2016 aftermarket wiper blade replacement
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Loots, Nov 13, 2024.
  1. Loots
    Loots Junior Member
    Arlington, WA
    Three Touring
    I bought my ‘16 three touring new. Several years ago nobody made direct replacements for the complete wiper blade assemblies. So I have had to resort to the factory rubber inserts. Does anyone now make a complete replacement? I remember this being a ‘16 only issue and the wiper arms were changed in later models. Anyone have info or experience with this? Thank you for your help.
  2. Drakxyfly
    Drakxyfly Member
    119
    29
    Usa
    2021 Prius
    The factory silicone inserts are the cheapest and best option. If you want to change the whole assembly any AutoZone or Walmart will do.
  3. BiomedO1
    4,129
    2,168
    SacTown, Ca
    I just bought a roll of commercial wiper inserts and cut them down to size.
    I believe the OEM inserts was rubber, not silicone. At least on my car they barely made it 18 months. The commerical roll I bought was silicone based and has lasted me more than 24 months and counting, no chatter or skips, just a nice clean wipe..
  4. slinke1
    slinke1 Junior Member
    2016 Prius v wagon
    "I just bought a roll of commercial wiper inserts and cut them down to size."
    Where did you get it?
  5. Mendel Leisk
    41,898
    Did you retain the originals?
  6. BiomedO1
    4,129
    2,168
    SacTown, Ca
    Off of E-bay, but you'll need to look at your current wipers and are they OEM. Mine had capture caps on both ends, so these slid right in. Cut them down to the length you need, my longest blade was 28", but the other is only around 15". I just measured out the old one and snipped it down to size.
    4 x Universal 28" Car Bus Silicone Windshield Frameless Wiper Blade Refill | eBay
    slinke1 likes this.
