engine rumble/vibration on startup, 155K
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Shooter8, Feb 20, 2025.
  1. Shooter8
    Shooter8 Junior Member
    central Arizona
    2013 Prius v wagon
    2013 Prius V, 155K. Our Prius recently rumbled and vibrated several times on startup. The car sat overnight, about 50 degrees in SoCal. My research points to bad head gasket. Rumble stops after 5-10 seconds. Ran fine on return trip to AZ, nearly 400 miles. We have never head any mechanical problems until now.
    At 155K, other parts might should be replaced: piston rings, timing belt, etc.
    Should I have the engine rebuilt or replaced (remanned or new?) or should we just replace the head gasket?
    What are your thoughts?
  2. Shooter8
    central Arizona
    2013 Prius v wagon
    Today, two days after return from Cali, the Prius started normally.
    I ran some errands in town: all starts were normal.
    I visited O'Reilly to read the codes: There were none.
    How long does moderation take?
  3. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
    Have you ever cleaned the EGR system?
    Coolant is leaking from the tank, does it need to be topped up?
    What is the condition of the engine oil?
    Danno5060 likes this.
  4. ASRDogman
    ASRDogman Senior Member
    7,635
    3,931
    You should turn it off if it rattles. You could bend a rod.
    Is the coolant tank low?
    It “may” just be condensation from a hot engine and cool outside air. That’s normal.
  5. Tombukt2
    13,079
    2,344
    So if you start it and it goes to raveling what happens if you step through it almost floor the gas pedal It immediately clears up seems like it's RPM dependent when you're at whatever idle is called in this thing. It seems to bounce all around The minute you step on the gas engines running just like it's supposed to like it has been all of its life so far and then it'll do it when in drive but only when your foot's off the gas seemingly if you keep your foot on the gas matching speed or adding It doesn't do it? My persona's doing the same thing but completely different engine and everything It was fine for about I don't know 10K and then was back to the same thing that it was with the other engine at 240k close to it anyway We just gave up We need the car to be on the road not being played with in the parking lot every other day basically a money pit and other things were starting to falter door skins door panels console lid all this stuff is highly expensive or not available now it may be available on clothes out or clearance but that was no help then and now the car is deteriorated even more If I'm lucky I'll be able to use the seats and something else.
  6. bisco
    52,037
    Moderation takes five posts iirc
  7. Mendel Leisk
    41,582
    What's also "normal" is head gasket failure, right around your miles.
    I'd say something" should have been cleaned about 100k miles back, and 50K miles thereafter, but I don't want to wake the dissenters. That cleaning should nclude the intake manifold, which has "something" passages as well.
    With symptoms just starting, I'd:
    Boroscope inspect the combustion chambers, first thing in the morning after a good drive the previous day, looking for coolant pooling atop cylinders, exceptionally clean piston tops, and tears of coolant at the head gasket seam. Pressurizing the cooling system should accelerate formation of the latter.
    If coolant is seen, I'd do the head gasket replacement, using the full Toyota gasket kit, and new head bolts. Timing chain is likely fine, and it's guides. Check the head and block for flatness against specs. Spray copious brake cleaner (it evaporates fast) into the the upside down head, to see if any of the valves leak.
    If the valves leak and/or the head is out of flatness specs, you may need to enlist a machine shop. Some do that anyway, and supply them with replacement valve guide seals. All of that is in the aforementioned gasket kit.
    Watch lots of videos, Gasket Masters, Sane Auto, Auto Scholar with Mr B, and so on. My signature has various relevant links. Last one is the full engine section from gen 3 Repair Manual, has spec's, torque, tons of info. (if you're viewing on a phone, turn it landscape to see signatures.
    Regarding piston/ring replacement: how's the oil consumption. That said, your year does have the low-tension piston rings, and they are prone commence oil burning right around your miles, and when you've already got the head off, it might be prudent. It "is" possible to separate the upper oil pan, disconnect the piston arms from the crankshaft, and push them out. This guy's video is invaluable, recently linked in post by @rjparker. He does pull the engine, mounts it on a stand.
    If and when you get the head gasket done, it's worthwhile to replace the water pump, and do a full clean of the EGR system (oops). Top two links in my signature have info on the latter.
    Not sure if I've linked this in my signature; attached TSB has the gasket kit, head bolt and piston/ring part no's.
    #7 Mendel Leisk, Feb 21, 2025
    Shooter8 likes this.
  8. Shooter8
    central Arizona
    2013 Prius v wagon
    Engine oil gets VERY black after 3500 miles, which is why I change the oil at 3500 miles. A service writer told me that oil is very good and can work well when black. The oil starts at medium amber. It's murky black in the drain pan but not so bad on the dipstick.
    #8 Shooter8, Feb 21, 2025
  9. Shooter8
    central Arizona
    2013 Prius v wagon
    It lasted only 5-10 seconds. Then idled OK.
  10. ASRDogman
    7,635
    3,931
    :eek::eek::eek:(n)(n)(n)
  11. Shooter8
    central Arizona
    2013 Prius v wagon
    We skipped some maintenance during 10 years: it has run so well. Scheduled for next week to scope the cylinders and piston heads. Thanks.
  12. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    If the engine is running unevenly, it is necessary to check the fluid levels and their condition.
    Cleaning the EGR is also necessary.
    If there is no damage to the gasket, then the EGR is most likely filled with coke, soot and oil deposits.
  13. Shooter8
    central Arizona
    2013 Prius v wagon
    It rumbled only several times over the past weekend in Cali. Good since then.
  14. Mendel Leisk
    41,582
    Worth noting: Toyota (and the dealerships typically echo this) issued a warranty extension for "issues'. Basically says if if you get code P0401 (EGR valve sticking) or experience knock/shake on cold start, they'll fix it. My Toyota Canada version shows a cut-off of May 24th of 2018 with unlimited miles, and/or 10 years from new purchase or 240k kms (150k miles), as the end of warranty extension.
    But no recommended preventative maintenance. By the time you get either of the above symptoms, you're basically having head gasket failure. Most typically it happens between 150k and 200k miles. Lower usage cars it can happen sooner. @bisco's '12 plug-in was getting shakes at 87K IIRC.
    Toyota has everything sewed up neatly, at least from their point of view. Not sure any of the other companies are any different, so here we are.
  15. Shooter8
    central Arizona
    2013 Prius v wagon
    The rumble occurred several times at start for 5-10 seconds not during driving. It's been good since we returned to AZ.
  16. ASRDogman
    7,635
    3,931
    Because of condensation…
    You should still keep an eye on the coolant level though.
    Brian1954 likes this.
  17. Mendel Leisk
    41,582
    155k miles and no EGR cleaning would have me bracing for the inevitable.
  18. Shooter8
    central Arizona
    2013 Prius v wagon
    We replaced some fluids 3 weeks ago: engine coolant, hybrid coolant, transmission fluid, and brake fluid. I hope I got the terms right. They're all good.
  19. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    Poster child, bam!
  20. Shooter8
    central Arizona
    2013 Prius v wagon
    We took the 2013 Prius to a local shop recommended by a family friend. Seems very busy. After one false start to repair, the tech scoped the cylinders and confirmed that some coolant and oil is leaking thru the gasket. This shop quoted about $4000, including disconnect the hybrid, pull the engine, replace A/C refrigerant, change the oil, machine the head and maybe the valves, and reassemble.
    Why can't the gasket be changed without engine removal? Are these other tasks necessary?
    #20 Shooter8, Mar 10, 2025
