2021 Prius Prime 1k+ miles for sale
Discussion in 'Prime Main Forum (2017-2022)' started by John Hayman, Jan 19, 2025.
  1. John Hayman
    John Hayman New Member
    Massachusetts
    There is a 2021 Prius Prime for sale relatively near me. It has a little over 1000 miles on it. It was leased new from Greentree Toyota in Connecticut. It was serviced at 1000 miles and not driven after that. It was returned to Greentree who is selling it for 25k. From what I’ve read letting an EV sit unused for long periods of time can be very bad for the batteries. Is there any sense in me making an offer on this? Can the battery be tested for capacity and that information shared with me? It has Toyota Gold coverage which covers the battery but I don’t know how the replacement threshold is determined. Pay their price if they replace the battery? Split the difference in the price of replacement? Or just say, “No”, and avoid the 2 1/2 hour ride to the dealer?
    Thanks
  2. pasta4breakfast
    113
    Anaheim, CA
    2020 Prius Prime
    I personally wouldn't buy it unless I drove a lot and/or planned to sell it before 2031. I believe hybrid batteries are meant to be driven. If you drive an average amount, it would probably be a better value to buy one with 40,000-60,000 miles on it, as long as it has been serviced without evidence of an accident and is in good shape. I just went on Car Gurus and it looks like you can get a 2021 Prius Prime LE with 44K miles for 23K in Framingham, MA. However, Toyota warranties the battery for 10 years, 150,000 miles. I believe it is transferable. Thus, if you drive a lot, the vehicle you mentioned starts to make sense. For example, if you drive more than 24,000 miles a year and want a 2021 Prius Prime, you would need one with 0-6,000 miles on it to get the full 10 years out of the warranty. The battery should last more than 10 years, but if you are one of the unlucky ones and the battery dies when it is 8-10 years old it will be nice for it to still be under 150,000 miles. I don't know anything about "gold coverage," so that may change things. I wouldn't drive out there without knowing if the gold coverage increases the 10 year/150,000 mile warranty on the battery. I think time wears these batteries more than miles, except for some extreme examples, like taxis.
  3. BiomedO1
    4,002
    2,103
    SacTown, Ca
    You effectively have a 6 year, 149K mile warranty on the EV system. If MA is a CARB state, other CARB state warranties also applies.
    The issue here is, was the traction battery kept at 100% charge the entire time it was dormant? That would not be good, but you can fall back on the long traction battery warranty. I would clarify the traction battery warranty and proceed with caution. Negotiate the price down further - if your able to put 149K additional miles on that car within 6 years - I'd say that's a pretty good gamble. You've only got a year and 59K miles left on the power-train warranty, possibly less it the car was first sold in late 2020.
    Hope this helps.....
  4. Washingtonian
    Washingtonian Senior Member
    726
    621
    It is important to know what model it is. Not sure of 2021 prices, but current prices are $28K for LE, $31.3K for XLE and $35K for Limited. That is a seven thousand difference between models.
    Ray
  5. Mendel Leisk
    41,814
    Check the hybrid battery with Dr Prius app? You’ll need to plug a Bluetooth dongle into the OBD port: Carista works.
    A test drive for sure too.
    FWIW: our “new” 2010 purchase had apparently been in storage for 15 months, all dusty, ~10 km on odometer, and a stone-dead 12 volt battery, which dealership tried to mask (made new 12 volt a sale condition).
    It’s been fine ever since, hybrid battery giving no problems. But that’s a much shorter hiatus than your case.
    #5 Mendel Leisk, Jan 24, 2025
  6. bisco
    52,274
    lithium stores pretty well, if it is around 30% charged
