What battery does my Prius have?
Discussion in 'Gen 3 Prius Main Forum' started by Peet, Feb 20, 2025.
  1. Peet
    Peet New Member
    South Africa
    I am buying a 2010 Prius, the current owner has always been under the impression that the vehicle is fitted with a Li battery, but the user manual says that it is NiMh.
    I see that both were an option for the 2010 model, but I am not finding any information on how to confirm what is currently fitted, ideally without opening the battery, which I am happy to do, but best not to if there is another way.
    I do have a fairly advanced scan tool, so querying the system is no problem, I am not picking up a BMS or battery controller module, but it might fall under one of the other modules.
    Another question is if there is a NiMh installed how feasable is it to upgrade to Li if it dies?
    The vehicle is still on its original battery, which seems to still perform well WRT fuel economy...
    I am an electronic engineer, I do service our own cars myself and have stripped and rebuilt both my Renault Kangoo and my wife's Toyota Yaris engines, just as a ref, as I know there are many people who would be best referring this type of work to a service company.
  2. Tideland Prius
    16,505
    The 2010 liftback were all NiMH. Only the Prius+ had a Li-Ion battery and those weren’t in production until 2011/2012. And only for the 7-seat version.
    Mendel Leisk and Brian1954 like this.
  3. MAX2
    MAX2 Senior Member
    1,436
    486
    101
    Third planet from the Sun
    If you have a non-plug-in hybrid, the battery is NiMH.
    Plug-in hybrids have a lithium battery, but it takes up the entire bottom of the trunk.
    You can open the trunk and take a look.
    Brian1954 likes this.
  4. Peet
    Peet New Member
    South Africa
    Thank you for the concise answers, I know this vehicle to be 5 seat, not plugin and has a spare wheel in the trunk, so almost certainly not Li.
    Fuel economy still seems good, so presumably it is in fair condition.
    Would anyone know about a thread where someone upgraded to Li?
    It would be interesting to know if that’s a reasonable option, especially if one gets more electric range!
  5. Grit
    Grit Senior Member
    6,571
    4,223
    Wilkes Land
    Bet the seller also said all highway miles.
  6. MAX2
    MAX2 Senior Member
    1,436
    486
    101
    Are you planning to drive only on electric traction?
    Then it is not reasonable.
    Electricity in a non-pluggable hybrid is taken from the combustion of gasoline, and with a lot of losses in the transmission of energy from the engine to the wheels, from the engine to the motor-generators, from the motor-generator to the inverter, from the inverter to the high-voltage battery and back.
  7. rjparker
    9,895
    6,102
    You need a more hybrid centric scanner. Low cost options include the free Dr Prius or Car Scanner phone apps and a $35 US bluetooth obd2 interface.
    There is a company in California that was selling lithium retrofits but the product had short lifespans, no lithium bms and fires. They denied everything for years but then suddenly dropped the product.
    Your best bet for a 2010 are new oem nimh modules or buy a Prius +/alpha that came with lithium cells and a lithium bms from the factory. That car mounted the lithium cells under the front seat console.
    #7 rjparker, Feb 21, 2025
  8. Paul Gregory
    Paul Gregory Senior Member
    2,002
    517
    Alberta
    2024 Prius Prime
    XSE
    I believe only the plug-in models had lithium ion batteries.
  9. ASRDogman
    ASRDogman Senior Member
    7,450
    3,872
    The Sodium Battery is VERY good. Mine has been great!
  10. Mendel Leisk
    41,008
    What’s the miles on it? There can be “other issues” besides the hybrid battery.
    Prodigyplace likes this.
  11. bisco
    51,561
    Plug ins were not available until model year 2012
    Grit and MAX2 like this.
  12. Peet
    Peet New Member
    South Africa
    Thank you for all the replies.
    The car has 120 000 kilometres on it, a good friend of mine is selling it as he is moving abroad.
    I am currently using the car twice a week, so I do know the car and it has been very well looked after, the thing that concerns me is that it is the original battery, though seemingly good at this stage, I want to understand the costs involved when it does go.
    Partly an upgrade to make it a plugin would be great, as the company I work for has charging stations and don’t charge their staff for the use thereof, but any economy / savings are always great.
    I am part of the R&D team that designed a lithium battery for inverter systems, so I understand the technology quite well and won’t get anything that doesn’t have a BMS and doesn’t balance.
    Interesting that a standard scan tool is not the best choice, I’ll try and see what makes the app more suited.
  13. bisco
    51,561
    May I ask where you saw that both batteries were available for the 2010 Prius?
  14. Peet
    Peet New Member
    South Africa
    Somewhere on this forum there is a brochure, I am currently using my phone to browse, not a computer, which is clearly not ideal for this site, but certainly at a quick glance it has both technologies.
    Here is what I found, though I cannot exactly say where on this forum I found it.
    I don’t seem to be allowed to post a link yet, so I’ll try to post a screenshot of the page.
  15. Paul Gregory
    2,002
    517
    Alberta
    2024 Prius Prime
    XSE
    I had one, and they seemed to be quite rare. And not really a success for the company. But I'm glad they didn't abandon the concept and improved it with the Prime.
  16. Mendel Leisk
    41,008
    The Plug-In was a prominent product placement, in Under the Dome TV series, a less than memorable adaptation of Stephen King's book of same name. Nice rims, snagged a set. :)
    (Appreciate I'm way off-topic, sorry.)
    omuomu likes this.
  17. bisco
    51,561
    Idk about Canada, but down here, they were only sold in carb states.
    Like the prime, they never made enough to meet demand, probably because of the lower profit
  18. Paul Gregory
    2,002
    517
    Alberta
    2024 Prius Prime
    XSE
    I don't know how they were sold here, but I got mine at a discount because the dealer couldn't move it, I guess.
    I only ever saw one other Prius Plug-in and heard about another. Seemed rare to me.
  19. Mendel Leisk
    41,008
    On the west coast I usually stop-and-stare when I see one, very rare. Apart from the missing charge port ours looks like one at present, using Plug-In rims with our snows. :)
  20. Paul Gregory
    2,002
    517
    Alberta
    2024 Prius Prime
    XSE
    The charging port door on the right side is the most obvious identifying feature. Sold mine last year for $9500. I guess it was a bit underpriced; no wonder it went fast. No regrets, however.
