combination meter repair - DIY
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ultanium, Jan 20, 2016.
  1. jonsey1886
    jonsey1886 Junior Member
    Roanoke
    Bold emphasis is mine.
    Mr._Mulligan likes this.
  2. ChapmanF
    18,706
    There seems to be something of an opinion split over whether all of that work is necessary, or just replacing/increasing C3 generally does the trick.
  3. Mr._Mulligan
    Mr._Mulligan New Member
    Riverside, CA
    OK, first major test of the repair. It was 42F this morning. The combo meter always fails when the temperature drops below 48F. It came on right away. If I recall correctly, when I did this repair the first time in Feb of 2024, it also worked when it got this cold. So, I might not know how permanent this fix is until next winter.
    If it starts to fail again next winter, I will not only replace the caps but I'll also replace the voltage regulator.
  4. KitsuneVoss
    KitsuneVoss Member
    374
    55
    Virginia
    My 2009 Instrument cluster always seemed to fail at random times, my roommate's 2007 instrument cluster seemed to always fail when the car was warm, and my 2006 seemed to fail the "final time" when the car was warm although also seemed to do the random thing. Was able to get it to work again but stopped at 7-11 to get a diet Pepsi and would not come on again. Always used the various tricks to get the cluster to work in my 2009. My roommate bought hers from a Toyota dealer so they replaced it as part of her purchase. I simply replace the capacitor in my 2006 and we have been having a number of 20 degree nights. So far it has been fine.
  5. Mr._Mulligan
    Riverside, CA
    Interesting that the conditions under which the combo meter fails is different from car to car. In my car, it has been 100% low temperature related. My uncle gave me the car, and he never experienced the issue, because he always kept it garaged. Even in the winter, the garage doesn't get as cold as the outdoors. My garage, like most California homes, is used like a basement. LOL.
  6. Mr._Mulligan
    Riverside, CA
    Coldest morning yet, and the fix still holding. I have frost on the car, yet the dash still indicated 41 degrees.
  7. mcprogram
    mcprogram New Member
    Colorado
    Hello everyone!
    Not a prius guy myself but am reaching out on behalf of my cousin. 2004 prius, 250 some thousand miles.
    He was having what seems to be the common issue here, full death of the meter with no open door light. He sent me a youtube video of just replacing the 100 to a 220 cap and supplied 10 caps of unknown origin (likely amazon).
    I went ahead and did the repair per the video, it worked for a day and crapped out again. I did some more research, finding this thread, having him buy caps from digikey (no voltage IC as i do not have a hot air station). Replaced, worked for a day, but he let the car run out of gas and now there is a much weirder set of symptoms, as follows:
    No speedometer/odometer/gas regardless of if the open door light is on or not.
    Flashing of all lights in the cluster.
    Intermittent big red triangle that corresponds to a useless “Problem!” warning on the center screen. Flashes with the other lights, but will stay on longer, and will beep.
    Passenger seatbelt sign is flickering.
    All in all, this screams weak power source to me. Could his voltage IC on the board be fried from letting the caps presumably go completely bad? Or having worrying quality amazon cap on the main 220 trace?
    All connections have been cleaned and verified on install of the dash back into the car. No corrosion present on any connector. I will be going over the solder joints for the entire board tonight, but any help would be appreciated.
  8. dolj
    dolj Senior Member
    8,604
    4,366
    Wellington, New Zealand
    There are like 200+ possibilities for the master warning light (red triangle). The same applies to the other warning lights, to a lesser extent, so all a light tells you is that there is a code or some codes to read relating to the appropriate system.
    If by intermittent, you mean the light flashes quickly for short periods, like slowing down or taking a corner, then that could be an indication that the oil is perilously low. I would have your cousin check the oil dipstick and add oil if necessary. Tell him to stop driving the car until he has done that.
    Possibly. If you want to reach out to Texas Hybrid Batteries, they have been known to be able to help out and advise on what to do. They can replace the power IC if you conclude that's what needs to be done, assuming you don't want to set yourself up with a hot air station.
    P.S., if your cousin's Prius is 2004, as indicated in your profile, its CM will top out at 299,999 miles. Therefore, you might want to consider getting the 2006-2009 retrofit (upgrade??) offered by Texas Hybrid Batteries, which addresses that issue.
    P.P.S., there is a bridging cable that plugs in on both ends. The CM end is disconnected to remove the CM, but the car-side connector can be inadvertently pulled loose, so that might be worth checking too. There is a picture, maybe in this thread, of that cable.
    #408 dolj, Jun 14, 2025
  9. KitsuneVoss
    KitsuneVoss Member
    374
    55
    Virginia
    Question, related to the 2004 then. . . . .Does a 2003, the older body style, also top at 299,999?
  10. dolj
    dolj Senior Member
    8,604
    4,366
    No idea, maybe someone with Gen 1 knowledge will happen along, or you could ask in the Gen 1 forum, where you will definitely find Gen 1 knowledgeable people.
  11. joey.b
    joey.b New Member
    texas
    So, i took apart the dash and replaced the CM, replugged everything and put it all back together. Now, i turn the car on and the red triangle warning signal is on (Master Warning Light) and a screen stating "
    There is a problem with the transmission 'p' lock mechanism. Park your car on a flat surface, and fully apply the parking brake." Would it be possible that when i reconnected the Parking button clip that it could have not latched all the way or not totally connected? or would it definitely be what the internet says the the battery voltage or other technical issues, and would it be a waste of time to take it to the dealership..?
    2006 Prius 107,000 miles by the way, hopefully this wasn't a totally dumb question.
  12. ChapmanF
    18,706
    What's the trouble code?
    Given all the things you had to disconnect to get to the CM, I wouldn't be surprised if it's a dodgy connection.
  13. VFerdman
    VFerdman Senior Member
    1,194
    1,218
    Western Massachusetts
    I remember having to reset the codes after I did mine. Everything was fine after I did so. Give it a try.
  14. joey.b
    joey.b New Member
    texas
    the error code accompanying the master warning light is the yellow brake light, so today im going to try to unplug the push to start connector and reconnect and see if that helps. I took the car around the block and it rough idles and breaks abruptly now. this car has driven super smooth since having it, so this is concerning.
    would the codes cause the car to drive differently, or is the new rough idling while braking a sign that the codes are right and it needs to be looked at? also, in the event that i could just clear the codes how do you go about that?
    #414 joey.b, Jul 15, 2025
  15. Brian1954
    Brian1954 Senior Member
    2,489
    996
    South Central PA, USA
    What is the voltage of the 12v battery?
  16. joey.b
    joey.b New Member
    texas
    its says 14.2 while IG-ON and 12.1 when just battery on. i just replugged the parking clip and now that error code has gone away. my battery seems charged just fine. The new error code is the drive malfunction (looks like a little car with exclamation point on my screen)
  17. dolj
    dolj Senior Member
    8,604
    4,366
    That does not help very much. What is the actual code?
    Brian1954 likes this.
  18. gdanner
    gdanner Member
    134
    51
    Central Illinois
    Digikey now stocks surface mount electrolytics with "automotive" temperature ratings ( 125 C ).
    105 C used to be the highest widely available temperature rating.
    But electronics located inside a car can get hotter than 105 C. So today there are plenty of capacitors specified for "automotive applications." These are rated at 125 C (some have even higher temperature ratings).
    Links below:
    Large selection list of 220uF capacitors:
    https://www.digikey.com/en/products/filter/aluminum-electrolytic-capacitors/58?s=N4IgjCBcoEwKwyqAxlAZgQwDYGcCmANCAPZQDaIMYMALAOwAcIRVtDAnM5dTe4i9TgAGOiAC6RAA4AXKCADK0gE4BLAHYBzEAF8iYdhyQhUkTLkIlyIIeN2UhvIybP4ipSBRgwhAAgCtAGLiUrKQIACqairSAPJoALJ4GDgArkp4OiwinNDG6Niulh7gAGw+AGrBIDJykdFxiclpGXYAtIi5JsopFu4UcLZ2HRR4WHjIysRYAJ7SKqhi2kA
    Smaller list of 220uF 16V surface-mount capacitors rated for 125 C:
    https://www.digikey.com/en/products/filter/aluminum-electrolytic-capacitors/58?s=N4IgjCBcoGwJxVAYygMwIYBsDOBTANCAPZQDaIALAAxwDMdIAuoQA4AuUIAymwE4CWAOwDmIAL6EATAFZJiECkgYcBYmRCSKkuGAAcIKWE0B2fcxDtOPASPGEwcXQmgK0WPIRKRyVJhI1UFM7Ibiqe6pKSVAAEAK0AYkysHJAgAKqC-GwA8qgAsrjo2ACuvLh2AcbBrkruql7kYDDRAGpJFinpmTn5hSVlFQC0ci6KfMX16tJ%2B-iPkuJi4SHxEmACebPwo5tMuLFBgrPuQMmJiQA
    #418 gdanner, Aug 6, 2025
  19. PriusTech
    PriusTech Active Member
    263
    120
    Reno
    I went to a hybrid repair shop in Sacramento to buy a hybrid core battery. They were Toyota specialists and they do the blacked out cluster repair. They said that you only need to replace the upper right cap, not all three.
    gdanner likes this.
  20. Eradan
    Eradan New Member
    Czech Republic
    Hello guys,
    I also have a problem with the combination meter, one day it just did not light up. I had no previous issues with it (dimming, blinking, etc.)
    However, when we replaced the condenser (we have replaced all 3 in the cluster to be safe), this did not solve the problem.
    My friend isolated the problem to SMD fuse - did anyone replaced this or could you help me get the specification, so I can order a replacement?
    Thank you for any help!
