4th Gen DIY heat exchanger bypass solution
Discussion in 'Gen 4 Prius Main Forum' started by texasdiver, Jul 28, 2022.
  1. ChapmanF
    17,735
    The ECO mode doesn't change anything about where the hot coolant physically comes from. It just slightly lowers a software limit on how hard the system will blow the heat at you. (It also rules out the use of the supplemental electric heat before the engine warms up—at least in gen 3. As far as I know, gen 4 also has the electric heat and this is probably the same.)
  2. al espenschied
    al espenschied Junior Member
    Ohio
  3. vvillovv
    vvillovv Senior Member
    4,320
    1,508
    NY
    I'd recommand you check your muffler for coolant like Gasket Masters showed in their video.
    All you have to do is giggle the muffler and if there is coolant still in there you should hear it sloshing around in there.
    There are others on this forum that think the muffler gets hot enough to boil that coolant out of the muffler.
    But to me, that just sound like some mechanic double talk to a customers question about what to do with any possible coolant in the muffler.
    It's a simple check.
  4. ChapmanF
    17,735
    My muffler is too serious for that.
  5. Mendel Leisk
    40,972
    Just for jiggles, giggle the muffler.
    douglasjre and vvillovv like this.
  6. BiomedO1
    3,125
    1,658
    SacTown, Ca
    Every Prie deserves a good belly rub, just don't do it when it's hot....;):p:cool::ROFLMAO::LOL:
  7. vvillovv
    4,320
    1,508
    NY
    Is it hot anywhere? gigglin the muffle kin not makin strange Prii sounds nobody's ever heard before. Or is it?
  8. sc91
    sc91 New Member
    Midwest side
    2018 Prius
    Does anyone know if the "new" part specified in the TSB (17410-37D40) actually fixes the issue? I ordered one during the 25% toyota parts promo a couple weeks ago, I got it for $6XX, but don't have it yet. I expect Toyota to put this on for me for free, so that will be an interesting conversation. :sneaky:
    However, I can't seem to find a lot of info on what the actual "fix" is. Can anyone point me to a thread I may have missed on it?
    I've an '18 with 41k and worry about this leak - I'm taking a picture of coolant level each week to compare level falling, and bought a scangauge to monitor water temp. Unfortunately, Scangauge cuts out everytime ICE goes off, so Scangauge and Prius don't work great together.
  9. Mendel Leisk
    40,972
    Might be gen 4 is problematic with Scangauge, not sure. I was using a SG II with gen 3, and one of the settings was expressly for hybrids having engine shut off. Check the SG documentation for that.
    #149 Mendel Leisk, Mar 27, 2025
    BiomedO1 likes this.
  10. Havik
    Havik New Member
    Netherlands
    2018 Prius
    Hello sir,
    It is a long shot, but since I live in Europe, the Netherlands, and bought a secondhand Prius 2018 with low miles, I thought maybe I could ask you how you managed to get the part replaced under warranty, since I read that some folks in Netherlands weren't so lucky. If you would please be so kind to share your experience. Thank you
  11. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    Sorry for late replay.
    I was lucky that the service guy wrote a claim in such a way that it was aproved, don't ask me what he wrote, something about coolant and aircon. I then had another Prius user contct me a couple of months ago with the same problem, he wasn't so lucky, but he insisted and made a complaint directy to the importer and he too was succesful.
    It's a known issue, and Toyota knows it, you must be insistent, but yeah, as a private person it's sometimes not easy, and a layer costs money.
    Havik likes this.
  12. black_jmyntrn
    black_jmyntrn Senior Member
    1,719
    402
    2013 Prius Plug-in
  13. Havik
    Havik New Member
    Netherlands
    2018 Prius
    I am asking as someone quite new on the subject, but could you perhaps mention a few significant advantages of the shown system? I wonder if it is possible to manually activate the fan for the battery.
    Thank you
  14. Havik
    Havik New Member
    Netherlands
    2018 Prius
    I nevertheless thank you for the reply.
    It seems that dealers worldwide are getting confronted more and more with the issue, hopefully making a claim easier nowadays.
    Enjoy your vehicle sir
