Pine Hollow "If you don't diagnose the problem and start firing the parts cannon"
Discussion in 'Prius v Main Forum' started by rjparker, Jan 30, 2025.
  1. rjparker
    10,103
    6,267
    New Pine Hollow Gen3 Diagnostic
    "If you don't diagnose the problem and start firing the parts cannon, things can get out of hand pretty quickly"
    Once again Pine Hollow Diagnostics is spot on.
    Place your bets now
    Multiple right answers so there are Win, Place or Show possibilities
    Includes basic diagnostic tests for no start on a gen3 including ignition, compression and fuel. The usual suspects are all here.
    #1 rjparker, Jan 30, 2025
    douglasjre likes this.
  2. Mendel Leisk
    41,347
    Just after 15 minutes he notes no engine rev when he pushes gas pedal. This is normal when it's cold; it's running purelly on battery power, engine just idling till it warms more.
    Reitterates the misconception around 16 minutes: saying he finally got throttle response, due to hybrid battery charging. It's normal behaviour: cold engine just fast-idles, unresponsive to gas pedal, presumbably till a certain coolant temp threshold.
    220k miles, he concludes it'll need a head gasket. Oh yeah...
    So protracted head gasket failure, knock sensor shuts it down, simple fix: shoot the messenger.
    Appended text in red
    #2 Mendel Leisk, Jan 30, 2025
  3. rjparker
    10,103
    6,267
    There were a couple of other factors in the usual suspects lineup.
    "Why is it not starting?"
    #3 rjparker, Jan 30, 2025
  4. ChapmanF
    18,100
    Funny how he says a code telling you the engine is producing less than a fifth of the expected torque is "not useful at all" information....
  5. rjparker
    10,103
    6,267
    He already knows the engine won't run right
    #5 rjparker, Jan 30, 2025
  6. douglasjre
    douglasjre Senior Member
    2,172
    716
    Null, NL
    I Don't have to watch the video to know what the problem is going to be . I'm not going to waste my time watching this video. The real problem is going to surprise you guys
    Without wasting my time watching the video just based upon the above messages, I can pretty much tell The engine was never running in the first place. It was just cranking from mg1. When the cranking stopped, the engine stopped. It's usually a seized fuel pump. Keep trying to start it and you'll deplete the hybrid battery and then you'll have to replace that too as well. This bill is going to get really expensive. Really quick. Lift up the rear seat. Cushioned put your hand on the electric fuel pump and listen to the sound. You'll hear it thump but you won't hear it spin. That'll be the problem. You can prove it with a fuel pressure gauge under hood.
  7. rjparker
    10,103
    6,267
    Not fuel pump. A simpler reason we hear about quite frequently after guys have doing "maintenance".
    The video is a good "how to check systems" on a no start.
    douglasjre and Brian1954 like this.
  8. douglasjre
    2,172
    716
    Null, NL
    In short the, what was it
  9. Brian1954
    Brian1954 Senior Member
    2,167
    843
    South Central PA, USA
    Watch the video, then you will know.
  10. ChapmanF
    18,100
  11. bisco
    51,851
    it's a pop quiz, don't look at your neighbors answers
