Hybrid Battery Reconditioning/Replacement Options?
Discussion in 'Gen 3 Prius Main Forum' started by stokesey, Nov 12, 2024.
  1. stokesey
    stokesey Junior Member
    61
    Southern Cal
    Update on this topic. I received my "B6 V3 smart chargers" after being scammed by one Dhgate vendor. Guy sent some random bullsch*t to Salt Lake City and marked tracking as delivered. Took awhile but I got my money back:mad:.
    The chargers seem to work OK, one issue is that they don't do well charging lead/acid batteries in a car. Error message is "connection break" so I suspect its from inadequate contact. They do support NiMH cycle charging but the balance charging features are only for LiPo batteries with a special connector. I don't know enough about those systems yet to make use of the feature. So I guess I'll use the cycle charging feature with low amp discharge/charge settings. I have a car with a bad hybrid battery but haven't pulled the unit yet.
    Price was right on the chargers and I can include the Dhgate vendor if others are interested.
  2. stokesey
    61
    Southern Cal
  3. MAX2
    MAX2 Senior Member
    1,436
    486
    101
    Third planet from the Sun
    When charging and discharging individual modules, there is no need to disassemble the entire battery, removing all the modules. Modules that are not tightened into the case tend to swell when charging or discharging. Deformation of the plastic leads to loss of the module.
  4. stokesey
    61
    Southern Cal
    Right, I've seen other mention to keep the battery pack clamped together to prevent swelling. Also they said don't charge adjacent modules at the same time and keep the pack cool.
    But the bus bars need to come off, so I guess its still required to pull the pack from the car, right?
  5. ASRDogman
    ASRDogman Senior Member
    7,390
    3,854
    You only have to pull the cover off the top to get to the bus bars.
  6. MAX2
    MAX2 Senior Member
    1,436
    486
    101
    The process of charging individual modules is not a five-minute story. Of course, the battery must be removed and placed in some room or garage where it is possible to leave it under observation for several hours or days.
    An exception when the battery does not need to be removed from the car is the Prolong system, but they are used to charge all modules at once when the car is under supervision.
  7. Ryan Thornton
    Ryan Thornton New Member
    Salt Lake City
    I
    Are you a fan of the Nexpower V3 sodium pack? I’m considering it
  8. ASRDogman
    7,390
    3,854
    Very much so. I'm had no issues with mine. It's extended my ev time quite a bit.
    Increased my city mpg from 38 to 45, without trying. Keeps my highway driving around 48mpg.
    And I didn't drop mpg when it was cold. That really suprised me.
    stokesey likes this.
  9. Ryan Thornton
    Salt Lake City
    I
    Thanks for the response. How long have you had it and did you put it in yourself?
  10. ASRDogman
    7,390
    3,854
    I replaced it in September this year, I did it myself. Fairly easy.
    About 14,000 miles ago.
    The original is very heavy. It's best to have someone help you lift it out.
    Wear leather glove, there are sharp edges...
  11. Omer michaelis
    Omer michaelis New Member
    Israel
    Bought this charger, delta peak for nimh batteries seems to malfunction, mah capacity off was set to 7000 mah yet It charged my module to 9300 mah up until it started making sizzing noises(gas leak noises) and luckily I was there and noticed it. I immediately discharged all those cells but damage was likely done, how much is hard to tell. Does your unit function properly?
  12. stokesey
    61
    Southern Cal
    Gaah sorry to hear that, and good job avoiding a disaster! My chargers are a little wonky too. I am having the "Connection Break" error message a lot. According to some guys on YouTube, I may need to replace a MOSFET on the board. Not looking forward to it. In the meantime, I've found that adding a load to the charging circuit lowers the chance of the error.
    Check the settings on the charger carefully, there is a "auto shutoff capacity(something like that?)" setting that may help with your problem?
  13. ASRDogman
    7,390
    3,854
    :confused::eek: If you play with fire, you're going to get burned! (n):whistle:
  14. stokesey
    61
    Southern Cal
    Oh I see you set max off to 7Ah, that's a problem! Maybe mess around with a spare cell and try different shutoff values?
  15. stokesey
    61
    Southern Cal
    Great to know about the Sodiums. I thought it could be market hype but I guess they are working well. A little suspicious on the short warranty but I guess we'll see about lifetime over the next few years.
  16. bisco
    51,484
    like 20 or so, not to put too fine a point on it
