2014 Prius 3 45K maintenance
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by AliceLB, Jan 24, 2025.
  1. AliceLB
    AliceLB New Member
    Los Angeles
    I have a 10.5 year old 2014 Prius 3 with 45K miles. I'm the original owner, I live in Southern California, and the car has been garaged most of the time, and nowhere near the recent wildfires. Given the low mileage, I call it "the car that's afraid to leave the garage". :)
    I confess that due to 24x7 caregiving responsibilities for my folks, I haven't taken the Prius for maintenance in the past 3 years, in which I've driven it less than 3K miles.
    In addition to the standard multi-point check, engine oil & oil filter change, and tire rotation, the dealer indicated that they'll (a) inspect & potentially replace the cabin air filter and engine air filter, (b) flush the brake fluid, and (c) replace the coolant.
    Given that the car is mostly garaged, has 45K miles, and is not operated under the special conditions listed in the maintenance guide, are the brake fluid flush and coolant replacement required?
    What about changing the transmission fluid?
    I don't see brake fluid flush or transmission fluid replacement listed in the maintenance guide.
    The dealer also mentioned checking the tires for dry rot. Is that a concern given that the car has been mostly garaged?
    I'm trying to figure out what actually needs to be done at the upcoming service appointment to keep my Prius running well for many more years.
    Thank in advance for your recommendations.
    #1 AliceLB, Jan 24, 2025
  2. Mendel Leisk
    40,580
    That'd be good to do, at least once, sooner than later. You're right that Toyota USA (and Toyota Canada) say nothing about transaxle fluid change. Be forewarned: dealerships have been known to quote very high prices, for what is a very simple process, on par but somewhat different than and oil/filter change. It should not cost more than $100 USD, through dealership service department. If you resort to a 3rd party mechanic, ensure they use Toyota ATF WS. Four quarts will be more than sufficient (it'll take about 3.5). Any left should be recycled, not saved for later use: according to Toyota only freshly opened bottles should be used. Relevant repair manual excerpt is attached.
    Toyota USA says nothing about brake fluid change either (worth saying "change", flush has different meaning). On the other hand, Toyota Canada now recommends tri-yearly or every 48k kms (~30k miles), whichever comes first. It should not cost more than $150 USD, through dealership service department. Relevant repair manual excerpt is attached.
    Maybe. Assuming they're original, that aged-out tires, by any standard. I went well over 10 years on our stock tires, but that's pushing it.
    Toyota USA's recommendation for first engine coolant change is 100k miles or 10 years, whichever comes first. For the inverter coolant it's 150k miles or 15 years. For what it's worth, Toyota Canada recommends to change both at the first interval.
    Worth notiing: all of the Toyota USA maintenance recommendations are laid out, in the Warranty and Maintenance Booklet, a slim volume that comes with the Owner's Manual, usually in the glove box. If Either book is missing, pdf versions are available for download from Toyota Tech Info, in the "Manuals" section.
    That said, the format used by Toyota USA is event-by-event, making it nigh impossible to see frequencies, patterns. There's also a few breaks in the patterns, likely typos, very hard to spot unless you've converted it to table format. Which I've done, see attached.
    Having a long-term stored car, you likely need to bend the rules some, take their advice. But don't let them snow you. That multi-point inspection for example, is mostly nonsense, there no mention of it by Toyota, and I'd wager dealership would get evasive if you ask what it entails.
    One more thing: 3rd gen has a newly implemented Exhaust Gas Recirculation system (EGR) that has proven reliably prone to clog up with carbon, defeating it’s function, and (arguably) leads to blown head gaskets. Ideally it should be cleaned, every 50k miles at most (my recommendation only).
    Dealership service departments are the last place to get this done: they will only replace parts, which are about a grand USD, and theres multiple hour labour charge on top of that. In LA I'd contact Hybrid Pit Stop about EGR cleaning; they’re good at it.
    #2 Mendel Leisk, Jan 24, 2025
    MAX2 and BiomedO1 like this.
  3. BiomedO1
    2,816
    1,498
    SacTown, Ca
    I agree with most of what @Mendel Leisk said
    ATF change should be done to extend the life of the car. If money is tight you can forgo this and $150 would be a fair price. The Toyota ATF WS fluid cost has almost doubled between the changes I've done on my old 2012 Prius C and my new 2021 Prime.
    Brake system flush; brake fluid can be tested to see if it still meets specs. I'm pretty sure it still does. I flush out my brake system every 5 years, but I do it and it only cost me some time and <$5 of DOT3. In your shoes, I'd have it tested before making that decision.
    Air and cabin filters, I'd say NO to that. Filters are cheap on Ebay and amazon with plenty of Youtube videos on how to do it. 5-10 minute job, maybe 15 minutes for your first time.
    Coolant change for your So Cal whether - definitely NOT. I'd probably wait for the 15 year inverter interval and get them both done at once. Again, if I was in your shoes.
    Tires; wait for a sunny day and pull the car out of the garage. Inspect the tire's sidewalls for cracks and blistering. If none your good to go. If you leave the car out in the elements, put some tire shine on it to protect the tires from UV rays.
    Toyota recommends a minimum of annual oil changes, even if you don't hit the minimum mileage interval - but your outside Toyota warranty period, so you can do whatever you want. My personnel opinion, if the oil isn't turning dark brown - I'd wait until the next mileage service interval. I have a camping/fishing rig that only sees <4000 miles in 2 years. I think the last oil change I did on it was 3 years ago. This rig has an oil depletion sensor in it and it's currently at 25% till needed change. When that rig was produced, only dino oil is specified and that's what the sensor is calibrated for. I use full synthetic oil, so I've got a reasonable amount of safety built in.
    Hope this helps....
    On another subject, your 12V battery. If your doing a lot of short hops in that car - 5-10 minutes errands. You may be slowly depleting your 12V battery - not enough road time to recharge. You may want to look into a smart trickle charger or RV battery charger to keep your 12V battery happy and prevent an early demise.
    #3 BiomedO1, Jan 24, 2025
  4. bisco
    51,148
    if money is an issue, i would do the engine coolant change, because it may corrode the head gasket.
    and that's about it
    Grit likes this.
  5. BiomedO1
    2,816
    1,498
    SacTown, Ca
    The only reason I stated to push out the coolant change is because of their temperate climate in LA.
    If your on the fence about it, coolant can be tested - PH and glycol levels. Using a PH test strip and a $2 glycol concentration indicator. I'm pretty sure it's well within range.
    Hope this clarify things.....
  6. frodoz737
    frodoz737 Top Wrench
    4,535
    2,438
    33
    The vehicle is over 10 years old. All fluids and filters should be changed.
  7. Grit
    Grit Senior Member
    6,450
    4,186
    Wilkes Land
    Mendel bisco And frodoz are correct, fluid have a lifespan even if car is not operated. Mine has 240,000 miles and practice the 3 fellas’ mantras mentioned earlier.
  8. AliceLB
    AliceLB New Member
    Los Angeles
    Thank you so much for your guidance and recommendations, @Mendel Leisk, @BiomedO1, @bisco, @frodoz737, and @Grit.
    I have updates plus questions about trickle charging and hybrid battery maintenance, please:
    @Mendel Leisk - The files you attached are super helpful, thank you. Totally love your spreadsheet for the recommended maintenance schedule!
    I had my car's oil + oil filter and brake fluid replaced. Checked tires, and they look great. I scheduled replacing the remaining fluids (coolants + transaxle) for next week. Decided to do all the fluid changes now and not think about it for a few years (other than oil changes).
    @BiomedO1 - I changed the two air filters on my own. Thanks for the recommendation to do this on my own. It was as straightforward as you indicated!
    Also, I replaced the 12V battery a few years back, because it depleted exactly as you described. I recently purchased a trickle charger with a ring terminal plug so that I can leave that part permanently attached and easily connect it to the trickle charger as needed. Here's what I purchased:
    Will having such a plug permanently connected to the battery (instead of using the clamps each time) cause any issues?
    I stopped by Hybrid Pit Stop since I was running an errand nearby. Greg, their main tech guy, suggested I could possibly wait a few months before doing the EGR cleaning. I'm still planning on doing it now, since the car is 10.5 years old and I want to have all the major maintenance completed so that I'm not thinking about it for the next few years.
    He also suggested doing maintenance on the hybrid battery, which includes fan cleaning, cell rebalancing, and bus bars cleaning / replacement.
    Is the hybrid battery maintenance something you'd recommend as well?
    Thanks again for all your guidance. I'm super grateful.
  9. bisco
    51,148
    honestly, egr maintenance is premature and likely expensive. it is miles only, and not age.
    the battery maintenance could be of value, depending on the cost, and what they find when testing and checking. it could also be a huge waste of money.
    attaching prices the the maintenance items would help.
    unfortunately, i can't see the plug, but a permanent connection to the 12v with a quick connect for the maintainer above the hatch is ideal, or you can use the jump point under the hood.
    Brian1954 likes this.
  10. Mendel Leisk
    40,580
    Said the man whose head gasket failed at what, 87k? ;)
  11. Grit
    Grit Senior Member
    6,450
    4,186
    Wilkes Land
    HAHA!!!...
  12. bisco
    51,148
    I sit corrected, but do you think it’s worth around $1,000. at 45k?
  13. Mendel Leisk
    40,580
    Didn't you see the clause when you bought your third gen, "owner must be prepared to DIY clean the *#%! EGR every 50k miles, or blown head gasket, whichever comes first"?
    I concur though: if you roll into the dealership and ask them to remedy the EGR, they don't stoop to cleaning, so you're looking at a grand of parts, before they start adding the labour. Hybrid Pit Stop (LA) and Tampa Hybrids, witl do a cleaning for $600~800 USD.d There are others too.
    And there's guys like @Raytheeagle, @Grit organizing EGR cleaning "parties", and @jerrymildred, worked part time at Tampa Hybrids, and helped some guy out, basically did the job while the guy helped and learned. @NutzAboutBolts videos are a godsend too.
    Second time around, I found this took "about a weekend", putting in about 6 hours on a Saturday, and a couple of hours wrapping up on Sunday.
    For anyone getting this done professionally, save the receipts (always a good idea), just in case some lawyers get ambitious, try for a class action.
    #13 Mendel Leisk, Feb 1, 2025
  14. AliceLB
    AliceLB New Member
    Los Angeles
    Thank you @Mendel Leisk and @bisco for the additional follow-up.
    The costs are as follows:
    Battery maintenance: $400
    EGR cleaning (including engine coolant replacement and fuel injector cleaning): $700
    I saw a post on this forum (https://priuschat.com/threads/egr-cleaning-at-hybrid-pit.232233) that led to another question:
    The posted mentioned that when they took their Prius into Hybrid Pit Stop for EGR cleaning, they were shown the clean EGR parts from ANOTHER Prius that would be installed in their Prius.
    Is this expected? I assumed that the EGR components from my Prius would be cleaned and installed back into my Prius.
    (I reached out to Hybrid Pit Stop towards the end of last week about this, but haven't heard back yet.)
    Not sure why the link to the trickle charger didn't come through in my post above; sorry about that.
    Here's a photo of the trickle charger with the "permanently connected" plug:
