Featured Death to EV bills
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Feb 13, 2025.
  1. Prodigyplace
    12,626
    11,808
    Central Virginia
    Virginia currently had a Democrat government with a Republican governor. Those fees happened when we had a Democrat governor too.
    52,283
    Cow towing to industry? Voters? Republicans? Lobbyists?
    We should pay our fair share imo, but it should be all vehicles based on miles and mileage
    Trollbait and Zythryn like this.
  3. Prodigyplace
    12,626
    11,808
    Central Virginia
    So. encouraging you to drive a polluting clunker :(
    Danno5060 likes this.
  4. Isaac Zachary
    Isaac Zachary Senior Member
    2,653
    1,367
    What about weight? 1,000 miles in a 1972 VW Beetle isn't going to cause near as much road wear as a 1,000 miles in a 60,000 GVWR dump truck.
    Are we raising funds for road repair or trying to incentivize or disincentivize certain factors like pollution and/or safety or are we trying to do both?
    The problem with politics is even if a good idea gets in there, the next administration will just give the executive order to remove it, kind of like when Ronald Regan removed the solar panels from off the White House (IIRC).
  5. bisco
    52,283
    In a way I suppose, but it’s just different philosophies.
    We aren’t going to change the world, but I like to do my part.
    Much worse than that is the 40 cents per kWh we pay around here
  6. bisco
    52,283
    Yes, weight should be included in the equation
    Zythryn and Prodigyplace like this.
  7. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    Agreed, as long as it is tied to how much damage the weight does to the road.
    For example, on an interstate a 1500lb car does virtually the same damage as a 3000lb vehicle. So don’t charge the 3000lb car twice as much.
    Trollbait likes this.
  8. hill
    8,896
    Those very large Vehicles already pay large amounts of Road tax. The rationale for our personal gassers is - if you have a heavy & large vehicle it will use more gas. Not so with an EV until someone figures a way to make you pay at the charging socket.
    Isaac Zachary likes this.
  9. bwilson4web
    16,330
    Some of us remember Los Angeles:
    Also Denver:
    Also Washington DC:
    Danno5060 and Isaac Zachary like this.
  10. El Dobro
    El Dobro A Member
    7,088
    3,270
    We were notified that electric is going up around here, effective June 1st. LED bulbs and power strips help a little bit.
  11. Isaac Zachary
    2,653
    1,367
    What helps me is I never use electric heat (unless a blanket) nor do I use A/C. No electric stove, no electric hot water heater, etc. Natural gas is much cheaper.
  12. hill
    8,896
    Electric stoves Or Electric Appliance cost to run turns on the cost of your natural gas/propane - versus electricity. The cost to purchase electricity in some areas is a bargain still - even compared to Natural Gas. But yea that's not the general rule.
  13. Isaac Zachary
    2,653
    1,367
    Installing a heat pump heating unit might make electricity more feasible. Here electricity is cheap compared to some places. It's around 11 cents per kWh. But natural gas here is even cheaper. I don't spend more than some $60 per month on each, so less than $120 per month for heating and cooking.
    Prodigyplace likes this.
  14. Trollbait
    12,653
    Cowards really need to increase the federal gas tax. Hasn't changed from 18.4 cents since 1993. It's effectively 8 cents today.
    I think it was an EV owner that sponsored the bill in Pennsyslvania.
    Thing is, plug ins were never fuel tax free here. They were to pay a rate on kWh equivalent to the gallon rate on gasoline. Sounded like the system to do was clunky, but the main problem was that it depended on the honor system. Would be surprised to hear a plurality even knew they were suppose to be paying.
    The real shame is the DOT suggested going to a per mile system, but the politicians nixed that.
  15. Prodigyplace
    12,626
    11,808
    Central Virginia
    our optional per mile system uses a third party and you need to send an odometer screenshot once a year to true up their monthly snooping err billing.The state DMV already has annual odometer readings from the mandatory vehicle inspection.
  16. hill
    8,896
    If it's any consolation, California (where the lion's share of drivers are filling up) has nearly 70¢/ gallon on top of the federal tax.
  17. bisco
    52,283
    We’re getting hammered from all sides
    Massachusetts residents fuming over skyrocketing gas bills
  18. Prodigyplace
    12,626
    11,808
    Central Virginia
  19. bisco
    52,283
  20. hill
    8,896
    Sister moved herself to PA along with our mom. They have free natural gas in giving up their underground rights to drillers. Ironically the state has some of the highest Natural Gas prices. Sister & mom getting it for free, because iow, everyone else is paying for their privileges.
