Professional EGR Cleaning Resources
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mendel Leisk, Oct 5, 2022.
  1. Scottyboy24
    Scottyboy24 Junior Member
    33
    Pensacola, Fl.
    I BIG thanks to ya! Will do!
  2. Scottyboy24
    33
    Pensacola, Fl.
    Thanks to you all. I will schedule the borescope test tomorrow and go from there. -- But could coolant still be getting in there, even if I never have to add coolant? LIke I haven't had to add any in a couple of years now at least. But it sure sounds like what's happening because it runs good the rest of the day. -- Oh well, I will let you all know what I find out. Thx again for all the support!
  3. rjparker
    10,227
    6,386
    Make sure the coolant system is pressurized and the mechanic knows gen3 Prius issues. It just takes drops of coolant seeping in overnight.
    This is how to do it
    Brian1954 likes this.
  4. johnHRP
    johnHRP Active Member
    645
    188
    KA, DE
    Excel
    I am afraid it is head gasket @Scottyboy24
    Classic random misfire in a cold Start. EGR clogging effects the drive in mid throttle after the engine is warm
    Check the coolant level, and start shopping around for a used 2015 engine. That's the most cost effective way unless you can find someone replace headgasket for less than 1000$.
    How much the oil consumption? if it is less than 1q per 5k miles, then it is worth to fix it. Otherwise, time to move on
    The head gasket at around 150-250k miles is very common on 2010-2012 Prius. The 2013 model has less issues but not immune. The p0300 random misfire, p0301=cylinder 1 misfire, etc. Bring it to mechanics to do a pressure test, otherwise the coolant level already gives a clue. The coolant level should stay the same over 5y in most Prius.
    I am very sorry, but we should plan cleverly. How much is the car worth, and the rest of the car condition. Head gasket in Prius pre 2015 is known problem and we must be wise what to do next. Check oil consumption, and prepare for catalytic converter too if it excessively burns oil 1Q/1000 miles.
    #184 johnHRP, Feb 20, 2025
    BiomedO1 likes this.
  5. BiomedO1
    3,778
    1,969
    SacTown, Ca
    The P0300 is the ECU knowing there's a misfire, but can't nail it down to a particular cylinder because the engine is rattling so much. @johnHRP does a good job explaining this and the main misfire is in #2.
    I would call local parts stores to borrow a bore scope. Remove the spark plugs and inspect the top of the piston heads. One or two of them will be different from the rest, that's the one getting steam cleaned by your coolant leak, if it's a head gasket problem. If that isn't the issue, move spark plug #2 to #1 and #2 ignition coil to #3 to see if your problem moves. If the problem moves, that's the intermittent part that needs replacing. At that kind of mileage, If it is a failed plug or ignition coil; I'd replace the set - but don't shot-gun it if it's a head gasket. You'll need to determine if it's worth fixing.
    BTW: the electric coolant pump tends to get intermittent, lazy, and/or die at that mileage also. You need to monitor the ECT to make sure the engine isn't running hot, might be another reason the head gasket blew. The ECT icon doesn't trip till +240F, normal operating temperature is around 190F. Some people claim that they don't have a problem because it only flashes on and off a few times. Your engine is running too hot. Start saving up for a major repair....
    Hope this helps....
    Scottyboy24 likes this.
  6. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    Throw parts at it without leak down test first with those codes?
  7. Stephen Herman
    Stephen Herman Junior Member
    North Carolina
    Anyone know of a shop in western nc that does this? Took a 2015 to dealer and was advised to forget about preemptive head gasket maintenance. Would clean/replace the egr valve only. And doing this would cause more damage because would "upset" the gunk in the intake manifold, et al. Know this doesn't make much sense. But taking apart the egr system for a thorough cleaning is not what they do. Advised to wait until start throwing codes (too late then). Can't take it to Florida. thx in advance.
  8. Tim Jones
    Tim Jones Senior Member
    1,759
    565
    SE Texas
    2011 Nissan LEAF
    Gen 3 total junk....... doomsday machine..... avoid at all costs..... or you will pay the costs
  9. Mendel Leisk
    41,628
    What a world we live in now. :(
    Bill Norton likes this.
  10. Tombukt2
    13,110
    2,352
    Yeah most shops don't know anything about this not even if it's a ct200h from Lexus it's just not a thing by the time somebody would notice this and catch whatever the hg's starting to go down in the software whatever the damage is pretty much gotten started so then you're possibly doing this $600 worth of cleaning and taking apart when you should be doing something much more probably I'm not sure how they look at it I haven't really talked to anybody about it but I don't know anybody that does it except owners. I do know shop owners that will do what people ask it's x amount of dollars an hour no matter if we're shooting dice in the bathroom or taking your car apart but then they're not going to be responsible taking instructions from a customer if something goes awry after they get done your engines rattling in other words so you know you're not going to be able to pawn that kind of thing off on these kinds of folks
  11. Julio_E
    Julio_E Junior Member
    Michigan
    2024 Prius Prime
    XSE Premium
    Maybe try a google search like "hybrid shop north carolina". I'm in Michigan and found a nearby Hybrid shop the same way. One of my relatives has the Gen3 so at some point, we may visit that shop, now that winter's over. I did that suggested search and got some results. You can call some of them to ask.
  12. rjparker
    10,227
    6,386
    A dealer will replace the egr cooler, valve and intake if you ask for those services. Egr is not the gen3 hg problem and the dealers know it.
    They are not going to spend many hours at $175 an hour to clean an egr cooler when a new cooler is less money. Small shops and diy'ers might or will have extras that are cleaned ahead of time to swap out. My mechanic has a box full of egr coolers to go with hybrid battery modules and other spares removed from blown engines.
    There is a revised egr valve, improved ecu software, updated intake, redesigned pistons, rings and head gasket Toyota can supply or install. What that translates to is a rebuilt engine. If you love the car enough to spend more than it is worth, yes the above is a preemptive strategy that will work. Later gen3s sold overseas through 2022 have very few of our problems but have the same engines and egr configuration.
    The only affordable way to keep a US gen3 longterm is to diy it. This forum is full of those types.
    Tim Jones and Bill Norton like this.
  13. Bill Norton
    Bill Norton Senior Member
    2,192
    740
    MONW, Ks.
    2019 Prius
    L Eco
    But the leading theory around here is the uneven gunk in the small EGR passages in the intake is what causes the HG problems.
    The dirty cooler and valve at most would evenly slow down the flow.
    Unplugging the EGR valve also evens out the flow, as in none.
  14. ChapmanF
    18,301
    unless it's not closed when you unplug it
    Tombukt2 likes this.
  15. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
    Buy a new intake manifold complete with gaskets for under a hundred dollars and install it on your car, removing the old one.
    Intake manifold 17120-37054
  16. Mendel Leisk
    41,628
    The intake manifold is the last thing I’d consider replacing, unless it’s cracked or defective somehow, say the threaded embeds hooped. It’s so easy to clean.
    Tim Jones likes this.
  17. Stephen Herman
    North Carolina
    Thanks for all above responses, informative even the pessimistic ones. This is a defect that's like a timebomb connected to a clock. Sure and certain. Hybrid head gaskets are subject to more heating and cooling cycles than ice vehicles but still no reason to blow head gaskets at 150-250 k miles. Outside generation 3, others don't seem to have this problem, nor other hybrids. From Mr. Norton's response, seems that the intake manifold is main culprit. Taking Julio's advice in searching for a shop that has experience with this and proven competence,
    Agree with Tim Jones that this generation can be very dangerous to buy. Test drove a 2015 at the local Toyota dealership. Drove great, but the sales manager acted very suspiciously when questioned about this problem. Later found out they sold the vehicle wholesale. Why? Obviously the head gasket was throwing codes already. Knew it was about to pop. They aren't going to waste money fixing it. They would be buying the lemon. And probably not for parts. To some scammy place making a living selling these lemons to unsuspecting customers.
  18. Mendel Leisk
    41,628
    The dealership is one of those scammy places.
  19. Bill Norton
    2,192
    740
    MONW, Ks.
    2019 Prius
    L Eco
    1. Exacto Mundo!
    2. Dangerous? I would say just have $2/-2.5k ready for when that fateful day arrives.
    3. I never heard of 'codes' related to a pending head gasket failure. It just starts mysteriously dropping the coolant level and maybe stuttering/misfiring during a start up after being shut down for a while. Any time the coolant is low and it hasn't moved in the prior +150k miles.... Get ready for that big repair bill.
    You may get an overheat light if you let the coolant get very low. But that's not a 'code'. That's a warning light. Take it seriously. Stop NOW.
    You can leave the coolant cap loose to lessen the pressure in the coolant system. This buys you time to take it to the shop.
    I drove mine weeks and hundreds of miles to that well known 'Head Gasket' Specialty shop for the repair.
    I'm still waiting for that shop to finish what was supposed to be a 1-2 day repair. But that's a different story for a different day,,, once I finally get my car back,,,, weeks later....:(
  20. Mendel Leisk
    41,628
    Misfire codes P0xx with xx sub'd by 00 through 04: 00 being general, and 01 through 04 corresponding to cylinders.
    They "just" signify misfire, but more often than not...
