from toyota.
    these batteries last forever
  4. BiomedO1
    3,130
    1,660
    SacTown, Ca
    The traction battery changed to lithium from gen4 forward and your given a 10yr, 150K mile warranty on it. The gen4 had a lead acid battery under the hood, which went back to an AGM battery in the rear passenger side hatch on the gen5.
    Hope this answers your questions....
  5. Paul Gregory
    Paul Gregory Senior Member
    1,959
    493
    Alberta
    2024 Prius Prime
    XSE
    I only just got my Gen 5 a year ago, and no change so far, but I owned a Gen 3 for ten years, and it lost about 12% capacity since new.
    BiomedO1 likes this.
  6. bisco
    51,524
    and on those, the head gasket will blow before the battery dies
  7. mva
    mva Member
    118
    71
    B.C. Canada
    2024 Prius Prime
    SE
    I appreciate real experience like this. I trust that the Toyota engineers did a good job again with Gen 5. The Traction battery charging is set up with a good amount of buffer when empty or fully charged, which will help to extend the life. From what I’ve read here the battery is rated at 13.6 kWh and a full charge takes about 10.5 kWh. Zero miles of EV range still has 1.9 kWh or 13% charge remaining and fully charged is 12.4 kWh or 91% charge. So we are using 13% to 91% of the battery capacity. Also, Gen 5 is set up with liquid heating and cooling of the traction battery pack which will help to extend its life.
  8. RandyPete
    396
    163
    2024 Prius Prime
    XSE
    The '24 Gen5 Prius Prime aux battery is a 12v flood lead acid battery located in the back right hand corner of the car.
  9. Paul Gregory
    1,959
    493
    Alberta
    2024 Prius Prime
    XSE
    I'm hoping my Gen 5 will be as trouble-free as my Gen 3. I spent almost nothing for repairs for it.
    I think I read somewhere that Toyota designed the hybrid battery to charge to 70% capacity for the purpose of longevity. I'm inclined to believe it. My cellphone battery went bad in less than 2 years, and both types are lithium based.
  10. Mr.Vanvandenburg
    1,344
    559
    2020 Prius Prime
    The Prime can lose half it’s capacity in say 15 years and still be working fine just more charges than before. In a full ev, losing half can be a bigger problem. In a prime you can go on and still enjoy the low cost travel on trips and have long range on gas. Figure 20 years is about as long as most people keep a car, it is not something to worry about. Ok lots of 2004 cars still running fine, but will you be using a 20 year old car in 2044?
    I’ll have run my course in life, a car is the least thing I need to think about.
    PrimeDan and BiomedO1 like this.
  11. Paul Gregory
    1,959
    493
    Alberta
    2024 Prius Prime
    XSE
    I honestly don't know if my hybrid capacity has diminished in one year, but I doubt it. I might expect that from a cellphone battery.
    My EV range has gone down from a record of 61 kms during the summer, but now it tops out well before 50. I noticed that my EV range is directly related to the ambient temperature. I expect it to return to 60 kms this summer. Based on experience with my Gen 3 lithium battery, I was losing a bit more than 1% per year. When I bought it in 2012, the EV range was 18-20 kms. When I sold it recently, the EV range was 16-18 kms.
  12. BiomedO1
    3,130
    1,660
    SacTown, Ca
    I had a friend who bought a cheap used Nissan Leaf for $3K. Battery would only take him 70 miles on a charge. After another 5 years, he's down to 35 miles a charge. His commute to work is only 15 mile and he recharges at work. Great around town car and I'd say he got his money's worth out of it..... During the hot summer months, he needs to watch his AC usage - otherwise he may not make it home:whistle::ROFLMAO: He usually preconditions the car while it's plugged-in.
    As stated earlier, you'll just drive the Prime in HV mode, if the battery goes bad since you've got a lot of capacity.
  13. Deathcommand
    Deathcommand New Member
    2023 Prius Prime
    SE
    I'd imagine even if a prime had severely reduced capacity, it would still be better than a normal Prius because the threshold is much much larger.
  14. PrimeDan
    PrimeDan New Member
    Philly Suburbs
    2024 Prius Prime
    SE
    If I recall correctly, early models of the Leaf didn't have onboard liquid heating/cooling of the battery pack, hence the drastic reduction in range
  15. pokenoprius
    pokenoprius Member
    51
    27
    New Zealand
    2018 Nissan LEAF
    I will be upgrading from my 2019 prime to a Gen 5 PHEV( Japanese Z grade ) later this year, the only grade available here in NZ. I charge my 2019 prime fully maybe twice a week. ( the traction battery rarely gets to 1/4 empty , buffers aside ) For the Gen 5, Is it best to let the traction battery drain and then charge in full, or can we continue to charge every other night as a top off?
  16. Paul Gregory
    1,959
    493
    Alberta
    2024 Prius Prime
    XSE
    I believe the battery will last longer if you don't top it off every day.
    pokenoprius likes this.
  17. Trollbait
    12,430
    Continuing your current practice will be fine, and possibly better for the battery.
  18. BiomedO1
    3,130
    1,660
    SacTown, Ca
    All Prius traction battery packs were air cooled up to the gen4's. The gen5 started using the HVAC Freon for heating and cooling.
    PrimeDan likes this.
