Bizarre 12v Battery Issue
Discussion in 'Gen 2 Prius Main Forum' started by Bholey, Jan 17, 2025.
  1. Bholey
    Bholey Junior Member
    Houston
    I am having an intermittent issue with my Gen2 Prius. I unlock the car using key fob and as soon as I press start button everything shuts down. Dash is completely dark. No light, nothing. The car is completely dead, there is no juice coming from 12v. I can not start the car, Can't use my key fob to lock the car or do anything. I'll leave it for a little while and come back and now I can see the 12 v is back to life. I can start the car and use it as usual but my clock, trip meter and radio is reset.
    It has happened at least 6-7 time with various intervals. 12v goes back to life almost always except one time when I detached the neutral battery and reattached and it worked. At that time I checked the battery and it showed up around 12.37. The 12v battery is almost 7 months old. The issue is that this is an intermittent problem and hard to diagnose. Any ideas, suggestions ?
  2. ChapmanF
    18,553
    Where are you measuring, when you measure 12.37, or say "there is no juice coming from the 12V", etc.?
    Sometimes being specific about that leads rather directly to a solution. I've seen cases, for example, where there'd be 12.37 when the test leads are pressed right on the battery posts, but not when pressed on the cable clamps on the posts. Or still present there, but not somewhere else. You get the idea.
  3. Bholey
    Houston
    12.37 was on Battery clamps (not the battery post). The clamps were also really tightly connected to the battery post. So no loose clamps.
  4. Hayslayer
    Hayslayer Active Member
    465
    265
    Classic symptoms of a poor electrical connection in the 12v supply circuit.
    Assuming you have an internally good 12v battery with good posts. (I have seen 12v batteries with internal failures, but very very rare)
    The (-) post has one end of a black cable clamped to it, the other end is fastened to the car body by a 10mm hex head bolt. Verify those connections are clean and tight.
    The (+) post has a fuse block assembly clamped to it. Make sure this post and clamp are clean and securely fastened. Internal to the fuse block assembly is a large fuse (or fusible link, whichever you want to call it) that is fastened to the clamp on one side and the output busbar on the other. If I remember correctly, those are 8mm hex head fasteners. Make sure those connections are tight. The output busbar has a large red cable plugged into it. Make sure this plug is fully seated into the receptacle. Feel free to slide it out, inspect it for physical integrity and re-install it so you hear the "click" when it's fully engaged. The small plug is 12v feedback and should have no input as to whether the 12v supply is present or not.
    The opposite end of that red cable is fastened to a stud in the upper passenger side corner of the underhood fusebox. This is the 12v supply for the fuse box and has a 10mm hex nut clamping it to the stud. Make sure this nut is tightly secured. This stud is what supplies 12v power to the main fusible link, which is the portion of the fusebox that has the clear plastic window. Behind that clear plastic window, the 12v is then distributed to several circuits using various amp rated links.
    Brian1954 likes this.
  5. ChapmanF
    18,553
    Excellent. Just keep moving those test probes until you get from where the volts are to where they aren't.
    I saw an old Ford once where the battery clamps were tight on the posts, but the clamp and post surfaces were badly oxidized. Conduction between the post and the clamp was happening in one small clean area.
    That car would seem fine, all light light up and everything, until trying to crank the engine. Then everything would go dark. And stay dead for about five minutes. Then come back to life.
    The heating caused by starting current through the tiny conducting area caused the clamp to expand until conduction was lost. Then it would take five minutes or so to cool and contract again. It was acting just like an unintended self-resetting circuit breaker.
    The point of the example is just to observe carefully and stay open to unthought-of possibilities, because weird things do happen.
    MAX2 likes this.
  6. Bholey
    Houston
    Thank you both for some pointers. I took apart all connections in the battery area today. There was no oxidation. Every connection was properly in place but I reassembled everything just to make sure I'm not missing anything. It is poor electrical connection but hard part is to find where it is and this is intermittent so I cant trouble shoot this. Thanks again for pointers. Its definitely helpful.
  7. BiomedO1
    4,151
    2,175
    SacTown, Ca
    has the battery been properly load tested?
  8. Paul Gregory
    Paul Gregory Senior Member
    2,235
    593
    Alberta
    2024 Prius Prime
    XSE
    That's my thought. The battery capacity may be so low that it only works intermittently, and the voltage is hovering so low that it shuts down the control computer when the load increases to a certain point.
  9. Bholey
    Houston
    Not sure about the load testing but it was tested at the local parts shop and they said the battery is good.
  10. BiomedO1
    4,151
    2,175
    SacTown, Ca
    Sorry, Just asking clarifying questions. If your not sure how the battery was tested, how do you know that isn't the problem? You've already checked the connectors and ground points. I've seen bad batteries that have ample voltage, but not enough current.
    I used to work in an auto parts store when I was in high school. Some guy shows you how to do something - green light good, red light bad. No idea how it works or what the parameters are.
    Please get the battery properly load tested, with a carbon pile load tester. I don't really trust those little automatic battery test boxes. They have a very small load resistor that results in a lot of false negatives. Once we're sure it's not the battery, we can move to the next item.
    Point is that you may be just chasing your tail because some guy gave you bad information.......
    Hope this helps.....
    #10 BiomedO1, Jan 18, 2025
  11. Goodcitizen
    Goodcitizen Member
    75
    30
    Cali
    I had an intermittent no power issue on my gen2. Where I'd press the power button and the car would go dead. Eventually it didn't work for weeks. It ended up being corrrosion on a wire junction under the dash. Junction iac3 drivers side.It was a huge headache to trace down and if you check my post history there's a couple threads with details. If you have or had condensation/water intrusion issues due to winter, then corrosion is what's causing your problem.
    That being said after you confirm it's not the 12v, which was suggested to me like 20 times only for it not to be the battery.. i suggest picking up a techstream dongle from amazon/ebay and utilizing the 'techstream in 5 minutes' guide easily found via google.
    Even when your prius won't power on via the button techstream can in theory communicate with 4 of the modules. So while my prius seemed dead it actually had a code generated. I was able to confirm what modules weren't getting power. The code was enough to use the service manuals troubleshooting guide to work my way along the wiring diagram and confirm what did and didn't work. Quite time consuming but looking back it was pretty straight forward. You just need a good voltmeter, techstream, the service manual, and a lot of patience.
    Good luck to ya, don't let the check your 12v replies drive ya crazy! Techstream or a pro level scanner like autel can help you figure this out.
    If you have any questions I'll do my best to help.
  12. Paul Gregory
    2,235
    593
    Alberta
    2024 Prius Prime
    XSE
    Post Edit: I had the battery tested, but the dealer declared it OK. I later resolved this issue, explained in many subsequent posts.
  13. richard schumacher
    7,666
    1,047
    United States
    What voltage do you measure at the test point under the red cap inside the fuse box?
    #13 richard schumacher, Feb 24, 2025
  14. Mendel Leisk
    41,909
    @Bholey you must have measured voltage with meter probes right on the battery posts by now: what did that read?
    I’d concur about the need to load-test. If you want first-hand assessment, testers from TOPDON and Autel are popular. I’m using a Solar BA5, current iteration is BA9, around $50~60 USD.
  15. Paul Gregory
    2,235
    593
    Alberta
    2024 Prius Prime
    XSE
    If my car is starting, I don't have enough OCD to load test my battery.
  16. Mendel Leisk
    41,909
    Yes, foresight is overrated. :rolleyes:
  17. Paul Gregory
    2,235
    593
    Alberta
    2024 Prius Prime
    XSE
    It's not like it would help me to know my battery was losing capacity.
