Someone smashed the driver side window, advice on replacement?
Discussion in 'Gen 5 Prius Main Forum' started by thnok, Jan 19, 2025.
  1. thnok
    thnok Member
    122
    44
    2023 Prius
    Someone broke the driver side window (glass), maybe hoping it’s not a Toyota Prius or for some idiotic reason. Anyways, I’m trying to get it replaced and looking for advice.
    1. is it a DIY-able repair? Any guides since I haven’t seen much on YouTube.
    2. Can Safelite do the replacement with the original Toyota glass? I currently have an appointment in two week. The folks on the phone said it’s possible, I’m skeptical.
    3. Is the body shop/collision at the dealership a good place for it? I might end up paying out of pocket since I live in a snowy area and can’t afford to wait.
    any other advice on this, thanks.
  2. ChapmanF
    17,739
    Usually door glass replacement isn't very hard to DIY. You get the hang of it the first time, how the inside door panel comes off and so forth. Vacuuming the glass crumbs out of the bottom of the door can be the slowest part. If you live in a place where this kind of thing happens more than once, you can get pretty fast.
    I'm not sure if there's anything very special about Toyota side glass compared to what your friendly local glass shop has. You might at least compare the price and see how special that is. I think I would be more likely to pop for Toyota glass for a windshield, say, especially if the car has a heads-up display or driving assist cameras.
    thnok likes this.
  3. BiomedO1
    3,130
    1,660
    SacTown, Ca
    It's nothing special and easy to do if your handy.
    A bear smashed out the drivers side door glass on my old SR5 pickup while I was camping. It was only the second time I've ever changed a door glass. Yes, vacuuming out the glass takes a long time, If you don't want it to rattle while using the door or bouncing down the road.
    If you can't get the glass in, peel back the front and rear glass u-guides. You can slip them back in, once the glass is in place.
    Good luck.....
    thnok likes this.
  4. Prodigyplace
    12,462
    11,703
    Central Virginia
    Some trims of the 2025 Camry have an acoustic noise reducing front side glass. Something similar may also apply to some Prius trims.
    thnok and Trollbait like this.
  5. Paul Gregory
    Paul Gregory Senior Member
    1,958
    493
    Alberta
    2024 Prius Prime
    XSE
    My Gen 3 got broken into twice. I went to Toyota to price out a new passenger side window. Apparently it was a separate part number, being a Prius plug-in, and had a higher price than the regular Prius. They quoted me $1000 CAD, plus an 8 week wait, minus installation.
    I called a wrecker and he quoted me $80. When I got there to pick it up, he said he'd made a mistake, it was $60. I put it in myself in 10 minutes after watching a YouTube video on my phone.
    The second time it happened, I went straight to the wrecker.
    #5 Paul Gregory, Jan 19, 2025
    thnok likes this.
  6. Trollbait
    12,430
    I believe the higher Prius trims do.
    Prodigyplace likes this.
  7. frodoz737
    frodoz737 Top Wrench
    4,647
    2,487
    33
    Respects, but you already pay for insurance that handles this for you.
  8. thnok
    thnok Member
    122
    44
    2023 Prius
    I’ve got an XLE Prius. Any idea who to find it out?
  9. Prodigyplace
    12,462
    11,703
    Central Virginia
    For the Camry, it is listed in the sales brochure. Otherwise do a parts lookup online. For some reason, the 2025 Camry parts are still not listed online even though it was released in May 2024.
  10. schja01
    schja01 Senior Member
    1,827
    1,217
    Chicagoland
    2024 Prius
    Limited AWD-e
    Do you carry "Comprehensive" coverage on your car insurance? If yes that would cover the repair minus your Comprehensive deductible if any.
    Mendel Leisk and Prodigyplace like this.
  11. Trollbait
    12,430
    My knowledge came from discussions here. It might only be true for the Prime. From comments, the laminate glass has a different tint than the standard glass on the rear windows. There might be a label etched on the lower corner of the glass.
    The big clue is in how it broke, and the fact it did break. The fancy glass is the one that is the one that makes it hard for rescuers to get into, and it doesn't shatter into pieces.
  12. Paul Gregory
    1,958
    493
    Alberta
    2024 Prius Prime
    XSE
    I've been carrying a rescue knife, with a seatbelt cutter and a glass breaker, should I find myself trapped in a wrecked vehicle.
    Not all glass breakers are created equal. If the point isn't harder than the glass, it won't shatter the window; it will just make a divot on the glass.
  13. xliderider
    xliderider Senior Member
    8,131
    3,268
    Honolulu, HI
    Window tint film will also hold the glass together. A desirable feature from a security standpoint, but not so much in an escape scenario.
    SM-G781V ?
  14. Paul Gregory
    1,958
    493
    Alberta
    2024 Prius Prime
    XSE
    Window tint is illegal in most places.
  15. Winston Smith
    Winston Smith Active Member
    292
    212
    OH
    2024 Prius
    LE AWD-e
  16. Mendel Leisk
    40,974
    I think Canada-wide, but at least in BC, aftermarket tint is not allowed forward of the rear side doors. US seems a lot less stringent though, even allows windshield tint in some States I think. Which seems nuts to me, especially for night driving.
    Exactly. Near-new car too.
  17. Prodigyplace
    12,462
    11,703
    Central Virginia
    My state allows a lighter tint on the front side windows & the top 6 inches of the windshield.The windshield visor tint is especially good for us height challenged people. ;)
    #17 Prodigyplace, Jan 20, 2025
  18. Gokhan
    Gokhan Senior Member
    5,911
    2,336
    Paramount CA
    Around here in LA County, everyone has dark tint. You can’t see the inside of the cars at all at night.
  19. Mendel Leisk
    40,974
    And the drivers are half-blind as well, lol.
    Gokhan likes this.
  20. Paul Gregory
    1,958
    493
    Alberta
    2024 Prius Prime
    XSE
    Most people around here just find a doctor who will take cash to write you a note claiming you have a skin condition that allows you an exemption from the tinting law.
