Turn signals
Discussion in 'Prime Main Forum (2017-2022)' started by Nick r24, Feb 9, 2025.
  1. Nick r24
    Nick r24 Junior Member
    North bay
    2022 Prius Prime
    Upgrade
    Hello, I have a 2022 prius prime and I can't find anything on how to change the front turn signals bulbs. Does anyone know how?
  2. Tideland Prius
    16,505
    They’re LEDs and cannot be individually replaced.
  3. Nick r24
    North bay
    2022 Prius Prime
    Upgrade
    Do you know how to access the unit?
  4. Mendel Leisk
    41,008
    This is on the (2017~2022) Prius Prime only? Looking at the Owner's Manuals, regular 4th gen and corresponding Prime, this appears to be the case: regular 4th gen shows peanut bulb replacement.
    Accordingly, for the Prime, full headlight replacement is the only option? The LED's supposedly are more reliable, but apparently not for OP.
    Just on the principal that troubling trends tend to continue, I'd assume 5th gen has LED turn signals integrated into headlight housing as well, lol?
    Off-topic, but I hate front turn signals integrated into headlight housing, think they should be outlawed: with most applications, good luck seeing them on car across the intersection, when your pupils are constricted by bright headlights. He may or may not be turning left, I can't blinking tell.
    #4 Mendel Leisk, Feb 10, 2025
    AVTrainz and bisco like this.
  5. AVTrainz
    AVTrainz Member
    123
    61
    California, USA
    The issue of not being able to replace individual LEDs in a light assembly goes back to the Gen 2 brake lights. Of course, I have only seen a few Gen 2s with burned out LEDs. Hopefully the OPs issue is uncommon considering how much newer the bulbs are.
  6. Nick r24
    North bay
    2022 Prius Prime
    Upgrade
    I have a 2022 prime.
    AVTrainz likes this.
  7. Nick r24
    North bay
    2022 Prius Prime
    Upgrade
    Just from looking at the front of the car, the bumper is in 3 parts. Left and right fir the turn signals and the middle. Looks like y9u can just take off the one side. Is this complicated?
    I can't find one video online someone taking it off.
