New 2024 factory windshield blurry tinting
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Ashingler, Jan 11, 2025.
  1. Ashingler
    Ashingler New Member
    2024 Prius Prime
    SE
    Just bought the 2024 SE. The front windshield and rear window are slightly (but noticeably) blurry from what looks like the factory tinting. It's like looking through very thin plastic, instead of a new car window. Is anyone else experiencing this? Is it normal? Do I need to go back to the dealer?
  2. CooCooCaChoo
    CooCooCaChoo Senior Member
    961
    542
    Cow-lee-fornia
    2023 Prius
    There shouldn't be any tints on the front windshield. You sure it's not something on the inside if the windshield?
  3. Ashingler
    2024 Prius Prime
    SE
    Thanks, CooCooCaChoo (great name!) - I hadn't thought of that. I'll take a look and report back.
  4. Trollbait
    12,684
    The windshield at least is laminate glass with a layer of plastic film between the glass. If it is blurry, that's a defect.
  5. Ashingler
    2024 Prius Prime
    SE
    That's very helpful, Trollbait. Thank you.
  6. Mendel Leisk
    41,901
    Never heard of a car coming from the factory with a plastic film tint, afaik that’s strictly aftermarket. FWIW in BC (Canada) any aftermarket tint forward of the rear side doors is illegal.
  7. Prodigyplace
    12,678
    11,830
    Central Virginia
    Here in Virginia. you can get what they call a visor tint across the top of the windshield.
    Tint darkness for sedans:
    • Windshield: Non-reflective tint is allowed above the manufacturer’s AS-1 line (or top 5 inches).
    • Front Side windows: Must allow more than 50% of light in.
    • Back Side windows: Must allow more than 35% of light in.
    • Rear Window: Must allow more than 35% of light in.
  8. BiomedO1
    4,141
    2,170
    SacTown, Ca
    I'd take it back to the dealership to get it rectified. The issue is only going to get worse while driving in the dark, raining, or foggy conditions or any combination of the previous mentioned.
    Very few cars roll out of the factory with OEM tint, it's usually a very profitable dealer add-on by a local shop, contracted to do so. In any case, it's the dealers responsibility to make sure the car is road worthy and free of defects. They put it on, it's their responsibility to fix it.
    PS; make them give you a loaner car if they need to keep it overnight.
    #8 BiomedO1, Jan 12, 2025
    Prodigyplace likes this.
  9. Prodigyplace
    12,678
    11,830
    Central Virginia
    It is likely a safety hazard so they may need to provide a loaner under warranty until it is repaired.
  10. Ashingler
    2024 Prius Prime
    SE
    Thanks, folks!
  11. Mendel Leisk
    41,901
    It should be easy to determine if the windshield has a plastic film tint applied: it’ll feel slightly softer, and all around the edges it’ll stop, maybe 1/8” from the moulding. Again, if it’s present it’s aftermarket.
  12. Ashingler
    2024 Prius Prime
    SE
    I'm making an appointment with the dealer. I literally bought it new and there was no mention of tinting on the paperwork. The defective laminate glass assembly suggestion seems most likely but I will soon find out at dealer. And I'll report back to finish this thread.
