Techstream
Discussion in 'Gen 3 Prius Main Forum' started by raymonty, Aug 17, 2024.
  1. raymonty
    raymonty Junior Member
    Dahlonea, GA
    My Techstream 18 won't access (show) the 'Utilities' submenu from the ABS selection in order to bleed the brakes. Would anyone know why? Thanks.
  2. 6cylinderbike
    6cylinderbike Junior Member
    Hendersonville Tn
    Same here, did you ever find a solution?
  3. ASRDogman
    ASRDogman Senior Member
    7,986
    4,052
    Is it a pirated copy? If so, it’s likely a sub par cable.
  4. 6cylinderbike
    Hendersonville Tn
    Thank you for responding!
    Pirated copy, unless you spend a lot of $, aren't they all? I bought mine on amazon. My cable communicates with the car, and when I click on ABS, it tells me there are no trouble codes. Unless I'm doing something wrong, the "Utilities" tab should be on the left side, but is not an option.
    #4 6cylinderbike, Feb 23, 2025
  5. raymonty
    Dahlonea, GA
    Yes, used an older version. It came on a hard drive and I simply installed the hard drive on a laptop which works perfectly. Cost about $100 though, but worth it for me having two gen 3's.
  6. ASRDogman
    7,986
    4,052
    Most people have the same issue with the pirated copy. Some have better results with a
    better cable. Someone will chime and and let you know which one to get.
    I just purchased the XTools D8, and have had no issues….
    MAX2 likes this.
  7. Abarnabe
    Abarnabe Active Member
    169
    100
    Netherlands
    I had the same issue with a clone mini vci cable, the solution was Tactrix open port cable
    raymonty and Brian1954 like this.
