Trunk Light
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Djyoshi626, Jan 25, 2024.
  1. Djyoshi626
    Djyoshi626 Junior Member
    34
    LA
    2024 Prius
    The stock trunk light is ridiculously dim. Has anyone changed out the light in their trunk?
    bostonbruins8703 likes this.
  2. wrtboy168
    wrtboy168 Member
    70
    29
    Northern California, USA
    2024 Prius
    Djyoshi626 likes this.
  3. Brumey
    Brumey New Member
    Sacramento, California
    2024 Prius Prime
    XSE
    Niche price too :)
    wrtboy168 likes this.
  4. Hammersmith
    Hammersmith Senior Member
    2,495
    2,554
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The stock light is so poor, I'd probably be willing to pay that much for a plug-and-play solution like that, but the placement is godawful(I realize they are stuck using an existing removable panel to make a clean install, but still...)
    Not only is your body going to block the light as soon as you move close to grab anything, but there's a real chance the LEDs are going to be hit repeatedly by any shifting cargo when the car's in motion. When the hatch is closed, those lights are going to be at or near the level of the cargo floor.
    I'm hoping someone eventually comes up with a better solution.
    Djyoshi626 and wrtboy168 like this.
  5. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    Led
  6. Mksky
    Mksky Member
    61
    35
    Los Angeles
    2024 Prius
  7. Mksky
    Mksky Member
    61
    35
    Los Angeles
    2024 Prius
  8. Djyoshi626
    34
    LA
    2024 Prius
    Thanks for the recommendations!
    Mksky likes this.
  9. Sharol
    Sharol Member
    162
    76
    Kansas, USA
    2023 Prius
    I think I'll just put a little flashlight back there.
    Jason Mosiman and douglasjre like this.
  10. Lantaral
    Lantaral Member
    66
    31
    US
    2024 Prius
    That one appears to be a brighter, drop-in replacement for the dim cargo light that comes installed. $15 + shipping.
    Where does the other light install?
  11. Mksky
    Mksky Member
    61
    35
    Los Angeles
    2024 Prius
    otatrant and wrtboy168 like this.
  12. Lantaral
    Lantaral Member
    66
    31
    US
    2024 Prius
    If the switch is set to on, does it light when the hatch is opened and turn off when closed? (like the OEM).
  13. Mksky
    Mksky Member
    61
    35
    Los Angeles
    2024 Prius
    When you switch on, the light is on when you open the trunk and shut off when you close the trunk. When you switch it off, it will forever be off even if you open your trunk.
    skirmish and Lantaral like this.
  14. priusdriver223
    84
    32
    Lala Land
    2023 Prius
    XLE AWD-e
    Hey there, I think there’s a ebay listing for a brighter light, im thinking of buying one. Cheers!
  15. rymo926
    rymo926 Junior Member
    San Francisco
    2024 Prius
    Following
  16. rymo926
    San Francisco
    2024 Prius
    Just found it on AliExpress for $6. Going to give it a try.
  17. priusdriver223
    84
    32
    Lala Land
    2023 Prius
    XLE AWD-e
    Hey there, I’ve tried that one before, didn’t fit for me but let me know how it goes. Cheers!
    Lantaral likes this.
  18. wstt
    wstt Member
    148
    26
    Did you try it? Didi it work? Or not fit?
  19. rymo926
    San Francisco
    2024 Prius
    didn’t try. Someone on FB tried another one from Ali and said it fits. Just got my seat covers so working on that. Here’s the link.
  20. rymo926
    San Francisco
    2024 Prius
    Here’s a screen shot. If you’re not on that group. I kind of actually changed my mine on it and prefer the dim light. I had a super bright light in my last car. Really impressive when I pop the trunk but due to the relative brightness, as I move stuff around, anything in the shadow becomes completely dark. It was kind of annoying.
    #20 rymo926, Jan 31, 2025
