P0301: Engine shaking, run rough
Discussion in 'Gen 3 Prius Main Forum' started by imdfrnt, Feb 28, 2025.
  1. imdfrnt
    imdfrnt Junior Member
    Montreal, CAN
    Hello everyone!
    Yesterday morning I started my car and a few seconds later, the engine started running strangely. It vibrates, runs hard.
    I stopped the engine and started it again: everything is fine!
    So I go for a ride around the block and at the first stop... it starts again (except this time the check engine light comes on). I look for the error code and it's P0301.
    My prestone level remains unchanged.
    I reset the error code before making the following replacements:
    I changed the ignition coils and spark plugs.
    Unfortunately, the engine still vibrates when starting (sometimes).
    In traffic... it can start to sputter randomly again.
    If I press the gas pedal even a little, it returns to normal.
    After about 90 kilometers (about 56 miles), as soon as I stop and start again, when accelerating it gives a knock (seems to come from the transmission?!?) around 30kph (18mph) everything returns to normal.
    The check engine still hasn't turned back on despite the things I've noticed since replacing the coil packs and spark plugs.
    I don't really know what to look at anymore... since it seems like there are two problems at the same time:
    1- the engine seems to start vibrating as soon as it goes from EV mode to combustion mode.
    2- When I start accelerating, it gives a knock up to about 30kph (18mph)
    If anyone has any ideas... what to check...
    (Prestone level is good, no prestone found in the oil).
    Thanks in advance!
  2. MAX2
    MAX2 Senior Member
    1,436
    486
    101
    Third planet from the Sun
    Code P0301 indicates problems in the first cylinder.
    Have you inspected the spark plugs, checked the coils?
    It may also be a problem with a broken head gasket, when the coolant enters the cylinder drop by drop.
    You can inspect with an endoscope on a cold engine for drops on the cylinder walls.
  3. Mendel Leisk
    40,878
    Save the old coils. What’s the miles?
  4. imdfrnt
    Montreal, CAN
    230 000 miles
  5. imdfrnt
    Montreal, CAN
    Before replacing them all… I switched the first one and put on the cylinder 2 and the coil no.2 at the first cyclinder (the problem remain without any check engine)
    #5 imdfrnt, Mar 1, 2025
  6. imdfrnt
    Montreal, CAN
    So… its now confirmed… Head Gasket…
    I started my car this morning so I could clear the driveway. When I started it, the strange sound came back at the beginning and stopped like 30 sec later.
    And 5 minutes after starting my car, I looked at the prestone level.
    It went down below the "low" line. Which has never been the case with my car.
    Mystery now solved
    Brian1954 likes this.
  7. Mendel Leisk
    40,878
    The misfire stayed on cylinder one? Yeah that would indicate problem is the cylinder.
  8. rjparker
    9,799
    6,041
    Not much of a mystery, thousands have been there done that with gen3.
    The real issue now is a $2k head gasket gamble or a $3500 rebuilt engine sure thing?
  9. imdfrnt
    Montreal, CAN
    Honestly… I think it will go to the scrapyard or I’ll buy a used motor from Japan…
    Not sure about that at this moment.
    The car is rough and the body too…
  10. Grit
    Grit Senior Member
    6,550
    4,221
    Wilkes Land
    What’s prestone?
  11. rjparker
    9,799
    6,041
    MAX2 likes this.
  12. imdfrnt
    Montreal, CAN
    More rationally...
    Normally, the prestone would have mixed with the oil and would have increased the quantity (the excess prestone should increase the quantity of oil?!)
    Because currently my oil level has not moved.
    Could it be that it is the EGR that causes this noise?
    I am trying to understand because normally an HG will cause the presence of prestone in the oil and at least increase the level abnormally...
    in the link, the sound of my vehicle when started:
    https://share.icloud.com/photos/003L6hP9ysy6qdd490tE-KoBQ
  13. rjparker
    9,799
    6,041
    In these Prius gen3s with hg problems it is normally a slow leak manifesting as drops between a cylinder coolant passage and the cylinder. Most of the time that leak does not continue into the cylinder long enough to accumulate and drain past the rings to the sump. It burns off and goes out the exhaust.
    An advanced case can accumulate and hydrolock the piston but the strong mg1 torque will simply bend the connecting rod, occasionally exploding it through the block.
    Shudder video
    “Hey Walt… they want to wait and see if it gets worse…”
    Best HG Diagnostic
    Car Care Nut HG Borescope at 660 sec
    #13 rjparker, Mar 2, 2025
    MAX2 and imdfrnt like this.
  14. Mendel Leisk
    40,878
    Not with 3rd gen Prius. The EGR causes clogs, head gasket fails (typically starting on cylinder one, and the failure is typically coolant leaking into the combustion chamber(s).
    Bill Norton and MAX2 like this.
  15. imdfrnt
    Montreal, CAN
    It seem to be my case
    Thank alot for your answers ✌
  16. Mendel Leisk
    40,878
    Info in my signature (on a phone turn it landscape to see signatures).
  17. Bill Norton
    Bill Norton Senior Member
    2,136
    730
    MONW, Ks.
    I'm at the very first stages of coolant use and twice it had a misfire during light acceleration.
    I know it's the head gasket failing at 167k miles on my '10.
    I'm having Gasket Masters replace it for ~$2000. Much cheaper than a dealer or independent shop.
    With buyin a used engine, you have a Used Engine. Won't you feel silly when that head gasket goes bad?
    There is an American made FelPro head gasket that hopefully is better quality than the OEM.
    Grit likes this.
  18. Mendel Leisk
    40,878
    Maybe "shooting the messenger". Toyota makes a gasket kit, which includes the head gasket (and it's been revised), plus most every other gasket, o-ring, and seal you're likely to encounter, plus valve stem seals, and they're all OEM. FelPro also makes a "kit", but apart from the engineered head gasket, it's mostly "this'll do", and much less complete at that.
    It might be prudent to replace head bolts too. Part no's for aforementioned in attached.
    Keep your fingers crossed with gasket masters, and hopefully it goes smoothly. I've heard their follow-up relations can be testy...
    bobby515 likes this.
  19. imdfrnt
    Montreal, CAN
    I’ll go for a used motor… since mine is now cracked in the base. I’ve find a smashed prius from the back with 103 000km. So I will be able to clean properly the EGR etc… and put them back.
    Bill Norton likes this.
  20. rjparker
    9,799
    6,041
    I would get a JDM engine instead of a North American used motor. JDM gen3's used in Japan could be as new as a 2021. Search JDM engines. But it is certainly your choice.
    bobby515 and MAX2 like this.
