How Long Until My Car Needs Replacement?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Moving Right Along, Jan 7, 2025.
  1. Moving Right Along
    Moving Right Along Senior Member
    707
    554
    I have a 2009 Prius, and it's developed rust on the wheel wells and door frames. I asked a shop about it and they said it's going to cost more to fix it than the car is worth, so I'm ignoring it for now. But from what I've heard, rust is the death knell for these cars. I first started to notice the rust a couple years ago, and now it's developed into visible patches around 3-4 inches in diameter. The car works fine mechanically and it's got 190,000 miles. I want to at least get it to 200,000, which will probably happen around the end of 2025 or beginning of 2026. But I'm not sure how much longer the car will last, and new and recent used cars are expensive. Around how long do you think my car will last before I need to start worrying about the rust causing problems?
  2. Tombukt2
    12,680
    2,263
    Well you're one of these guys that lives all over the USA and has no town so I don't know where you are are you in the real rust belt or what I used to live in Western Massachusetts cars there 3:00 to 5 years and the strut towers are rusting out and your front tires are cambering negative positive while driving down the road. Quite unsafe so there's always that now I live in North Carolina where cars can last my whole life I've got three generations two that will outlast me My daughter will be driving them when I'm expired I don't have the rust problem here so all you have to do is look at other people's vehicles and read and you'll find out generally how long vehicles of your size and welded unit construction will last in your area It's pretty documented it's not rocket science I could tell you if I knew where you were more than likely making 10,000 more miles on some rust around the rocker panels in the door seals oh God you'll go to 250 probably unless you never drive in the car just sits If it takes you to get to 250 to 2031 well then yeah the car may be gone. But rocker panel and door silll and and lower edge of door damage oh you're good to go for another 5 years easily generally speaking unless you're strut towers and suspension mount points are starting to rust any company that sells tires and does front end alignments will tell you very quickly You should make the 200k without any issue to be honest about it.
  3. bisco
    51,523
    it's impossible to know without clear and detailed examination and pictures.
    you could easily last another 50-100k.
  4. Moving Right Along
    707
    554
    I don’t know the condition of the underside. The first patch of rust is just above the drivers side front wheel and is the most obvious when looking at the car. The second is a 6 inch long strip of bubbling on the black paint trim between the drivers side front and rear windows. The third is at the bottom of the wheel well behind the rear passenger side tire, where I can see holes through the metal. And I live in Minnesota, so regular doses of salt on the roads.
  5. Leadfoot J. McCoalroller
    8,008
    7,483
    Pennsylvania
    2018 Prius c
    Rust like that is potentially dangerous because it will have substantially reduced the strength of the structure.
    It's fine for driving around and getting your groceries and stuff, the problem is if you're in a crash: it isn't going to protect you anywhere near as well as it once could have, because the metal literally isn't there anymore.
    A car with 20 years of salt treated road service just mushes into dust when you hit it.
    So... I think it's likely you can hit your odometer goal, but it is clearly time to budget and schedule the next car.
    BiomedO1 likes this.
  6. Moving Right Along
    707
    554
    Saving for the next car is definitely a goal. I was just trying to get a good idea on how long I’ll have to save. Given all the cars I’d be interested in are 3x-4x the price I paid for mine, I’d like to have 2-3 more years with the current car so I can get together the required amount. But we’ll see.
  7. BiomedO1
    3,130
    1,660
    SacTown, Ca
    I'd be more concerned with the "under-pinning" of the car. If something is going to break lose or cause it to be unsafe to operate. Then there's the other concern about crash protection. It one thing to take chances with your own life - but when you place someone else's life in danger, that changes the calculus of things.:(
  8. douglasjre
    douglasjre Senior Member
    2,143
    711
    Null, NL
    Rust is like cancer
  9. Moving Right Along
    707
    554
    I don't think my car is quite that bad yet. At my 180k service, the technician sent a video of the bottom of the car. He said the edges of the rotors were getting rusty, but didn't mention any other rust related concerns on the underside.
  10. Leadfoot J. McCoalroller
    8,008
    7,483
    Pennsylvania
    2018 Prius c
    It would be remarkable if your car matched any "best/worst of" on YouTube.
    It's pretty normal for a Toyota to last about 15 years on salted Northern roads. Nothing special about the Prius in that regard.
    Yours is definitely not done yet, but it's clearly the right time to start the early research, take a fresh evaluation of your current and upcoming driving needs and then factor it into your budget.
    BiomedO1 and Moving Right Along like this.
