2011 Prius won't start
Discussion in 'Gen 3 Prius Main Forum' started by Caitlin McDonnell, Feb 9, 2025.
  1. Caitlin McDonnell
    Caitlin McDonnell Junior Member
    34
    Brooklyn
    Two Eco
    Triple A jump started it but when he unplugged his battery it kept turning off. He says he thinks this means it's the alternator. Does this sound correct? I guess I have it towed to a mechanic? Can someone tell me about how much $ I'm looking at?
    Thanks.
  2. PriusCamper
    PriusCamper Senior Member
    12,712
    5,137
    Pacific Northwest, USA
    There's no alternator in a Prius, the hybrid motor and battery pack acts in place of the alternator.
    The most likely problem you have is your 12v battery is no longer holding a charge and needs to be replaced.
    Brian1954 likes this.
  3. rjparker
    10,103
    6,267
    $200 if you replace it yourself
  4. Mendel Leisk
    41,347
    Do you have a digital multi-meter? Not optimum, but checking the battery's voltage will give you some idea where it's at. More than 12.5 (volts) is ok, more than 12.7 is in-the-pink, 12.0~12.5 it's time to start shopping, less than 12.0 you'll need alternate transportation to get the battery.
    All that said, it's likely replacement time.
  5. Brian1954
    Brian1954 Senior Member
    2,167
    843
    South Central PA, USA
    Your Prius does not have an alternator. If the car was in "ready," and the car was running and then turned off after disconnecting the jump starter, this may indicate a problem with the DC/DC converter which is located inside the inverter assembly. FYI, there is a 20-year extended warranty with certain problems with the inverter. To qualify for the warranty, you need to have certain trouble codes.
    How old is your 12v battery?
    Are there any warning lights on the dash?
  6. Caitlin McDonnell
    34
    Brooklyn
    Two Eco
    I'm sorry are you talking about the reg battery or the hybrid battery? I don't really know the language for it, but I know that it's a big deal if I need to replace my hybrid battery.
  7. Mendel Leisk
    41,347
    The regular battery, aka 12 volt battery.
    This is what I'd be looking at, in CDN funds, from nearby Canadian Tire:
    There's a $20 "core charge" tacked on, which you recoup when you bring them your old battery. This is something you "can" do in a store parking lot, in a pinch:
    ^ That's a 10mm box wrench he's using, for the battery clamps. It could also work for the bracket bolts. I'd bring a few washers too, just in case the replacement battery is slightly taller, to shim the finicky bracket.
    ^ One caution: you always want to cognizant, that electrons are always ready ready to make a jump from one battery post to the other (I'll never remember which direction), and if for example you were using an extra long wrench, that could provide the bridge. You maybe shoult keep any wrench handle closer to vertical, avoid any chance of providing that bridge. Another good trick is to wear safety glasses.
    #7 Mendel Leisk, Feb 9, 2025
    MAX2 likes this.
  8. omuomu
    omuomu Junior Member
    34
    I just went over to my local Batteries+ and they switched it out right there in the parking lot for 235 with tax and it was all good from there. So that or an equivalent store and you should be OK. Mine still had the original battery from 2012 in it, and this was in 2023.
  9. PriusCamper
    12,712
    5,137
    That's a great price... Can you please tell us what specifc brand and model of battery they sold you?
    omuomu likes this.
  10. omuomu
    34
    Absolutely! I kept the receipt:
    "Duracell Ultra Platinum AGM 325CCA BCI Group S46B24R Car and Truck Battery"
    It was 219.99 back then, and the guy changed it out in minutes, no problem. Which I could find someone to do that with my engine!
  11. Brian1954
    2,167
    843
    The correct size AGM battery at Walmart is only $180 +tax.
    omuomu likes this.
  12. bisco
    51,851
    Batteries + should be Duracell with unconditional 4 year warranty
  13. PriusCamper
    12,712
    5,137
