Replace tire?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Noahdoge, Jan 12, 2025.
  1. Noahdoge
    Noahdoge Active Member
    202
    144
    Mississippi
    I was filling up my tires today and noticed this crack on the sidewall. I bought these Pirelli P4 tires in 2021 and have probably put close to 70,000 miles on them, mostly my interstate commute. There’s still plenty of tread left on them, but is this dangerous or just cosmetic?
  2. BiomedO1
    3,156
    1,671
    SacTown, Ca
    IMHO; that's on the outer layer ply. Tires are made to take a lot of punishment. If there was a real problem, that area would start bulging. I'd probably rotate it to a rear axle position, easier to control the car if it should blow.
    Just my 2-cents......
    Noahdoge likes this.
  3. rjparker
    9,886
    6,094
    Most tire shops would say replace to be safe. A blowout at speed is very dangerous and will ruin the wheel at a minimum.
  4. frodoz737
    frodoz737 Top Wrench
    4,652
    2,487
    33
    Time to replace those tires...the whole set.
  5. ASRDogman
    ASRDogman Senior Member
    7,441
    3,870
    What is the mileage warranty? If you have less miles than the warrantied mileage,
    you'll get a pro-rated refund. Something to check into.
    It's looks like something hit the tire and damaged it.
    The little cracking is not an issue, yet. It's that slice you should worry about....
    What do the other tires look like? Are they the same?
  6. Grit
    Grit Senior Member
    6,571
    4,223
    Wilkes Land
    This is one of those not all information upfront like tire warranty and tread that is left so we can go buck wild guessing.
    Replace all four tires now since 70,000 miles are logged, is my blind guess.
    frodoz737 likes this.
  7. Mendel Leisk
    40,991
    70k means you don’t have to think too hard about it.
  8. Noahdoge
    202
    144
    Mississippi
    Thanks for the replies everyone! I decided to go ahead and order 4 new tires just to be safe. I was able to open up that cut on the sidewall and it was way deeper than I thought.
