Pistons washed...
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Brabus82, Jan 12, 2025.
  1. Brabus82
    Brabus82 Junior Member
    Taylors, SC
    2015 Prius v wagon
    I have a 2015 V with 201k on it. I bought it about 140k a few years ago and it's been a good car.
    Currently I'm chasing a slight rought start in the morning. It's not rough like I see from the cars with the bad head gasket issues but it does have a little shake on the first startup. I don't know if I'm over thinking it or hopefully catching something before it becomes a bigger issue.
    I pulled the EGR, EGR cooler, intake, etc and cleaned everything and changed the plugs about 7k miles ago just to see how it looked. I cleaned up a lot of carbon from the intake and EGR but it didn't seem to make much difference on startup.
    I do have a very slight fuel smell on the oil dipstick that I don't remember in the past but I've seen a lot of people say that can happen with the hybrids over the winter. It is due for an oil change now. I haven't pulled the injectors out yet but my guess is they are probably carboned up if the intake had that much carbon.
    I pulled the plugs out last night and scoped the pistons. Pistons 1 and 4 are definitely cleaner than 2 and 3 but they don't look HG clean unless it's a very small leak at this point. I find it interesting that it's the two outer pistons and not 1 and 2.
    I have a video on my photos but it won't let me link it because I haven't posted enough. Haha. I've lurked here for years though...
    Any thoughts?
  2. rjparker
    10,170
    6,321
    1 and 4 are steam cleaned. It can be several cylinders.
    The egr cleaning is always a waste of time if you don't have egr codes.
  3. Brabus82
    Taylors, SC
    2015 Prius v wagon
  4. Mendel Leisk
    41,522
    You did the EGR cleaning way too late. You’ve had protracted run time with partially clogged EGR system, head gasket’s starting to let go, and now you clean the EGR. It’s illogical to think that would somehow fix the head gasket.
    Brabus82 likes this.
  5. Brabus82
    Taylors, SC
    2015 Prius v wagon
    That makes perfect sense. In the back of my mind, I thought the new gasket design fixed the issues of the earlier third gens and didn't tie the two together before that. I was hoping initially that the EGR itself was not functioning correctly.
    I've not had any misfire codes through this process yet. I usually have Torque running so I can see temps, and I've never noticed it running hot, so hopefully, it's early enough to not cause many head issues.
  6. rjparker
    10,170
    6,321
    If the above is the worse you get I would not worry about it. Generally the hg rattle is more severe and several seconds longer. However warm starts are usually good even when a severe rattle has previously happened. The engine is ready to blow a hole in the block when it happens at stop lights, eg engine offs while in Ready. By then a hg alone is a waste, an engine is the right answer.
    A gen3 head gasket fail is almost never associated with an overheat and is clearly a multifactorial design flaw resolved with the gen4 redesign.
    Obviously any car with an aluminum engine will blow if it is overheated. The few gen4s with a hg problem are caused by an overheat caused by an exhaust heat recirc coolant leak into the exhaust.
    When it comes to overheats, too many people drive them with a warning light or a warning light that flashes and goes away. Toyota finally came to that realization later and added a temperature gauge on some hybrids.
    #6 rjparker, Jan 13, 2025
  7. Brabus82
    Taylors, SC
    2015 Prius v wagon
    That makes sense on the Gen3 HG. Toyota has a different part number for the Gen3/4 2ZR-FXE but it you look at felpro they use the same part number for both of them. Wonder if you could just swap the head over from a 4th gen. I wish it had the 2.5 from the Rav4... lol
    Yeah, I wish it had a temp gauge. Even my Ram 2500 CTD doesn't have a dedicated temp gauge. I have the change one of the dash screens to even see it. I miss the old school coolant / oil temp etc. lol
  8. rjparker
    10,170
    6,321
    No you can't just change the head. Most of the gen4 cylinder cooling improvements are in the block. The cylinder cooling was dramatically changed including a special insert in a slot around the cylinders to even out cylinder wall temps.
    Gen4
    Plus a new large volume egr system with exhaust picked up after the cat instead of before as in a gen3.
    Toyota also updated their gen3 head gasket with more of the black sealer on the metal hg.
    Some have retrofitted a gen4 engine into a gen3 but it is a frankengine with gen3 egr, intake, exhaust along with slight wiring harness mods and completely custom aux cooling circuits with frequent overheating complaints.
    Others report success with used in Japan JDM gen3 engines which fit properly and are advertised as low mile. It is interesting the 2017 gen3 Prius v was still sold in Europe and Asia until 2022. Those engines could start showing up as JDM imports.
    #8 rjparker, Jan 13, 2025
  9. Brabus82
    Taylors, SC
    2015 Prius v wagon
    That's interesting. My EGR was dirty, but it wasn't as bad as expected. None of the EGR passages on the intake weren't blocked off with carbon. There was a layer of carbon all over, but not nearly as much as I expected to see.
  10. rjparker
    10,170
    6,321
    While I don't think the gen3 cooling system capacity is an issue, I still monitor it and have for many years.
    P10 Obd2 Display
    The best thing with this kind of display is you can set an audible alarm lower than the factory 248f. I have it set to 220f because I have never seen high load temperatures over 210f. Normally in 100f ambients with full ac it might be 195f.
    Some have had issues with obd2 devices like Scanguage impacting other can bus traffic or bluetooth scanners causing excessive parasitic draw. I measure 6 ma draw while running with this model (newer models are available) and zero incremental when off. Your experience could vary but I like the lower temp audible alarm.
    I also display accurate mph speed with a 78 mpg audible to avoid freeway tickets.
    Brian1954 and Brabus82 like this.
  11. rjparker
    10,170
    6,321
    When it comes to egr valves, Toyota has an updated version for gen3 which may reduce stuck open valves causing low rpm stumbling and codes.
    This real egr issue is easily tested without disassembly other than two easy bolts
    Car care Nut Egr video with block tube test
    The updated egr valve includes an ecu software update which is also recommended with their revised intake manifold.
    Egr valve updated Kit 04004-58137 with 25620-37120 Updated egr valve. The kit includes the valve and gaskets at less cost than the valve alone.
    Aftermarket egr valves often code right out of the box.
    Some speculation was fueled by a European recommendation to change the valve and ecu software to improve hg problems. There is no corresponding recommendation from Toyota USA but several of us have the revised valve or at least the latest ecu software.
    #11 rjparker, Jan 13, 2025
  12. Brabus82
    Taylors, SC
    2015 Prius v wagon
    I haven't had time this last week to mess with the V. Hopefully, I get some time to start getting parts together this week. Last night, I rotated the crank to get better pictures of Cyl 2 and 4. Cyl 4 doesn't look washed so badly, which makes more sense. Interestingly, I see a cleaner spot between Cyl 1 and 2. I overlaid them next to each other in the same photo/orientation.
    #12 Brabus82, Jan 20, 2025
  13. Mendel Leisk
    41,522
    This is where 3rd gen head gasket usually fails first:
  14. Brabus82
    Taylors, SC
    2015 Prius v wagon
    That's what I thought from everything I've read. Look just slightly below that at pistons 1 and 2. See the light circle coming out of the each side?
  15. Brabus82
    Taylors, SC
    2015 Prius v wagon
    It looks pretty clean for 200k. The block and head are flat. A couple of the intake valves leak cleaner and I fill the ports. Going to pick up a valve spring compressor to change the valve seals and lap the valves. 20250201_171624.jpg 20250201_120642.jpg 20250201_175239.jpg 20250201_175755.jpg 20250201_175740.jpg
    SM-S921U ?
  16. Mendel Leisk
    41,522
    Took your lower/right pic, rotated and upsampled 50%, and not seeing any obvious coolant "breaches". Could be leakage was just getting started. (y)
    Brabus82 and Brian1954 like this.
  17. Brabus82
    Taylors, SC
    2015 Prius v wagon
    That's what I think too. It was early stages for sure. The typical spot between Pistons 1 and 2 is flatter than the rest. If you look at the bottom side by piston 4, I see the beginning of a compromise there too. Pistons 1 and 2 don't look washed yet but they don't look as matte as pistons 2 and 3. I need to lap the valves. I found a couple that leak a little and put new seals.
    SM-S921U ?
  18. Mendel Leisk
    41,522
    Likely you nipped it in the bud.
    Check all the interfaces with a straight edge and feeler gauges, against the spec in last link in my signature. If I was in your shoes, and didn't have a machinist's straight edge (or one I could borrow), I might dig out my collections of slotted angle, levels, and some salvaged, extruded aluminum bars. Seems to me if I place two of them edge-to-edge, and can't squeeze a thin feeler gauge through, they're more'n likely straight enough.
    And you've got a valves leaking a bit.
    Did you get the Toyota Gasket Kit btw? It has valve seals I think.
  19. Brabus82
    Taylors, SC
    2015 Prius v wagon
    I ended up picking up a Malhe kit but yes it has all the gasket pieces I need.
    SM-S921U ?
