Engine coolant temperature sensor replacement - P0117
Discussion in 'Gen 3 Prius Main Forum' started by Steven Stolle, Dec 21, 2021.
Tags:
  1. Steven Stolle
    Steven Stolle Junior Member
    25
    Bellflower, CA
    I have a P0117 DTC code and am replacing the temperature sensor. I tried to remove the connector from the sensor but it will not disengage. Is there a tool that I can use to remove it?
  2. ChapmanF
    18,022
    They are generally just squeeze and pull. When they've been there for ten years it can be a little more like squeeze and persuade, but there shouldn't be much more to it.
    P0117 means there was a moment, at least half a second long, where the ECM thought there was a short in the circuit to the coolant temperature sensor.
    What was your process to ascertain that the problem is in the sensor itself and not in the wiring?
    I think the sensor is a simple thermistor and (never say never, but) probably isn't very likely to go bad.
    Tombukt2 likes this.
  3. Steven Stolle
    25
    Bellflower, CA
    The Toyota repair manual gives several causes for the P0117 code. First is the ECT sensor; second is the thermostat; third is a short or dirty connectors contacts, etc. I'm following the order of causes given. The connector on the sensor is difficult to reach with little space to squeeze and remove. The connector is in a position that doesn't allow a small screwdriver to engage the tang in the connector to release it. I think I need some kind of a plier tool to engage and release it. I came to this board to get advice on finding a tool like that. Any ideas on that?
  4. ChapmanF
    18,022
    When I see a connector like D6, all I generally do is squeeze the tab and pull the connector off. Yes, sometimes they are in awkward positions, and sometimes after being on there for years they are a bit recalcitrant, but there isn't any specific releasing tool needed. Sometimes you just need to see what you've got around, and improvise.
    When you see something like this in the repair manual,
    while the "trouble area" column is usually organized in a rough order of likelihood (in this case suggesting you might first look at the possibility of a wiring short), that isn't exactly the same as instructing you to "change this thing, then change that thing, then change the third thing." It is giving you the possibilities you need to gather evidence about in order to determine which thing to change.
    As you see, that list suggests considering first the possibility of a wiring short.
    Looking through the rest of that nine page diagnostic section in the Toyota repair manual, the only two places it would tell you to replace the sensor would be after step 2(i) or after step 3(g). Both of those places you only reach by first confirming that the wiring is OK and that the ECM reads as expected when you substitute a known resistance for the sensor.
    It's curious that you seem to have seen a "Toyota repair manual" that gives ECT, thermostat, then short etc., in that order. Can you say more about where you found that?
  5. Elektroingenieur
    2,515
    3,282
    Three Touring
    It’s true that the electrical connectors are made to be released without a special tool, and Toyota’s publications don’t mention one, but there are connector housing pliers designed to make this job easier. See, for example, the KTC AD101 (page in Japanese), also on page 149 of their English-language catalog (55 MB PDF), or the Muromoto Tekko (“Merry”) HS175C (page in Japanese). I have the latter, sold at a discount by amazon.co.jp.
  6. Timoci tagi
    Timoci tagi New Member
    Fiji
    I have the same code p0117 and once it's overheated my coolant drains out quickly and it's giving different noise whenever I refill i have replaced the coolant temp sensor still my engine overheats when drive for an hour
  7. Brian1954
    Brian1954 Senior Member
    2,131
    825
    South Central PA, USA
    How many miles on the car?
    My guess is a bad engine water pump.
  8. ChapmanF
    18,022
    Replacing the temperature sensor sounds like shooting the messenger in this case.
    BiomedO1 likes this.
  9. BiomedO1
    3,436
    1,790
    SacTown, Ca
    You need to test, rather than aiming a parts cannon at the car!!! An IR temperature gun is cheap!! Validate what's the ECU is seeing, temperature wise. That's how you rule out other possible faults, so your not randomly replacing parts and possibly introducing additional problems into your car from counterfeit parts.
    #9 BiomedO1, Jan 23, 2025
    ASRDogman likes this.
