Wheel bearing noise…not wheel bearing though
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by John Galluccio, Jan 1, 2025.
  1. John Galluccio
    John Galluccio New Member
    New Hampshire
    Hello all
    I am hoping someone may have some advice
    I have a 2011 Prius I believe version 3. Approximately 169000 miles.
    Recently I noticed a noise when I’m driving around 40mph and turn left. The noise sounds like it is coming from the front right wheel. It sounds like a vibration or hum like something is rubbing.
    originally I thought maybe a brake issue but when I took it apart the pads are wearing evenly and other than a sluggish slide pin everything looked good. I cleaned and relubed the slide pin but the noise was unaffected.
    After doing some reading and consulting others we came to the conclusion it was the wheel bearing.
    I changed out the bearing but sadly the noise hasn’t changed.
    Above 50mph or so you can’t easily distinguish the sound from road noise….below 39mph and it fades away.
    if anyone could possibly point me in a direction for my next course of action I would be greatly appreciative
  2. Tombukt2
    12,950
    2,324
    Maybe it's actually the other side stuff is hard to hear in front ends and all that seriously. I know mechanics get the left and the right messed up when listening to wheel bearings and all that there's not really a lot in the front end of a Prius rotating around or reciprocating to make all this noise to be honest about it or I can't see it similar with my generation too both the front ends of both of these cars are very similar from drive axles to hubs and all of it so in your front end other than your axle your wheel bearing assembly and the carrier bearing that's the bearing you tap the axle into when you're installing a new one in your transmission and funny thing I just watched a video where Sherwood down at royalty Auto replaced a needle bearing with a sleeve and a Tacoma truck in the transmission where the front drive axle smacks into the transmission that is a kit that fits a whole lot of Toyotas I don't know if the Prius is included or if there's a similar fix I haven't heard of this problem on the Prius doesn't mean it doesn't exist but this had to do with where the axle went into the transmission with his chassis microphone setup he was able to clip that to the front end of the car and one or two places and that's how he discovered the problem He had one of his mic sensors sitting right under the inboard CV joint on the left side driver side and you can see the noise on the computer screen as the microphone picked it up when he put it in four-wheel drive or some other mode he put the truck in the noise would go away so it was when it was not in four-wheel drive I guess or maybe he locked the front wheels and the noise went away and unlocked when it was freewheeling It was noisy something along those line anyway there's a sleeve that's made to replace this needle bearing that's in this assembly I don't think we have the needle bearing or the sleeve but I haven't looked just a thought everybody's always talking about the wheel bearing but at the other end of the axle can be a lot of the racket where it goes into the transmission.
  3. ASRDogman
    ASRDogman Senior Member
    7,571
    3,905
    Rotate the wheels front to back to front.
    Or swop the front wheels right to left to right.
    Does the noise change? Bet it does.
  4. Leadfoot J. McCoalroller
    8,076
    7,557
    Pennsylvania
    2018 Prius c
    Have you listened to the other 3 wheel bearings? Those things are ventriloquists, you would not be the first one to have replaced the wrong one.
  5. Mendel Leisk
    41,406
    Drive shaft CV joint?
    (a quick skim of @Tombukt2 ’s tome: he mentioned as well)
    #5 Mendel Leisk, Jan 3, 2025
  6. Tombukt2
    12,950
    2,324
    I don't think the Prius has the same bearing type as the all-wheel drive light trucks maybe similar but I do know if there's play up there usually annoys will ensue never had a problem on it either of the Gen 3s the high mileage or the low mileage one with any of that I did replace the wheel bearings on the high mileage and put brake pads and new rotors but never really had any noise even the car that had 396,000 when it got parked with original wheel bearings and all the front end stuff original except the brake pads no noise dead quiet car other than plastic flapping that was coming undone on the body and chassis.
  7. rjparker
    10,135
    6,297
    Often the sound seems to come from the opposite side. I change both sides for that reason. Once the bad bearing is out it is easy to tell.
  8. John Galluccio
    New Hampshire
    Thank you all for your replies. I am sorry it took me so long to respond, I didn’t realize anyone had responded!
    I did jack up the front again and yanked on the other side from and both rears….all felt solid with no noticeable noise when manually spun.
    I also rotated the tires fronts to rears and the noise did not change.
    everyone I run the problem by says it sounds like a bearing though.
    is there any way to know for sure which one it might be? I hate to do the other front and have it be fruitless
    thanks again for all the suggestions
  9. Leadfoot J. McCoalroller
    8,076
    7,557
    Pennsylvania
    2018 Prius c
    The Chassis Ears kit is the definitive tool for solving this problem.
    There are several versions at different prices. I'm not suggesting you run out and buy it to solve one noise, but maybe call around town to find a shop that already owns one and pay them to do a diagnosis.
  10. ASRDogman
    7,571
    3,905
    You will have to remove the cv axel, and the brake pads, to be able to spin the hub without
    interference from anything then you cna hear the any noise and feel any grinding from the hub.
    For the rear hubs, you just have to remove the pads.
    You can use a long screw driver with the blade touching the hub and the plastic end touching
    your ear as you rotate the hub.
  11. John Galluccio
    New Hampshire
    Awesome
    thanks for the advice. Let’s hope I can hit pay dirt!
