Fuel economy degrading after Tuning
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MJKAwan, Dec 30, 2024.
  1. MJKAwan
    MJKAwan New Member
    Pakistan
    I have dine the general tuning of my prius 2013 model. The Tuning included following parts.
    Throttle body Cleaning
    air sensor Cleaning
    Fuel Filtor, Fuel Injectors Cleaning
    catalytic convertor Cleaning
    Egr.
    Spark plugs cleaning
    After tuning the fuel average has gone worse.
    Let me suggest what wrong had happen.
    Before Tuning it was averaging nearly 22liter/km while after tuning it is now giving 17 to 18 liter/km.
  2. johnHRP
    johnHRP Active Member
    644
    186
    KA, DE
    Excel
    22L/km is like armor vehicle. It is probably heavier than M1A2 Abram or Leopard 2 tank. :LOL::LOL::LOL::LOL:
    Probably you meant 22km/L which is about 4.3L/100 Km or 55 MPG, which is very high. Most people only get 45-50 MPG mix city/highway.
    I never recommend cleaning the MAF just because..., it often does more harm than good. I am not sure how do you clean catalytic ocnverter that contains ceramic with Pt,Pd, Ro metals on it. It also often just placebo effects. Unlike Diesel particular filter, there is no sludge or shoot on gasoline car catalytic converter because they are very hot, turn everything to ash.
    I think you measure the MPG not accurate enough. You should do a trip at minimum 1 full thank or 600 miles or 1000 km before getting good enough statistics
    #2 johnHRP, Jan 3, 2025
    BiomedO1 likes this.
  3. BiomedO1
    3,585
    1,856
    SacTown, Ca
    ^ That and your probably getting bad diluted petrol.
    Whatever caustic chemicals you dipped your Catalytic converter into may have stripped the materials out of it to perform it's designed function - rendering it useless or inoperable.
    Spark Plugs should be replaced, not cleaned. It's in the combustion chamber, it'll get dirty again as soon as you start the engine.
  4. johnHRP
    644
    186
    KA, DE
    Excel
    I actually clean and reinstal the sparkplugs every 5 years/60k miles because the change interval is 10y/120k miles in Denso Iridium SC16HR11. I only clean the tread, nothing else because the tips are in perfect condition. There is no such things called TUNE-UP in modern car. The ECU with injectors, O2 sensors, and MAF works dynamically. We only say change air filter every 4 years if the air is not too dusty. The cabin air filter is the one need to be changed or washed every year. The original Denso or Bosch filter is fiber glass and can be wash with laundry detergent.
    If you live in hot climate, make sure turn the AC ALL the Time. It is part of the cooling system for the hybrid battery. Park the car inside the garage to keep everything last longer too.
  5. ColoradoBoo
    ColoradoBoo Senior Member
    1,240
    827
    Monument, Colorado USA
    Did you disconnect the negative battery terminal for at least 5 minutes after doing this? This is a good idea because it will force the ECMs to go through all their recalculations and resets so the car could run rough for a bit but, then, will normalize and should bring those mileage numbers back up.
  6. johnHRP
    644
    186
    KA, DE
    Excel
    That's true if one clean the throttle body, the air mixture may be off and the ECU will do relearning. Removing the 12v battery - pole will reset the ECU throttle opening air mass learning.
