FIAMM 74100 El Grande Horns on Gen 5?
Discussion in 'Gen 5 Prius Accessories and Modifications' started by scotched, Feb 16, 2025.
  1. scotched
    scotched Member
    76
    108
    Encino, CA
    2023 Prius
    Has anyone installed these on their Gen 5?
    It seems pretty straightforward other than the lack of pnp OEM connector.
    I'm just wondering if anyone has done this cleanly and reversible.
  2. Perfectpacman
    Perfectpacman Junior Member
    85
    24
    United Kingdom
    2024 Prius
    ----UK----
    I've fitted the genuine Lexus twins to replace the 'meep meep' original one and they're fantastic.
    Not sure about the FIAMM ones but anything is better than standard....
  3. priusdriver223
    84
    32
    Lala Land
    2023 Prius
    XLE AWD-e
    Hey there, is this a plug and play or it requires other things as well? Cheers!
  4. Hammersmith
    Hammersmith Senior Member
    2,370
    2,420
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The kit comes with everything you need(plus a few little things you don't).
    There are a few different part numbers that work. I ended up with 08522-B1010. It's a JDM part number, so you order it from an ebay dealer or an importer.
    What you use:
    1. Horn(High)
    2. Horn(Low)
    3. Bolt (car already has a threaded hole for a second horn)
    4. Harness splitter
    5. Zip ties and adhesive mounts
    Remove the trim cover(some push clips - need a small flat tip screwdriver or similar to pop them out).
    Unplug old horn.
    Unbolt old horn.
    Adjust mounting point on both new horns to fit car(loosen a bolt, rotate mount, tighten bolt).
    Bolt in horn #1 with old bolt.
    Bolt in horn #2 with new bolt.
    Plug in splitter to harness and both horns.
    Use zip ties and mounts to secure the wiring.
    Reinstall trim cover.
    Takes maybe 10 minutes. By far the easiest upgrade I've done. Maybe the cheapest. The kit price varies from $50-$80 depending on the seller.
  5. Perfectpacman
    85
    24
    United Kingdom
    2024 Prius
    ----UK----
    Agreed.
    Make sure the horns are pointing down too, in case of water ingress through the grille
  6. scotched
    scotched Member
    76
    108
    Encino, CA
    2023 Prius
    I might just shell out for the Lexus kit and save the other kit for my other car. I don't feel like splicing wires on a new car yet.
    Perfectpacman likes this.
  7. Eddie F
    Eddie F Junior Member
    27
    Windsor, Canada
    2024 Prius Prime
    SE
    I installed the Lexus ones discussed in this chat. Absolutely love them.
    Perfectpacman and scotched like this.
  8. Perfectpacman
    85
    24
    United Kingdom
    2024 Prius
    ----UK----
    Awesome. I know manufacturer's will try and reduce costs for the bigger percentage gains, but that horn fitted to a £37k car was bordering on dangerous
    Oh, and extremely embarrassing
  9. Robmoo
    Robmoo Junior Member
    55
    2024 Prius
    I installed these on my 2017 Gen4. My not sure if I want to void any warranties on my 2024 Gen5 yet. They do work great. You go from meep meep to sounding more like a SUV.
    Eddie F and priusdriver223 like this.
  10. priusdriver223
    84
    32
    Lala Land
    2023 Prius
    XLE AWD-e
    Hey there, Meep Meep is crazy. Thanks for the laugh, cheers!
  11. VirginiaLeePrius
    VirginiaLeePrius Junior Member
    47
    Space Coast, FL
    2024 Prius Prime
    SE
    I second that! I searched for 08522-B1010 KIT on Ebay, picked the cheapest one and ordered it. The Japanese instructions were helpful because it is similar, albeit maybe reversed. I tucked the covered cable as the instructions suggested and mounted the secon horn under the hood release (as shown). It such a complete kit, it even has the spacer and bolt to replace the existing hood release bracket bolt. Worth every penny and sounds great!!! I tried to upload videos and sound clips but couldn't the difference is SO dramatic it is ridiculous.
    Eddie F likes this.
