Lost cabin lighting...
Discussion in 'Gen 4 Prius Technical Discussion' started by PixelRogue, Feb 25, 2025.
  1. PixelRogue
    488
    86
    US
    2021 Prime:
    Hello all. "<strike>THINK</strike> HOPE" I blew the dome light fuse. How? Replacing the rear seat bulb w/slightly larger LED bulb AND the light was on when replacing. All cabin lighting dead mid stream w/LED bulb replacement. This is a recently acquired (nearly mint) vehicle w/less than 25k.
    FUSES BOX LAYOUT
    Fuse box diagram Toyota Prius 50 51 55 (2015 - 2022) relay with assignment and location
    • 19 and 1 are furthest to front of car
    • 36 and 18 are closest to driver
    • Left row (19-36) appear to be accessory fuses only powered when vehicle is on.
    • Right side (1-18) appear to be always powered. Center pole for power.
    Photo of cabin fuse box untouched, and a few fuses were empty.
    • #19: 7,5A FOG RR – Rear fog light
      Not equipped, no light on light probe when car is on.
    • #08: 10A TAIL – Side light, rear fog light, front fog light, backlight
      Unclear ~ Side light turn signals in the mirror? If so, not equipped.
      Rear fog light ~ Not equipped.
      Backlight ~ what is that?
      Light probe shows light, always on
    • #09: 20A DOOR – Window regulators
      Windows (and their respective buttons) seem to work fine? What are window regulators?
    • #14: 15A WIPER RR – Rear wiper and washer
      Not equipped.
      Light probe shows light, on.
    DOME FUSE
    My understanding is it is a 7.5 fuse (brown,) which looks to be third from the top on the cabin fuse box lid (number 21 according to Toyota numbering.) If this fuse is removed, noticed no backup camera. Replace fuse, backup camera restored but still no dome light. Something else going on?
    Observations for trouble shooting
    • Cabin lights in general worked fine even when bulb was missing from rear dome light.
    • When accessories are on, light probe lights up for every fuse EXCEPT 19-24, and 1-5;
      functions work fine so do not know why light probe does not light for these fuses?.
    • Removal of fuse taps (see dash cam below) reflect no change.
    DASH CAM FUSE TAPS
    Including here as others have been posting unanswered questions on which fuses to tap...so to help anyone following even though the world has moved onto Gen5.
    • #26: 15A RADIO – Audio system, monitor, navigation
      Accessory power wire
      Always on wire (parking monitor w/auto off battery protection.)
    WILD CARD
    Obviously, since the loss of light was immediate to the slightly oversized LED going into the rear dome light while the power and lighting was all on, this clearly looks like a blown fuse. That said the Dome Light fuse has been replaced and still not cabin lighting.
    Few days back I installed recessed trunk lighting, tapped off the luggage light. This was all working just fine w/o issue. Including the context as possibility something else happened that would cause the cabin lighting to fail, and more of a coincidence to timing of flown fuse - or possibly something else got blown instead. Honestly though low voltage LED and wire (and we are talking about very small wire)
    Also worth mentioning I'm a novice around auto fuses. I have the light probe, and a Kaiweets multi-meter, yet I'm not all that great with the meter even after all the Youtube rabbit holes.
    What would you do next to isolate the issue?
  2. BiomedO1
    3,941
    2,070
    SacTown, Ca
    Put the old incandescent bulb back in, to see if it works or you blew something. Isn't that on a 3-position switch, off, door, and on? See if you can get it to work in the ON or door positions. I think to activate, it closes a ground path, so if you broke or disconnected the ground path - it won't work.
    Hope this helps....
    FWIW, be careful with those simple light probes; you can pop an ECU if you get on the wrong circuit path.
  3. PixelRogue
    488
    86
    US
    "FWIW, be careful with those simple light probes; you can pop an ECU if you get on the wrong circuit path."
    For real? Something so simple and effective? I'm ok switching to multimeter just need to know it better.
    Yes, tried reverting back to incandescent bulb however the replacement (tried two different types, both slightly larger) stretched out the connector a little so old bulb falls right out. NOW, my thinking here is that the other lights should work either way - nothing requires the back seat dome to run.
    Yes, tried anything to get any light to work on its own... in all switch positions (driver dome, read dome, luggage light in trunk) - and jumping the bulb.
  4. BiomedO1
    3,941
    2,070
    SacTown, Ca
    Yes, the correct way to use it, is to clip to a ground point and look for voltage. I've seen people clip to +12VDC probing for ground point. Obviously, introducing 12 volts onto a 5 volt or 3 volt circuit line can pop something - depending on if your down stream or up stream of the circuit protections.
    While shunting to ground is always the safer option. You can also take advantage of the probe by offering the circuit an alternative path to ground. Since almost all lamps are on a 12V circuit, poking around there shouldn't be an issue - but blindly poking a wire/circuit may pop something.
  5. PixelRogue
    488
    86
    US
    I was keeping the clip grounded and hunting for ACC and 24/7 power and dead fuses. Can't find a dead fuse, don't understand why the cluster of fuses listed above don't light the probe up, and have no interior lighting. Took the car for a drive and everything else seems unaffected. Do not think it would be a short per-say (I mean, I can't imagine anything broke or got pinched.) That said, these are about the thinnest wires I have personally seen - these light wires...hope I didn't break something?
    Would you know of ways to test (ie continuity) to determine the light wiring itself is ok? I'm puzzled no doubt, and this is all after I thought I was out of the woods... project was wrapped up and done...just to put in that forgotten LED.
  6. PixelRogue
    488
    86
    US
    #6 PixelRogue, Feb 27, 2025
  7. BiomedO1
    3,941
    2,070
    SacTown, Ca
    If you still got the LED bulb in there, turn it around. LEDs are polarity specific - incandescence aren't. Use a DVM to check continuity and voltage.
  8. PixelRogue
    488
    86
    US
    No bulb in there atm - and appear to have lose the hybrid system so problem expanded. Think a reset should restore the hybrid system, then back to the lighting issue. Thought LED auto bulbs 'didn't' have polarity?' Nothing on the bulbs I can see indicating one side from the other (talking all cabin bulbs that were replaced w/LED. Doubt they were all done randomly correct. The passenger bulb was the only 'odd' one that required a special order (never understand things like that ... where all bulbs are identical but on odd one out. CAn't see a single reason why the rear cabin dome light would require a different dome bulb than rest of the car - or why it couldn't match the front dome light bulb.)
  9. PixelRogue
    488
    86
    US
    Realized I had been posting the thread in the wrong forum:
    2021 Prime: Cabin Lighting Gone | PriusChat
    In short, switched out an LED above back seats and lost all cabin lighting. Pretty sure the fuse itself is fine and wondering what else to look into (personally, not hire it out) to get it working again.
    @Mendel Leisk Meldel, you are wealth of knowledge AND connections. If this topic isn't of interest would you know another person or two I could ask to join the thread? What I have noticed is that I'm not the only one who lost their cabin lighting due to changing out that bulb - BUT - haven't found any fixed or solutions myself nor posted.
    MrFixer likes this.
  10. bisco
    52,188
    Would it be worth it to replace the fuse just to be positive?
  11. MrFixer
    MrFixer New Member
    UK
    2020 Prius
    Excel
    I would suggest using a voltmeter to do some faultfinding (maybe buy yourself a cheap digital multimeter so you can measure voltages and resistances). Check the fuse for continuity. Check for voltage on the hot side of the fuse. Check for power and ground (good continuity to chassis from the bulb ground pin) at the bulbholder etc.
  12. PixelRogue
    488
    86
    US
    Yes, done that several times...several new fuses out of desperation.
  13. PixelRogue
    488
    86
    US
    Listening. Have a good mutli-meter albeit I'm a novice w/it even after all the youtube videos and the like.
  14. Tideland Prius
    16,588
    *Merged threads*
    PixelRogue and bisco like this.
  15. bisco
    52,188
    Are you sure the fuse isn’t blowing each time you replace it?
  16. PixelRogue
    488
    86
    US
    The original fuse looks fine (no break.) Tried a few new ones and would expect to see a spark, hear a pop or something to indicate something not working (or cabin lights flash on for a moment before fuse blows.) That would be a step in the right direction and looking for a short.
  17. PixelRogue
    488
    86
    US
    Thank you for merging and moving the right spot.
  18. PixelRogue
    488
    86
    US
    Anyone able to confirm the 7.5 fuse (21) is for dome light? One observation is that removing fuse 21 disables the rear view camera...put the fuse back in and rear view camera working as expected. I would be surprised if cabin lights and camera were on the same circuit; i did test other 7.5 fuses and nothing noticeable.
    If fuse 21 is for the dome light, then thinking there is a broken common or ground (?) as the fuse itself is working as expected.
    For getting back to the starting point, the original non-led bulb is in place btw (and not broken.)
    EXCELLENT resource for identifying fuses...and looks like I was at the wrong end for dome light. Let's see...
    2021 Toyota Prius fuse box diagram - StartMyCar
  19. PixelRogue
    488
    86
    US
    Wrong fuse.... dome lights are BACK!
    Thank you to those who chipped in to help... love Prius Chat.
