Carpet floor mat repair
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Mendel Leisk, May 25, 2015.
  1. Mendel Leisk
    41,743
    Toyota's OEM carpet floor mat doesn't have a rubber inset on the driver's mat. Ours lasted about 6 months before it was worn right through. I was vacuuming out the interior today, thought I'd try a repair, with some rubber floor mat material I had.
    Cut it to size, then pre-drilled a series of holes around the perimeter. Did the stiching with a Tandy Sewing Awl. It'd been so long since I'd used one, I'd forgotten how they work, had to watch a YouTube video. The waxed thread is very grippy, more-or-less self-tensioning.
    All in all I think it went ok. I'll leave it as is for a while, see how it wears. If there's a next time: I might make it extend a little further back, towards the driver's seat.
  2. Mendel Leisk
    41,743
    Just another thought: when you're doing any kind of extended interior cleaning, with the front doors open, all the unswitchable "convenience" lights are draining the 12 volt battery. Because I had it, I used a C-clamp on the door switch, to turn the lights off, but it's cumbersome, you might bump it, damage something. Something like this might work well, looks more convenient. If you could get one big enough. It needs a bit over 3" grip:
    CR94 likes this.
  3. Former Member 68813
    3,524
    983
    US
    i'm surprised yours was worn in 6 months. mine is OK 4.5 years later. i had a hole in one in corolla after about 7 years of driving (mostly commuting). BTW, thanks for info. i'll save it for future reference.
  4. JayLn
    JayLn Active Member
    248
    141
    Four Touring
    I am impress, if you extend the rubber to the left a little more to make it even but that just me :p over all job well done excellent!
  5. Mendel Leisk
    41,743
    Yes, this was one of my more "fast, cheap and out of control" projects, took at most an hour. I find it often works out, albeit with rough edges. The more time I have to think it over, the more chance to mess it up, lol. But, I guess I focussed on the damage area, let that guide me. A bit more symmetry would be nice, and I think coverage a bit further towards the driver would make it less of a transition, your heel would be on it more.
    Pre-drilling the holes was a good idea I think, made it a lot easier to sew, and maybe the rubber is less likely to tear later.
    The best thing would be to do this pre-emptively, before you've worn a hole clear through. Time will tell, but I think some sort of filler in the hole might be needed, the rubber may concave into it as-is.
  6. CR94
    CR94 Senior Member
    2,727
    1,191
    Northwestern S.C.
    Even if your Prius doesn't have all those lights, and you shut off all the others, you're still draining the battery if you leave a door open for long.
    Similarly, I used a 12" Harbor Freight slide clamp to hold down a rear door switch button; it's too thick to work in front. I might make a gizmo less cumbersome than a C-clamp for the front.
  7. Mendel Leisk
    41,743
    Hmm: if someone could make a variety of rubber mats, various sizes, with rounded corners, stitching holes and a groove between them to recess the thread?
  8. Tideland Prius
    16,586
    The mats are pretty darn thin. Both carpet and all-weather mats have gotten thinner and lighter over the years. A welcome change for the all-weather mats but, perhaps not so for the carpet mats.
  9. Saucey
    Saucey Junior Member
    San Diego
    Seeing this thread just verified to me that I need a metal plate so that my right foot doesn't ruin the mat.
  10. Noriman
    Noriman Junior Member
    Ohio
    @Mendel Leisk, How has this repair held up? Running into a similar problem on my 2015 Prius and trying to decide between performing this repair and purchasing new front floor mats. I’ve repaired leather projects using an awl before.
    Also: when you drilled the pilot holes you mentioned, did you drill only through the rubber layer, or through both layers?
