GruppeM Ram Air System for Toyota 60 Prius 2.0 HYBRID
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Mksky, May 15, 2024.
  1. Mksky
    Mksky Member
    61
    33
    Los Angeles
    2024 Prius
  2. Xov’ze
    Xov’ze Member
    39
    46
    2023 Prius
    I’m looking at the product page and I’m pretty curious exactly how this is different from the stock air intake? This appears to pull the air from the same place as stock, the only real difference being the shape of the filter? Idk am I missing something?
  3. PhoS
    PhoS Active Member
    234
    195
    Nowhere
    2023 Prius
    Limited AWD-e
    The carbon shroud looks to block the intake duct from air under the hood a little better than stock. Otherwise there's just a MAF housing adapter to use a cone filter instead of the oem flat style filter, and the stock airbox gets deleted entirely. It looks nice for show purposes but I'm willing to bet the intake drone with the CVT will get old quickly.
    vs.
  4. Xov’ze
    Xov’ze Member
    39
    46
    2023 Prius
    couldn’t we accomplish this with like? A strip of duct tape?
    What exactly does swapping out the airbox do? Does it get better airflow maybe?
    I’m kinda skeptical about intake mods for the prius considering the stock intake is already basically a ram-air intake
    HacksawMark and soft_r like this.
  5. PhoS
    PhoS Active Member
    234
    195
    Nowhere
    2023 Prius
    Limited AWD-e
    Yes 100%
    The assumption would be that it flows better. I can say from experience that the stock intakes on Toyotas are rarely as restrictive as aftermarket intake companies would like you to believe. Usually it's just a noise maker.
    Cruzctrl1, Xov’ze and GcinFl like this.
  6. Xov’ze
    Xov’ze Member
    39
    46
    2023 Prius
    Alright coming back to this thread because I actually wound up buying it
    I was looking for a way to get a bit more of a sporty sound from the engine. I didn’t want to go as loud as a catback exhaust, and I didn’t want to diy a cheaper short ram or “hot air” intake.
    Install was pretty straightforward: I didn’t need to cut drill or modify anything, and the instructions were clear and easy to follow. You basically just unbolt the stock intake and this bolts right in.
    I’ve gotta say, as an aesthetic mod? This thing’s great: the engine bay looks very nice with the carbon fiber, the intake sound is quiet enough under cruise to keep from being annoying, and you get a nice growl under acceleration. Definitely a deeper, more aggressive sound than the stock intake.
    As far as performance improvements? It maybe *feels* a little faster, but honestly, I’m thinking that’s mostly psychological. I went with this because I wanted the sound, and because this intake leaves so much of the stock intake intact I was confident it wouldn’t make the car run *worse*. I don’t think the ole butt-dyno is sensitive enough to detect the advertised +10 hp, and I’m not about to put a prius on a real dyno to find out. I haven’t yet noticed any major changes to fuel economy either, but I’ve only had it installed for two days. So, while I don’t expect there to be any meaningful effect on mpg, it’ll take a bit more driving before I can say for sure.
    tl;dr: bought the intake hoping it would sound nice, and this intake sure does sound nice!
    apissues likes this.
  7. Hayslayer
    Hayslayer Member
    246
    125
    was that really $1200?
  8. Xov’ze
    Xov’ze Member
    39
    46
    2023 Prius
    Sure was! it’s 6 peices of carbon fiber made to order (plus some other hardware for the cone filter swap), so not cheap. Definitely not a practical product/purchase by any means.
    I’m sure there are many cheaper ways to get a louder intake sound, but like I said, i saved up for this because I wanted quality parts that wouldn’t hurt the car.
  9. Perfectpacman
    Perfectpacman Junior Member
    78
    22
    United Kingdom
    2024 Prius
    ----UK----
    I can see a minimal benefit with a turbocharged engine, but with a naturally aspirated one it's not going to make anything happen.
  10. Xov’ze
    Xov’ze Member
    39
    46
    2023 Prius
    Exactly what I’m saying: this is for look and sound, and if that’s what you buy it for it’s very nice (if expensive)
    Perfectpacman likes this.
  11. Hayslayer
    Hayslayer Member
    246
    125
    To each their own. We all have our hobbies.
    You go to those Walmart parking lot car shows where guys lift the hood and show what they got and rev their engines?
    We see those quite a bit, and of course we have the LED crowd too. Always fun to look at.
  12. apissues
    apissues New Member
    Saturday
    ATL
    I have to admit I joined just for this post, but thanks for the review on this intake. I realize it’s rather a goofy mod for a Prius, but Wth else would you do to mod the powertrain? Answer: not much.
    (Not currently a Prius owner but interested in a Karashi as a new daily. I’d keep my truck for necessary truck stuff.)
