Hybrid Battery issues?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by VitoinTn, Feb 7, 2025.
  1. VitoinTn
    VitoinTn Junior Member
    Clarksville, TN
    Just completed replacing the head gasket on daughter's 2013 Prius Hybrid with 178k mi.
    Engine will not turn over, and getting the CHECK HYBRID SYSTEM PULL OVER TO SAFE PLACE message.
    Any ideas of where to start looking?
  2. Brian1954
    Brian1954 Senior Member
    2,668
    1,066
    South Central PA, USA
    Are there any warning lights on the dash?
    Did you scan for trouble codes?
    Did you remove the orange safety plug from the hybrid battery when you worked on the engine?
  3. VitoinTn
    Clarksville, TN
    Point may be moot now. Got the ICE to turn over and run, but smoking around exhaust manifold and the fresh oil and coolant I'd put in appear milky now so I suspect there was a crack in the No 4 cylinder wall to go along with the break in the head gasket between cyls 3 & 4.
    Gonna call it a night as too dark to get good visibility, but thanx for replying.
  4. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    You worked with the engine, the battery is an unlikely cause of failure to start.
    It was enough to disconnect some electrical connector in the engine compartment and the attempt to start would fail.
    Can you describe in detail what happened after pressing the start button?
    Grit likes this.
  5. vvillovv
    vvillovv Senior Member
    4,336
    1,518
    NY
    Did you complete all three steps when putting the Orange Safety Plug back into the Hybrid Battery?
    You'd be surprised at how many owners forget the last step of pushing the lock down.
    Insert the plug
    flip the locking lever back
    push the locking lever down
    Brian1954 likes this.
  6. bisco
    52,807
    Hybrid system is not necessarily the battery, you need a Prius aware scanner to read the codes
    Grit and Brian1954 like this.
