2010 Prius w/ NexCell Lithium Throwing Codes
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by addyspriusIV, Feb 23, 2025.
  1. Hayslayer
    Hayslayer Active Member
    390
    219
    I'm sorry, but based on my thread readings a couple months ago about this battery, weren't YOU one of the posters who insisted over and over and over and over and over there was no problem with the lithium battery? Insisted it was the greatest thing ever manufactured? Did your best to sell it at every opportunity so you could make a dollar kickback? Is that being a cheerleader?
    Thank God we had you to cheerlead this battery and all those other little "upgrade" devices you have affiliate links for on every post.
    You must feel very accomplished for helping to fool so many people about so many "upgrade" products.
    I can only imagine what kind of person you are in real life, anything for a dollar, right?
    YOU TRULY deserve any karma to match what YOU help put out into the world.
    Just wish you had more real-world knowledge and weren't so gullible that you believe everything a manufacturer tells you.
    See how those statements of yours can be made to fit?
    bomb_baby8 and Grit like this.
  2. AzusaPrius
    AzusaPrius Senior Member
    2,179
    918
    Sorry Naysayer actually what you are doing is cheerleading.
    You couldnt come up with something on your own, so you copied what I already did.
    Yeah thats cheerleading for sure.
    I have used all versions of lithium and had no issues, I can speak from experience.
    Can you?
  3. Hayslayer
    390
    219
    Yeah, Az(clown)usaPrius, my experience in life tells me you're a capital L.
    See, we can all play word games.
    Grit likes this.
  4. AzusaPrius
    2,179
    918
    Difference is when you are not good at it, you should sit back and just let the experienced handle it.
    I guess you actually think you are good at it, so carry on and let others see your great work.
  5. Brian1954
    Brian1954 Senior Member
    2,167
    843
    South Central PA, USA
    Can you please explain to the OP why Jack no longer sells the Nexcell Lithium version of the battery?
    Grit likes this.
  6. AzusaPrius
    2,179
    918
    Actually he still sells them without warranty, as he has moved on to sodium.
    Still a great option over stock.
    But sodium is way better in colder climates. Screenshot_2025-02-26-14-41-02-1.jpeg
  7. Brian1954
    2,167
    843
    I was wrong. Thank you for clarifying that they are still being sold without any warranty.
    Please explain for the OP all the reasons why the shift was made from Lithium to the Sodium Battery?
    Grit likes this.
  8. AzusaPrius
    2,179
    918
    I feel as though I am explaining it to you.
    The switch was made because sodium is more robust and can take the cold better.
    The power curve is like OEM and does not overcharge on long regen cycles like lithium and when it does it burns it off automatically and goes into what called super mario mode all EV until you drain it back down and goes back to normal.
    No codes, no crazy up and down cycles of the battery being unbalanced when overcharged.
    Brian1954 likes this.
  9. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    No way!!! Azusa brought receipts here that it worked great in winter!
    bomb_baby8 likes this.
