EGR Cooler Hose
Discussion in 'Gen 3 Prius Technical Discussion' started by DPZ, Feb 25, 2025.
  1. DPZ
    DPZ Junior Member
    Arizona
    I am so disappointed in myself. I am doing an egr cleaning and when I went to remove the hose from the top of the EGR Cooler the hose spring a pinhole leak. The stupid hose is about 3 to 4 inches long and has about a 40 degree turn in it. I think it attaches to what is called the Water joint that has a sensor on it.
    I think the part is 87245-47270
    Can anyone confirm the part number and /or a way to repair this with out buying the the hose at the dealership?
    Thank you
    #1 DPZ, Feb 25, 2025
  2. ASRDogman
    ASRDogman Senior Member
    7,818
    3,982
    The dealership is NOT stealing from you. You do NOT have to buy from them.
    IF you want the part from them, it will be X amount. You give them the money and they give
    you the part. There is NO stealing involved.
    Georgina Rudkus likes this.
  3. DPZ
    DPZ Junior Member
    Arizona
    Ok please ignore the "stealership comment" do you have a fix? Can you comfirm the part number?
    Thank you
  4. ChapmanF
    18,538
    Some dealerships will not-steal-it for you at a lower price than other dealerships. At autoparts.toyota.com you can probably pull up that part number and see a range of prices from some different dealers.
  5. Mendel Leisk
    41,900
    Looks like the correct part number. I followed a bit of a trail:
    Radiator & water outlet for Toyota Prius ZVW30L - Auto parts - Amayama
    Exhaust gas recirculation system for Toyota Prius ZVW30L - Genuine parts - Amayama
    Heating & air conditioning - water piping for Toyota Prius ZVW30L - Genuine parts - Amayama
    And on that last one, for item 67246A:
    Buy Genuine Toyota 8724547270 (87245-47270) Hose, Heater Water, Outlet. Prices, fast shipping, photos - Amayama
    For me on West Coast Canada, shows as $3.89 USD, with shipping "to be determined". Which might be around $10? In that scenario in past they've advised, to "complete" the purchase, and before you're commited they will get back to you with a quote for shipping, and it's up to you if you want to accept.
    MAX2 likes this.
  6. DPZ
    DPZ Junior Member
    Arizona
    so no superglue then
  7. DPZ
    DPZ Junior Member
    Arizona
  8. Mendel Leisk
    41,900
    Just check the ID. Or the OD of what it pushes onto. And the angle it deflects. It should be slightly on the tight side I think. It'd be advantageous to get one with the legs a little longer: you can always trim them, with a hacksaw or what have you.
