... F-ound O-n R-oad D-ead ~
Discussion in 'Fred's House of Pancakes' started by asjoseph, Jan 1, 2025.
  1. asjoseph
    asjoseph Samuel, '04 Ruthiemobile
    97
    34
    117
    lancaster, california
  2. mikefocke
    3,992
    1,801
    Sanford, NC
    A defect in the assembly of the suspension. Not associated with the design being electric. Could happen on any assembly line to any manufacturer with any engine design. Worker or tool failure, not a design flaw.
    So get facts before you post your anti-EV provocations.
  3. bisco
    51,895
    don't let the facts get in the way of a good story
  4. Mr.Vanvandenburg
    1,352
    571
    2020 Prius Prime
    Says the man from California with a 20 year old Prius. Greta would be proud.
  5. rjparker
    10,133
    6,296
    “Owners will be notified by mail and instructed to take their vehicle to a Ford or Lincoln dealer to inspect the torque of the left and right upper control arm ball joint nut,” the recall stated. “If the torque inspection passes, dealers will replace the nut. If the torque inspection fails, dealers will replace the knuckle and nut.
    “There will be no charge for this service.
  6. Paul Gregory
    Paul Gregory Senior Member
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    I think every carmaker has its lemons. I've never seen one surpass the others.
    My dad hated Fords, not for quality issues, but it was because when he was a kid, the family Car was a Model T, and he always wanted a Chev, because the Model T was underpowered by that time in the 1930s, and he was embarrassed by it.
  7. ETC(SS)
    7,139
    There's a difference between a manufacturer defect and an engineering flaw.
    -just sayin'
    An OEM cannot help but admit that maybe they should spend a few more bucks in Q/A when they're forced to employ union labor - when cars and trucks start failing in service.
    HOWEVER (comma!!!!)
    INTEGRIDY is quickly demonstrated when an OBVIOUS engineering failure is demonstrated 'in the field.'
    -lookin' at YOU.....Toyota!
  8. asjoseph
    97
    34
    117
  9. bisco
    51,895
    But they make it up in quantity ha-ha
  10. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    It seems to be a game that auto executives play. They reduce the quality to see how much they can get away with, it looks like.
  11. Trollbait
    12,520
    Same accounting trick that said Toyota lost money on the Prius, GM on the Volt, and Tesla on everything.:rolleyes:
  12. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    There's probably a bit of sabotaging in there too, to undermine potential corporate rivals.
  13. ETC(SS)
    7,139
    Just like the USPS.....
  14. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    I was once friends with the daughter of a design engineer who worked for GM. If you think his job was as straightforward as designing reliable components, that was rarely the case. Internal politics and planned obsolescence were always present, but never provable. That's why they existed.
  15. ETC(SS)
    7,139
    Planned obsolescence is a thing!!!
    I'm reminded of this every time I try to expand the memory in my iphone.....
  16. Prius Maximus
    Prius Maximus Senior Member
    955
    810
    Northeastern IL
    F-ix O-r R-epair D-aily
    But you can't, they engineered repairs out of existence. Throw it away and buy a new one.
  17. bisco
    51,895
    Invented by elong mucks and Tesla
  18. Trollbait
    12,520
    That might actually be John Deere
  19. Prius Maximus
    955
    810
    Northeastern IL
    Yes. My F-I-L left me a JD D160 garden tractor. It runs like a deer. For 5 minutes. Then it runs like a Deere. Meaning it won't even go up a slight incline. The hydrostatic trans bogs down. Many online complaints and Deere won't stand behind it. A new trans aint worth it.
  20. Trollbait
    12,520
    I was referring to how their licensing prevents people from fixing their owned equipment.
    Prius Maximus likes this.
