Coolant disappearing and can't find where
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Carsten, Jan 22, 2025.
Tags:
  1. BiomedO1
    3,790
    1,971
    SacTown, Ca
    Move cylinder 1 spark plug to #4 and #1 ignition coil to #3. Clear your codes and see if the problem moves. By doing this, your isolating ignition system fault. If you throw another P0301, you know that the issue is isolated to cylinder #1. That means you have either a mechanical and/or injector failure in #1.
    If the problem moves, then it's whatever part you moved to either #3 or #4 is defective.
    If coolant isn't hitting the ground or leaking onto your front floor mats, see #12 of this thread - those are the only other places they can go. That white smoke out the tailpipe doesn't apply to these new modern engines - they run too lean. You'll see white smoke out of your tailpipe on cold damp mornings, until the condensation burns out of it.
    Hope this helps....
    Prodigyplace likes this.
  2. Mendel Leisk
    41,643
    So did you have coolant loss through the exhaust heat exchanger, and/or was there a diagnostic done, say by dealership? If so, how long was it going on before you did the bypass? Did you try to get the exhaust heat recovery replaced under warranty, but were denied? Or dealership is waiting on "back ordered parts"?
    Trying to fill in the history.
    douglasjre and Prodigyplace like this.
  3. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
    Everything is sad. A piston cleaned of carbon deposits with a coolant leak is a clear indicator of an engine overhaul with a gasket replacement.
  4. Mendel Leisk
    41,643
    If doing boroscope inspection, you can exacerbate coolant leakage past the head gasket, by removing the engine coolant reservoir cap, pushing on a stopper with a through-tube and applying air pressure.
    In the attached pic, I used a T-connection as the "through tube", since that's what I had. The side channel is sealed with 2-part epoxy. The pressure/vacuum valve hose kept kicking the hose off, so I added a bit of bent steel wire to lock it.
    I might try this sometime, with a simple fluid transfer syringe, with a couple of check valves, arranged so it'll hold pressure.
    #24 Mendel Leisk, Jan 29, 2025
  5. rjparker
    10,238
    6,393
    You need a good dual view borescope to actually see the pistons and sometimes the coolant leaking in under prescribed conditions.
    White smoke from a hg leak can be seen at the exhaust when the problem is advanced. Yours could easily be advanced. Requires rev'ing the engine and an observer.
  6. Carsten
    Carsten Junior Member
    60
    Columbia, SC
    The heat exchanger was disconnected before I got the car, almost 2 years ago, nothing about it in carfax. Whoever did the work looped the hard lines under the car with some radiator hose. Twice I found coolant leaking there and this last summer deleted the hard lines.
  7. Carsten
    60
    Columbia, SC
    Thanks, I will try this.
    I'm preparing for doing the head gasket tho, found this video, seems like good instruction
  8. Carsten
    60
    Columbia, SC
    Good video, thanks
    vvillovv likes this.
  9. Carsten
    60
    Columbia, SC
    The code did move to cylinder 4, P0304
    New spark plugs will be easy but the coolant loss remains, it doesn't really seem like it matters at this point whether coolant is going into the cylinder, oil, or exhaust I either need to replace the head gasket or replace the engine
  10. Mendel Leisk
    41,643
    This bodes good for the head gasket.
    What's the miles on it, now, and/or when you got it? It might have been eligible for the exhaust heat recovery component (and catalytic converter, it's all on piece). It may still be. Maybe last owner was stonewalled by dealership when in fact Toyota would have covered it. Or the part was endlessly back-ordered.
  11. bisco
    52,093
    Just replace the engine and be done with it. the rest is a pretty good car
    Carsten and BiomedO1 like this.
  12. BiomedO1
    3,790
    1,971
    SacTown, Ca
    Well; it seems you also have an ignition issue too. I'd nail down the ignition issue now - so your not dealing with multiple problems when you do the head gasket. Otherwise, you won't know if you messed up the head gasket repair and/or introduced another issue.
    There's no telling how long the previous owner drove that car with the leaking EGHE (exhaust gas heat exchanger) and how many times he/she overheated it and how badly. You won't find anything on carfax, because the shop that did the work would be admitting to defeating a smog device. Depending on their jurisdiction, they could lose their license. The head and/or engine could be warped and a new head gasket repair isn't going to last very long. That's probably why the previous owner decided to sell the car, while it was 'running' decently. Get rid of the car before it starts costing them major dollars for repairs. The mechanic that did the bypass probably told them there was potential damage to the engine with the overheating. Sorry
    A good used engine may be a safer path forward.
    Good Luck
    #32 BiomedO1, Jan 29, 2025
  13. Carsten
    60
    Columbia, SC
    Good point about dealing with the ignition issue 1st.
    I've had the same thoughts now about the previous owner, although I have put 22k miles on it since I got it, seems like things would've unraveled sooner
  14. Carsten
    60
    Columbia, SC
    Why do you say this bodes good for the head gasket? I've still got coolant loss.
    135k miles when bought 4/22/23, 158k now
  15. BiomedO1
    3,790
    1,971
    SacTown, Ca
    Possibly; If you've got the time and don't mind doing the work - go for the head gasket repair. If that only last another 10K-20K miles; you'll know you need another engine. It's slightly warped.
    Good Luck....
  16. Carsten
    60
    Columbia, SC
    I'll have to give that some thought, the only part of automotive work I enjoy is when it's done and it works :)
    Thank you for your time.
    vvillovv and Prodigyplace like this.
  17. Carsten
    60
    Columbia, SC
    Just did the combustion leak detector test and there does not appear to be any gases in the coolant
    No change in color
    avidtravellerhkg likes this.
  18. Mendel Leisk
    41,643
    It’s checking for exhaust on coolant.
  19. Carsten
    60
    Columbia, SC
    correct
  20. vvillovv
    vvillovv Senior Member
    4,322
    1,510
    NY
    Might be why the cars leaking coolant. I doubt I'll be able to guess, for at least a year, maybe longer.
    Which bypass did you do? engine bay our U tube at heat exchanger?
