I find it very tedious to perform a simple adjustment on the sound tune such as bass
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by Humble Bear, Jan 22, 2025.
  1. Humble Bear
    Humble Bear Member
    131
    49
    Arcadia, CA
    2024 Prius
    I find that Toyota has dropped the ball on the basic stuff...I owned the Prius for 3 months and I find it very tedious to perform a simple adjustment on the bass or treble setting especially if you are playing SPOTIFY in carplay. You have to exit out of the carplay and go into the Toyota menus then the settings and on and on...Is there an easier way to do it besides using the voice command?
    Richard CabezaDeBaca likes this.
  2. Paul Gregory
    Paul Gregory Senior Member
    2,216
    586
    Alberta
    2024 Prius Prime
    XSE
    If you like to adjust your bass on the fly, you're out of luck. It seems to be a one-for-all setting.
    I got a nice Sony head unit when my stereo died on my Gen 3.
    soft_r likes this.
  3. Mendel Leisk
    41,824
    The migration to completely unusable controls is relentless. If I’m driving somone else’s car, I don’t even entertain using the “entertainment system”.
    Heat/vent controls, that a couple of decades back could be adjusted easily, without ever taking your eyes off the road, are now a dangerously distracting mess.
    #3 Mendel Leisk, Jan 23, 2025
    dolphinsil and Templeton like this.
  4. Paul Gregory
    2,216
    586
    Alberta
    2024 Prius Prime
    XSE
    I hate the current trend away from giving the customer what they want. The new radio in the Prius seems geared to feeding you what they want. It takes an unreasonable number of steps just to get to the radio station you want to listen to.
  5. Mendel Leisk
    41,824
    Yeah turning a tuning dial is passe. :rolleyes:
    I appreciate it is digital behind the scenes, but I believe it is possible still, to employ a tuning dial that emulates the old school tuner.
    Our 06 civic hybrid, attached:
  6. Humble Bear
    Humble Bear Member
    131
    49
    Arcadia, CA
    2024 Prius
    I hope that they will update the firmware on the display and put those basic stuff that you can immediately access any time on the menu icons such as radio, sound tune settings soon.
  7. PhoS
    PhoS Active Member
    255
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    Doubt it will happen any time soon. You could use an equalizer on your phone , the 3 band eq in the car menus is next to useless.
  8. vvillovv
    vvillovv Senior Member
    4,324
    1,511
    NY
    when the spirit moves us or just sitting in the driveway with the volume up, the tedium is reduced enough to be not that noticeable and the sound comes through load and clear no matter what system is being used. When we get access to true discrete spatial sound systems we'll all wonder what we've been kept in the dark about the real power of sound entering our ears.
  9. Paul Gregory
    2,216
    586
    Alberta
    2024 Prius Prime
    XSE
    My VW gives you several convenient ways to tune a station. Including a full tuning dial on the visual display, and a dedicated tuning knob.
    Nothing like that on my Prius. You can refresh a list of stations in each area, then you can assign them to a limited set or "favorites." There is a way to enter a station manually, but unless you know the exact frequency, it's useless. Very inconvenient.
    I'd be surprised if there were a third party alternative that didn't sacrifice some of the Toyota utilities.
    #9 Paul Gregory, Jun 5, 2025
  10. ETC(SS)
    7,312
    Still Love the F8F avatar!
    NORMALLY I would consider using a service like Crutchfield to replace the 'head unit..."
    However (COMMA!!!!) for YOUR car it might already be too late!
    We grew up in a wonderful time where you could pay some grad school dropout to graft a double-DIN head unit into your car for under a thousand bucks and you'd be all set.....
    My first car didn't even HAVE a radio.....
    Soon and very soon - an infotainment system malfunction may disable the whole car!!!
  11. Mendel Leisk
    41,824
    We replaced an otherwise functional kitchen range, due to failed touch-screen. Next one’s touch-screen also failed, after a few years, I DIY’d replaced. Said replacement was partially defective out of the box, managed to use it, by transferring a portion of the old one over. Supplied photo evidence to seller of the screen, ended up getting it for free.
    ETC(SS) likes this.
  12. ETC(SS)
    7,312
    Same thing happened to me.....
  13. Paul Gregory
    2,216
    586
    Alberta
    2024 Prius Prime
    XSE
    The new paradigm is to find someone on the internet to do the modifications for you.
  14. JimLudden
    JimLudden Member
    89
    36
    Taos, NM
    2024 Prius Prime
    I see this problem as not limited to the radio controls. While Toyota is great at controlling the hardware, the user interfaces are all very limited, including both the paper and electronic versions of the User Guide.
  15. Humble Bear
    Humble Bear Member
    131
    49
    Arcadia, CA
    2024 Prius
    I wish there will be firmware update to address this issue in the near future.
  16. soft_r
    soft_r Active Member
    183
    151
    Beverly Hills
    2024 Prius
    Toyota would never give you guys the simplicity you're looking for.
    Meanwhile, the best option which also improves your listening experience is to add a powered subwoofer (all in one unit that has the internal amplifier exposed to the outside for heat dissipation), have pulling signal from the front feed, not the rear, and then install a gain knob (bass knob) on your dash in the blank panel behind the wiper controls. Set it at about 100hz crossover on the subwoofer's amp.
    otatrant likes this.
  17. Humble Bear
    Humble Bear Member
    131
    49
    Arcadia, CA
    2024 Prius
    There is also another problem with the split screen using Android Auto where the big screen is showing the google map and the small screen is showing the Spotify, you cannot change the Spotify to the radio on the small screen. Please tell me you can...
  18. mingc
    mingc Member
    73
    56
    Portland, OR
    2023 Prius
    XLE AWD-e
    Resurrecting this in case it might help someone. For my 5th gen XLE, I've been able to get to my favorite stations without taking my hands off the steering wheel. I use the Mode button to get to the Radio. Once there I use the arrow buttons above the Mode button to scroll through my favorite stations.
    I always have to scroll past my unused Apple Music and Amazon options before I get to the Radio. Anyone know if and how I can remove them and Sirius?
  19. Paul Gregory
    2,216
    586
    Alberta
    2024 Prius Prime
    XSE
    I find that holding the forward button seeks new stations.
    mingc likes this.
  20. mingc
    mingc Member
    73
    56
    Portland, OR
    2023 Prius
    XLE AWD-e
    I'm not sure why mine opens on the Favourites page from Mode. Perhaps the Favourite page had to be hand selected first before it opens there afterwards. After that the arrow button just scroll through the Favs
