Number crunching
Discussion in 'Fred's House of Pancakes' started by Leadfoot J. McCoalroller, Apr 22, 2022.
  1. MAX2
    MAX2 Senior Member
    1,436
    489
    101
    Third planet from the Sun
    Do the panels have any additional protection?
  2. Salamander_King
    Salamander_King Senior Member
    11,024
    8,976
    New England
    Not that I know of. What kind of protections can you install on the rooftop panels?
  3. MAX2
    MAX2 Senior Member
    1,436
    489
    101
  4. Salamander_King
    11,024
    8,976
    New England
    Thanks but it does not look like anything commercially available being on Research Gate. Even if it exists as commercial product, I imagine that would increase the cost of the panel to the point no one can afford it. Besides, the problem we just had would not be prevented by the impact resistant glass. We did not have hail, we just had freezing rain.
    #504 Salamander_King, Feb 17, 2025
  5. Trollbait
    12,776
    Regular ice build up might make a defrosting system worth while. Even thin, the wires will cast a shadow on the cells. Vertically mounted, bilateral panels might be a better option with such concerns. Otherwise, a deicing solution for sometimes events, as long as the chemicals won't damage to panels.
  6. Salamander_King
    11,024
    8,976
    New England
    I dealt with snow by raking snow off the the panel with a long snow rake and wide rubber squeeze so far. But there is nothing I can do about freezing rain, especially when snow followed by freezing rain like last night event. I am not familiar with solar panel defrosting system. No option like that was ever suggested by the installer. And now, all the panels are installed on the rooftop, I don't see there is any easy and cost effective way to retrofit such system. I will just have to wait for natural warm-up. Once the day time temp hit above freezing, it should not take long for the layer of frozen ice/snow to slide off. :(
    EDIT TO ADD: I found this site Snow melting system for solar panels | Thermaltt
    Looks like this type of heating film is installed on the back of individual PV panel. I have no idea what the cost of material and installation. Maybe DIY installable looking at the video. But only for uninstalled panels. Once they are up on the roof, you can't do anything unless uninstall all the panels and do it all over again which I am not going to do.
    #506 Salamander_King, Feb 17, 2025
  7. Leadfoot J. McCoalroller
    8,225
    7,728
    Pennsylvania
    2018 Prius c
    We recently had a new generating peak- 15,216W measured by the app-thingy.
    I was expecting it sometime over the winter- a crisp dry cold day with no trace of clouds, very low humidity and low ambient temps to keep all the panels at peak efficiency.
    Even with the shorter days we are getting a few days that match our summer production, because it's always a bit humid/hazy in summer.
    ETC(SS) and John321 like this.
  8. Leadfoot J. McCoalroller
    8,225
    7,728
    Pennsylvania
    2018 Prius c
    A different record set today: 98.2kWh generated.
    That's over $17.00 worth.
    Today.
    Salamander_King likes this.
  9. Salamander_King
    11,024
    8,976
    New England
    Daytime getting longer, every sunny day is the new record for the system. Today was 74.5kWh.
    @Leadfoot J. McCoalroller, your system is similar size as mine. But our rooftop is not optimized for the south facing best azimuth as your system. Also I am in higher latitude than you. If 74.5kWh is the midpoint for me, then I think over 100kWh/day is coming soon.
  10. Leadfoot J. McCoalroller
    8,225
    7,728
    Pennsylvania
    2018 Prius c
    Nice clear days lately; getting nearly $20 worth of electricity out of the sky on a day like this. I know there are other ways to buy income but dang if this one doesn't feel good.
    Today I did even better! I was touring my yard gathering all the tree litter for disposal, and I found a muddy twenty dollar bill on the ground next to the solar plant.
  11. Salamander_King
    11,024
    8,976
    New England
    Even though we have had plenty of April showers this month, daylight getting longer every day, sunny day is always a new record solar production for us. Yesterday was the new record with 90.7kWh/day. We had 1.2mWh production last billing period which exceeded our consumption, giving us surplus to bank for the winter. This was even though we switched our car from PHEV to a BEV. This billing period, we are on track to produce 1.5mWh.
    BTW, we just finished installing 5 units of mini-split heat pumps to cover our entire home for heating and cooling. Unfortunately, we can't convert to electric heat pump water heater due to our home lacking suitable location to put it (i.e. no basement). So, we are keep using fossil fuel for hot water for time being. I have a plan to remodel our home to add a room to accommodate the hot water heater, but that is probably going to be next year's project. I will never recoup the cost of all addition and remodeling, but at least I will be enjoying the energy independence when that happens.
    We are also at the 10 year cycle of major appliance replacement period. We started with replacing the electric oven/range to IH oven/range first. It is a finicky appliance to use. My wife is not so sure if she likes it yet. We will give a try at least a few more weeks to decide whither to keep it or return it. On another front, I am feeling very good about cashing out a big portion of the equity fund in my tax deferred retirement account last year at the record high level. Now stock market has tumbled down 15-20% since last year's high mark, while market keep losing money, the cash I took out and invested into solar system is earning money steadily, and I paid no tax on the money taken out because of the IRA tax credit. My rough calculation is that I am making (saving) annual ~4% ROI on solar investment, that's far better than what the stock market has done so far this year.
  12. MAX2
    MAX2 Senior Member
    1,436
    489
    101
    How many solar panels do you use? What is the total area of these solar panels?
  13. Salamander_King
    11,024
    8,976
    New England
    35 panels on the size of our roof. Total area would be 67.8 in × 44.6 in x 35 panels.
    MAX2 likes this.
  14. Salamander_King
    11,024
    8,976
    New England
    So far for the first ~4 months of operation, the system has been performing flawlessly. The annual production estimate from the system by the company who installed it was 13,382kWh. This number if realized would offset 100% of our electricity use based on our historical consumption average of 12,732kWh/yr.
    What I did not know was how the company came up with the production estimate of the system. Using public site like NREL PVWatts Calculator I get 17,400kWh annual production result shown below using default value for adjustments but using the exact spec value provided by the solar installer. The number is 137% of the solar company's estimate. I think it is under ideal condition and it is an overestimate. On the other hand, the solar company may have underestimated the annual production to up sell system larger than needed. But so far, in the first ~4 months, our system production is on per with the solar company's estimate or slightly more. With addition of a BEV and whole house heat pumps, our annual electricity consumption may go up in coming year, so with current system it may fall short of off setting 100% usage. But actually, rather than producing excess amount of electricity, (we don't get paid from the utility for the surplus of electricity generated), we would rather produce slightly less than net-zero to make it cost effective.
  15. Salamander_King
    11,024
    8,976
    New England
    Although I have not seen 100kWh/day production yet, our solar panel has been performing as advertised so far. I have not paid the utility bill beyond the mandatory minimum fee to be connected to the grid which is currently $23.43/mo for the last few months. The system has generated 6.2MWh (equivalent to $1,984) so far in the last 6 months. This despite the fact we had the rainiest spring in our record with more than half of the days in the past few months were rainy or cloudy most of the day.
    One thing I learned about the system is that the size of the panel is over sized in comparison to the inverter. I read that it is an industry norm to under-size the inverter ~30% from the panel's rated power production. So, in our system even though the theoretical panel production peak power is 14.875kW, the inverter limit this to 11.5kW. This results in the inverter "clipping" as seen on the recent sunny mid-day production chart below. The theory is that by under sizing inverter ~30%, it works more efficiently in cloudy days and early and late day with less optimal sun rays, resulting in more overall total production than if I had matched or over-sized inverter. Also, under-sizing inverter can save money on initial cost. And of course, the ratio of under-sizing will diminish as the PV panel ages and its efficiency drops over time.
    I have no way of testing the effect of "clipping" on overall production. But it seems the system has been producing more than installer's estimate. So, I don't have much to complain. Will be interesting to see how much of this clipping is going to occur in longer sunny days in the next few months.
    Louis19 likes this.
  16. Leadfoot J. McCoalroller
    8,225
    7,728
    Pennsylvania
    2018 Prius c
    A few days ago we finished our Really Big Expensive Modernization Overhaul project.
    The last piece of the puzzle was an electric heat pump water heater.
    It is a 50 gallon tank with a compression heater strapped to the top of it. In operation it hums and draws air through, which leaves the air drier and cooler. Internally, it concentrates that thermal energy and transfers it into the water. So now our basement is cooler and drier and we get hot water without having to run the oil boiler at all. I no longer need a dehumidifier down there.
    The thing also has traditional resistance coil elements, so if we need more hot water than it can supply by compression it will (optionally) fall back to being an "ordinary" electric water heater.
    For now, I've set it in compressor-only mode. Just making the bet that our hot water usage is gradual enough that it will always be able to keep up. Four days into that experiment we have not been disappointed.
    This was the last step in our plan to modernize the house. It is expected that we'll use around $135 worth of electricity to operate this machine each year, down from about $900 worth of home heating oil to get the same amount of hot water.
    It could be said that we converted from the least efficient hot water system, to almost the most efficient type. A huge jump.
    So on top of the electrical savings we get from our PV system, we're now able to bank some real savings in fuel oil. And we still have the oil-heat system, which gives us choices going forward.
    With that project complete, we are out of the renovation game for a while. Time to switch down to minor maintenance and upkeep tasks while pocketing some savings.
    Salamander_King and Trollbait like this.
  17. Salamander_King
    11,024
    8,976
    New England
    Congrats on the completion on electrifying your home. I recently had to have 200 gal of heating oil delivered to fill the tank. This is mostly for the oil boiler for domestic hot water use. But since our whole home heat pump installed this spring has not been tested yet for the winter time, I had to make sure that the tank is full just in case we still need to fire the boiler for heating purpose during winter. If not used for heating, the tank should last until next spring.
    We can't install electric heat pump water heater in our house (no basement). That will require addition and remodeling that we may tackle in future, but will have to wait for now. Instead, our electrification started with the 15kW solar on roof, then whole house heat pump (not ducted type, but with 5 units of mini-split to cover every room in the house except bathroom and an utility room). Then switching to a BEV from PHEV. And now we are under contract to install a whole home battery backup system before the end of the year to take the last chance advantage on the 30% fed tax credit. When done, our home can operate fully off-grid with solar and battery.
    No cost saving by installing battery storage, but switching to the battery system from gasoline generator will allow almost complete energy independence (except that darn oil boiler for the hot water). That is going to be priceless. BTW, I did rough calculation on electric heat pump water heater. Even if I could switch to electric heat pump water heater, with theoretical 400% more efficient spec for example, a Rheem ProTerra model with a UEF of up to 4.0, it will increase our daily electricity consumption by ~10kWh/day. That will mean daily average electric consumption of entire home will rise from current ~35kWh to ~45kWh. And this does not have the tested real consumption data from the heat pumps as a main source of heat in winter time. So, I may actually see the average daily consumption to go up as high as average 50kWh/day after winter months of heating. This will be 18.25MegaWh total for the year. Our PV and inverters are estimated to generate only 14MWh electricity in a year. So, that will be 4.25 MWh of electricity I will have to buy from the utility. Not the net-zero home anymore. 4.25 MWh of electricity at our current $0.32/kWh is $1,360. So even with the most efficient heat pump electric water heater, I will be paying more than what I am paying now to fill that oil tank (~400 gal/yr or $1,200 at today's cost $3/gal). Add to that installation cost, and addition/remodeling, and possible maintenance cost and longevity of the unit... I don't see there is any money to be saved by switching to electric heat pump water heater in our home. But I still want to get rid of that darn oil boiler!
    #517 Salamander_King, Sep 29, 2025
  18. Salamander_King
    11,024
    8,976
    New England
    Well just received a bad news from the utility. They are requiring another transformer upgrade in order for us to install battery storage for our solar panels which we planed to install before the end of the year to take advantage of the expiring Fed tax credit of 30% rebate on the cost. I just know that transformer upgrade is absolutely not needed. Even non-electrician (=me) knows that. Battery does not generate any electricity, it only stores certain capacity (proposed 20kWh battery) and discharges at rate that is much lower than regular electrical feed. Yet, they are saying they have to update the transformer from current 25kVA to 50kVA one. The current 25kVA transformer was upgraded just one year ago for our solar panel installation to accommodate potential max 11.375kW AC generation. But in practice, our solar panel will never back feed the grid at the max generation power. Our house always consumes them before the excess is exported.
    And now, they are saying because the battery has capacity of 20kWh, even though we are not installing any additional solar panels, it requires the transformer upgrade. This means, the project is not going to be completed this year for sure. I don't see them hurrying to upgrade transformer on the pole before the end of year. I started this project early this year when it was announced that the Fed tax credit will go away. I and my installer have spent substantial time and effort in planning this. I am just glad I did not purchase the battery ahead of time. Would have been a disaster if I have paid for the battery that can not be installed. I will still lose $500 deposit on the project most likely.
    Oh well... this is the end of the solar battery project plan for our house.
  19. bisco
    52,662
    our daughter is starting a major remodel project, and is getting solar quotes as well.
    she has warm air by gas, but might change to a heat pump, if it pencils out.
  20. Salamander_King
    11,024
    8,976
    New England
    We installed 5 units of mini split heat pumps to cover our entire home. Installation was done this spring, so we have not used them in winter yet. So far in the shoulder seasons, heat pumps works very well. But economically, it makes no sense unless the solar generation cover the electricity consumed. Even at the maximum efficiency of the heat pump, the electricity cost is higher compared to current oil price, BTU to BTU. If I have to pay extra electricity to run the heat pump, then it won't save me any money. That is if the excess solar generation credit saved during summer can not cover the entire winter generation deficit months with heat pump used as primary heat, then it would be cheaper to run oil boiler to heat our home.
    I have to wait for the real cold to settle in to see its true capability and efficiency in the cold weather here. It is rated to provide heating even in extremely cold outdoor temperatures, reaching as low as -31°F. I don't think we get that cold here. But, if it operates fine without supplemental heat source in sub zero temp, I will give them thumbs up.
