2005 Prius, Gen 2, code P0A09, Hazard and car symbol with exclamation point
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MaryCarol, Jan 23, 2025.
  1. MaryCarol
    MaryCarol Junior Member
    Palo Alto, CA
    Hi there,
    Y’all have been so helpful in the past- and online searching hasn’t helped this time- so wondering if anyone has advice here…
    My car sat for 3 months while I was away and the 12 volt appeared to have died and was not charging well (bad battery according to neighbors trickle charger) so I got a new 12 volt today - the previous was under warranty and only a year old.
    After the installation, I saw the Hazard with exclamation point on the dash and then the car symbol with exclamation point on the screen. Which indicates a big problem.
    The man at autozone said the code was
    P0A09 and he suggested I drive the 2 miles home and then try to drive 50 miles in the next few days and see if that clears things out. However if something is seriously wrong, I don’t want to drive it or hurt it. And when I searched the code online, I found something about a hybrid DC converter failure. I’m hoping the hybrid battery (expensive) isn’t the problem bc the car itself is only worth about $4K at this point.
    The car is 20 years old, I am second owner and have had it 10 years exactly and it has just under 110K miles. Which I know is shockingly low. It will be due for an oil change and check up in about 300 miles, but since it was sitting for a few months, my next move may be to take it for an oil change and check up at a local place 2 miles away. (I did pump up the tires already, just to state the obvious).
    The big question- is this the hybrid battery and a super expensive repair I’m looking at?
  2. Tombukt2
    12,947
    2,322
    The car's not even broken in good yet but it's at the point year-wise like 20 years old almost where the brake actuator and things are going to start to fail but if you think those things are going to equal a new car better think again in this market even buying a new or refurbed hybrid battery handling the break actuator when it happens and the myriad of other little things that can go wrong you are still way ahead of a I don't even know what $15,000 something another and a payment easily especially if you can do anything yourself this is a pretty easy car to work on as far as taking things off and putting them back on with some basic hand tool seriously You don't need anything special for the most part to work on this car except for a reasonable scan tool if you're going to tackle the brake work and now you can do something with that for like $70 If you think this is costly well you haven't worked on much stuff or anything like that I guess doesn't get much cheaper.
  3. Tombukt2
    12,947
    2,322
    The code you have right now is about the circuit that charges your 12 volt battery which runs all of your car except for the electric motors in the transmission and your air conditioning that's high voltage. So your car's inverter apparently isn't charging the 12 volt so now you're running the brand new 12 volt into the ground what you going to want to do here generally is just replace your inverter what's broken is on the bottom of your existing inverter which apparently is working fine The DC to DC converter that charges the 12 volt that circuit has gone bad. Generally it's a pain in the rear end change it it's easier to change the inverter complete they're plentiful they're everywhere junk yards are throwing them away so just grab an inverter from a tow lot LKQ a junkyard anywhere you can get one relatively cheap say let's say $100 or less something like that like I say they can't get rid of these things so happy to take a hundred bucks. Plug that up screw it down and start the car up and check the 12 volt with the car in the ready mode it should show about 13.4 to 14.5 volts with the ready light on and you should be good to go also make sure all of your fuses are good there are some fuses I think that have something to do with charging and all that You want to make sure you don't have any blown fuses they make little doodads to test your fuses right on the car they light up they come in a yellow container made by a company called b u s s and good luck.
  4. MaryCarol
    Palo Alto, CA
    Tombukt2 - thank you so much! This is super helpful!
    I am having a mobile mechanic (who put the battery in for me at Autozone a couple days ago) come over tomorrow to check the fuses.
    If the fuses are the problem that will be the first thing I fix. I am sorry the new battery is sitting the way it is for a few days, but the earliest the guy was available to come over was Saturday (and my battery was installed Wednesday).
    But I searched local junkyards and one near me has a few inverters showing available online (you purchase online but then go get it in person) for $100-150. The ones near me do not have a 2005 inverter- does it need to be a Gen II (2004-2008) or can it be any year?
    And does mileage matter for buying an inverter? I was just curious.
    THANK YOU SO MUCH!
    I watched a whole YouTube video twice last night about replacing inverters- just in case...!
  5. Tombukt2
    12,947
    2,322
    You would ideally would want to get an '06 to '09 inverter I do believe as that should be the updated part It's the same as 04 and '05 just an updated few pieces inside of it If I'm not mistaken me personally I would probably try to grab one off of an '09 l8 08 something like that. That way there you're getting the last of the inverters with the updates You don't want to take an old inverter like you have a part and do the update to the DC to DC converter it's just a big mess there's too many of these things out there for near free if you were closer to me you could just come by and pick one up and have it because there's nothing anybody can do with it it's going to the trash or on a car which are all now 20 some odd years old and quickly falling by the wayside so there's no market in other words so offer the guy 75 bucks who wants a hundred that's that simple pretty much He's going to throw it away for free.
  6. MaryCarol
    Palo Alto, CA
    Thanks Tombukt2!
    The mechanic came over yesterday afternoon and checked the fuses- they were all good. So I was expecting to be buying an inverter, but I asked him if we should double check the battery and see if the error code came up again- because I had disconnected the 12V battery (that he had just installed a few days prior)... and he thought he would check to see if the battery was getting charge. So we reconnected it and suddenly there was no triangle/hazard light with exclamation point or car icon with exclamation point coming up.
    I have replaced the 12v several times before- and he himself had replaced a Prius 12V a few days prior and neither of us had seen those symbols come up.
    We reasoned that they may have initially come up when we put the new 12V in a few days ago because the night before, a neighbor tried to help me bring my battery back to life with a trickle charger - while the battery was still in the car. (Meaning, we didn't take the 12 v out of the car and charge it outside the vehicle- so that 12v was still connected to the hybrid battery while we tried to charge it.)
    Regardless, for the moment, it seems like the car is ok- but if I need to get a component, I found the junkyard near me that has 16 locations nation wide and seem to be able to get me parts I might need.
    Thanks so much for helping me learn and work to "do it myself"! Truly appreciate it!
  7. dolj
    dolj Senior Member
    8,439
    4,288
    Wellington, New Zealand
    This reasoning is not sound and any conclusions you draw from it are invalid. I'd be very suspicious of any 'professional' who spun such BS.
    There is no problem charging the battery in-car and the 12 V is not 'connected' to the hybrid vehicle (HV) battery when the car is off. Even with the car on, the 12 V is not (directly) connected to the HV battery. The only issue with what your neighbor did is if he truly used a trickle charger, rather than a proper 4 to 10 Amp smart charger, is that the trickle charge may not have had enough oomph to make much of a difference in the 12 V battery's state of charge or in any case the 12 V was simply past its use-by date.
