CQ3 charging tips, problems and question
Discussion in 'Gen 3 Prius Technical Discussion' started by Seymour1, May 18, 2024.
  1. Seymour1
    Seymour1 Member
    266
    32
    I have CQ3 chargers. I was getting some strange results in the recorded data. The charge and discharge readings would go up, way down and up again on the same modules. I could not tell a good module from a bad one. I felt that using alligator clips was not good. I then noticed that the banana plugs have a swivel in the end of the 4mm plug.
    I took my old bus bars and soldered the charger wires onto them and attached each bus bar to the screw studs on the modules. And, I soldered the swivel on the banana plugs to solder bridge the swivel.
    The CQ3 delta peak responds to a very small fraction of a volt. Thus, the connections must be consistent and solid from the charger to the battery modules. When measuring the discharge capacity, the amount of the previous charge is important. Sometimes, for some reason, (bad connections?) the charge did not reach the full amount (7500mah). If this happens, expect that the subsequent discharge reading to be reduced. And, due to the self-discharge nature of NiMH batteries, do not run a discharge/charge cycle, wait a day or two and then expect to get the highest discharge reading. I made that mistake.
    With good solid battery-charger connections, it seems that almost all of my charge cycles go to the maximum of 7500mah. Therefore, it does not go past the first cycle. I must monitor the charger and manually restart it for multiple cycles. The delta peak is set to default which is maybe too insensitive? Maybe the CQ3 is not detecting full charge or maybe all of my modules are faulty. Any ideas?
  2. 9Shenandoah
    9Shenandoah New Member
    22
    Washington State
    2014 Prius c
    Having the same issue myself, always get the Capacity message. This is really slowing the process down.
  3. Tim22B
    Tim22B Junior Member
    Madison Wi
    Same here. What did you come up with a solution, or did your soldering solution work?
    Please give us an update.
  4. bisco
    51,829
    Is gen 5 already having battery problems?
  5. Brian1954
    Brian1954 Senior Member
    2,135
    826
    South Central PA, USA
    I reported this thread to the moderator and asked that it be removed to the Gen 3 forum. The OP owns a Gen 3 Prius.
    Bill Norton, bisco and Mendel Leisk like this.
  6. KyleW
    KyleW New Member
    Kansas City
    @Seymour1 Thanks for the tips above. Any progress on getting the CQ3 to work more effectively? I've hit CAPA a few times now and it's definitely slowing things down.
