Prius dies after changing spark plugs
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Daniel Hanchett, Apr 24, 2022.
  1. mech1222
    mech1222 Junior Member
    32
    usa
    or techstream with mini vci on windows 7 or 10...the registry update and 64 bit minivci drivers work...
  2. Timttt
    Timttt New Member
    Los angeles
    Did you find out what was wrong. I have identical problem 2008 prius
  3. Timttt
    Timttt New Member
    Los angeles
    Any help would be appreciated
  4. dolj
    dolj Senior Member
    8,430
    4,285
    Wellington, New Zealand
    The only thing that might be "identical" is the symptoms. Unfortunately, there is a myriad of different problems that can produce these same symptoms so your top priority is to get your codes read and report them here.
    Have you read and followed the advice in this thread so far?
