Coolant leak.. can't find the culprit. Please help!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by djimbuser, Feb 11, 2025.
  1. pasadena_commut
    pasadena_commut Senior Member
    2,456
    735
    Southern California
    The endoscopes all (AFAIK) have built in LEDs for illumination. Most of the places they are poked into are dark.
  2. Hayslayer
    Hayslayer Member
    325
    177
    I didn't suggest the paper towel trick just because I wanted to make up some BS for you to try. It doesn't get much cheaper or easier than a roll of paper towels. Probably done it 3 or 4 times over the years on various cars, over various lengths of time to track down small problems. There's no need to make things complicated.
  3. djimbuser
    djimbuser Member
    73
    26
    Henderson, Nevada
    I had a similar idea to wrap each hose end with a little strip of shop towel and secure with string or something... each hose individually wrapped. After a good drive get in there to see which one is wet if any. However it's so tight in there I'd be afraid the paper towel trick would be a fair amount of effort with inconclusive results.
  4. pasadena_commut
    2,456
    735
    Southern California
    Also the OP said that coolant is landing on spinning hardware and being flung all over the place. So "wet towel here" may not be particularly helpful when "all towels are wet".
  5. Hayslayer
    Hayslayer Member
    325
    177
    The goal of packing a bunch of paper towels into that area is so the coolant is absorbed before it can even drip. No drip=no flung=easy to find leak when all you have to do is look for the uppermost wet spot.
  6. djimbuser
    djimbuser Member
    73
    26
    Henderson, Nevada
    I'm pretty sure the large hose was the culprit. You know when you slide back the clamp the hose is still supposed to be bonded to the pipe not just slide right off with ease. I cleaned it up and swabbed a coat of gasket sealant inside the hose and put it back on. I'm also going to order a new hose.
  7. BiomedO1
    3,125
    1,658
    SacTown, Ca
    Just a suggestion, put gasket sealer on the barb end instead of inside the hose. The hose is flexible and expandable, so when you push it back on, most of that sealant is going to get scrapped off on the tip of the outlet.
    YMMV
    djimbuser likes this.
  8. djimbuser
    djimbuser Member
    73
    26
    Henderson, Nevada
    Anything worth doing... I moved inverter to the side and re-did it, applying sealant to the barb end. I also removed the dried clump of sealant from the inside of the hose.
    Here's the efforts of mounting a goPro2 back there near the brake accumulator/fuel line. I don't think I should have used a flashlight it wrecked the contrast but you can definitely see something leaking.
    #28 djimbuser, Feb 15, 2025
    BiomedO1 likes this.
  9. djimbuser
    djimbuser Member
    73
    26
    Henderson, Nevada
    I've tried resealing the big hose, and the medium hose (to CCV) twice. It still continues to leak from somewhere. I'm starting to wonder if the head is cracked or something.
    #29 djimbuser, Feb 18, 2025
  10. djimbuser
    djimbuser Member
    73
    26
    Henderson, Nevada
    Could it be something as simple as the brass washer under the coolant temp sensor? I swapped it out for a Honda oil drain bolt washer it seems to be a great fit. Like the brass one is so small in the outer diameter if it's not perfectly centered/aligned it would seems barely big enough to cover the threaded hole in the head.
    Razor blade in photo for size reference.
  11. djimbuser
    djimbuser Member
    73
    26
    Henderson, Nevada
    Update: I actually picked up another 2007 about a month ago for cheap (cat cut out of it and no brakes). I stole the two hoses from it and put it onto my daily 2007. I also swapped out that brass sensor washer with an oil bolt compression washer. I took it on two 15 mile drives and it does not appear to be leaking. Oh and also I should mention I ditched the gasket maker goo and completely cleaned up the tubes coming out of the head and inside of the hoses and swabbed them with brake clean to make sure there was no coolant or oily residue on the mating surfaces.
    I have ordered brand new "Radiator Inlet Hose" (Big hose) and Water Bypass Hose #3 (Medium hose) but those can take weeks to arrive. For now I put the possibly problematic daily 2007 prius hoses onto the new fixer-upper 2007 - I'll test drive it today to see if it leaks.
    Edit/update: fixer-upper 2007 with daily's possible problematic hoses didn't seem to leak a drop on 13 mile test drive. I'm really thinking my leak was from the coolant temp sensor all along.
    #31 djimbuser, Feb 20, 2025
  12. djimbuser
    djimbuser Member
    73
    26
    Henderson, Nevada
    Update:
    Brand new water bypass hose #3 (medium diameter hose from ICE Head to CCV) installed. Somehow coolant is still ending up on top of the transmission.
    For comparison sake my other 2007 now has the hoses from my daily 2007 and it doesn't leak at all.
  13. pasadena_commut
    2,456
    735
    Southern California
    Did the OP ever check that it wasn't coming from the hose which drains the radiator overflow tank?
    Overflow hose from the coolant expansion tank goes where? | PriusChat
    The failure might go something like this:
    on highway trip
    radiator cap opens a little too early (too low a pressure)
    fluid flows into expansion tank
    expansion tank overflows down tube
    coolant dripping from tube blows under radiator and onto transaxle (leaving no trace at the drain tube)
    car stops
    coolant cools
    excess fluid in overflow tank is sucked back into the radiator
    fluid pools on top of transaxle
