P2195 07 Prius stalls at highways speeds
Discussion in 'Gen 2 Prius Main Forum' started by Frankusa94, Aug 24, 2024.
  1. Frankusa94
    Frankusa94 Junior Member
    60
    Ma
    My 07 after 3-5 miles of driving at 60mph+ …will suddenly starts blowing black smoke out tail pipe, mpg drops to 15mpg, stops charging hv battery and gradually rolls to a stop as battery becomes depleted. Powering the car off for a 2 minutes allows the car to restart and run normally…I do need to wait a few minutes for hv battery to charge up… then car drives fine the rest of the trip. Throws codes p2195 “ Bank 1 sensor stuck lean” car runs fine under 60mph. Aftermarket Upstream O2 sensor is 3 months old. anyone have any thoughts on this issue?
    Thanks
    Frank
    52,401
    my only thought is an ecu issue, but i have no idea really. i can't understand why turning it off an on fixes it, except for the resetting of an ecu.
  3. Leadfoot J. McCoalroller
    8,149
    7,654
    Pennsylvania
    2018 Prius c
    What do the fuel trims look like?
  4. Brian1954
    Brian1954 Senior Member
    2,413
    969
    South Central PA, USA
    Reply from the other thread that you posted in. Copied here for clarity.
  5. Frankusa94
    60
    Ma
    Leaning towards replacing with denso o2… just seems odd this aftermarket o2 works fine at city speeds and would only flake out after 3-5 miles of driving at 65+ mph. Another clue is the hv battery stops charging when issue occurs. I wish is knew if that happens once p2195 is set… or is it a charging issue that leads engine issue p2195?
    thank you
    I am just as puzzled… clear thing is that it only… only happens at 65+mph speeds…
    Short term trim is 0%
    Long term is usually 12-13%
    thanks
    #5 Frankusa94, Aug 24, 2024
  6. Leadfoot J. McCoalroller
    8,149
    7,654
    Pennsylvania
    2018 Prius c
    That's a very big trim. Combined with the error code I'm inclined to think that you've got a bad sensor or possibly a major air leak downstream from the MAF.
  7. Frankusa94
    60
    Ma
    The long term trim has concerned me. I am gonna try to understand that in more detail.
    Nor air leaks, exhaust or vac leaks.
    Yes…I don’t yet fully understand the significance of the long term value…ongoing… I have not found any intake,exhaust, or vac leaks… looks like I am leaning towards installing denso o2 in hopes of resolution. Original sensor was denso and car did the same thing before sensor heater failed …thus the replacement was installed.
    gonna stay at it til I get this issue fixed….
    thanks
    frank
  8. Leadfoot J. McCoalroller
    8,149
    7,654
    Pennsylvania
    2018 Prius c
    It's the fuel injection computer's way of saying "I don't mean to alarm you, buddy, but I'm really surprised by how much bonus gasoline I'm having to spray into this thing based on what the O2 sensor is telling me."
    The P2195 is "On second thought, it is worth an alarm."
    Plan on an extra oil change once resolved, there's probably a bunch of fuel diluted in there now.
    MAX2 likes this.
  9. Frankusa94
    60
    Ma
    I hear ya!… gonna have to try a denso o2 sensor. This issue has happened 6 times over a 5k span, oil looked good, just got changed 600 miles ago. Looks like I gotta keep it under 65mph til I get this issue fixed… I can see it now…” look at that slow Prius holding everything up on the interstate”…. lol….
    thanks
    Frank
  10. bisco
    52,401
    i would take mr guy mann's advice
  11. Brian1954
    2,413
    969
    Frankusa94 posted in a different thread that he solved the problem. Here is what he wrote on September 23, 2024:
