2016 Prius II cabin heating problem
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by al espenschied, Mar 2, 2025.
  1. al espenschied
    al espenschied Junior Member
    Ohio
    Hello all,
    The last couple days we had a cold snap in Ohio. Yesterday, I noticed my cabin is not warming up as usual. Today, I research a little and found This Thread about a recall including my model regarding the heat exchanger within the exhaust. Although I do not have loss of radiator fluid, I have many of symptoms reported by others on the thread. So I thought I'd post for input from others before implementing the work around on pages 2-3 of that thread.
    I did a little investigating. Normally the Prius warms up within 10 minutes, even on the coldest days, whereas the past 2 days it is about 33F at the time I drove it, not really cold for such a slow warm up. I check the fluid level in my radiator reservoir on the right side of the radiator,, it was down only slightly from, just below the "low" line which is on the right side as one faces the engine compartment. The other reservoir, on the left, I assume is overflow, is empty as far a I can tell. I added a small amount of radiator fluid , maybe 5 ounces to bring it up to the "Full" mark.
    I drove the car in stop and go traffic for 25-30 minutes before feeling warm air come from the floor vents with the control set on "HI". Then I kept checking the vent by feeling it and noticed that when the ICE was running, I would get warm air shortly after it started and when in EV mode, it would return to cold in a few moments after the switch., at 35 minutes I parked the Prius for 90 minutes and returned home with a 10 minute drive. Same this happened: I drove it up to 55 mph, the ICE engaged warm air again, back in town, at stop lights and EV mode cold air again. I turned on the front defroster for a minute, it was also blowing cold air on the windshield. Any comment would be appreciated. The car has no service problems previously of any kind and currently has 187,300 miles.with a lifetime MPG of 62. I don't notice a change in MPG yet as the problem is new.
  2. vvillovv
    vvillovv Senior Member
    4,320
    1,508
    NY
    Get a modile app for your phone. The car scanner app shows the coolant temps !
    You'll need a ODB2 adapter to plugin to the cars ODB port under the dash below the steering wheel.
    These are some of the adapters the developer of the app explains ...
    Choosing OBDII adapter – Car Scanner ELM OBD2
    Gen 4 prius ( in my experience ) finish their warm up cycle when the coolant reaches 132 F ( 55 C ).
    I don't know why it's taking longer than usual to reach reach warm air from the heater for you :oops:
    So keeping track of the cars coolant temp when the heater starts blowing warm air might help narrowing down what's going on.
    It should only take a mile or two (at slow speeds ) for the Gen 4 to finish it's warm up cycle and start blowing warmer air. That is if you wait before you turn on the heater until the coolant has had a chance to warm up some.
  3. al espenschied
    Ohio
    Thanks. I want to see if I have any codes or errors. There are no trouble lights displayed currently.
  4. al espenschied
    Ohio
    I checked fluids again, added about 1/2 quarts of engine coolant and now everythings back to normal as far as I can tell.
  5. BiomedO1
    3,125
    1,658
    SacTown, Ca
    Your engine coolant tank is on the passenger side of the car. The coolant tank near the battery is your EV inverter coolant tank. Both tanks needs to be near the full mark on the tank.
    You need to check both tanks every few days to see if you got a leak. They shouldn't be going down!
    Hope this helps...
    Check your operators manual if you don't know how to check your coolant levels.
    Brian1954 likes this.
  6. al espenschied
    Ohio
    yes, the problem is I hadn't really checked the engine coolant level for almost 9 years. I did top it off, but plan on changing both coolants soon, probably tomorrow.
  7. BiomedO1
    3,125
    1,658
    SacTown, Ca
    FWIW; Toyota maintenance manual states that the engine coolant should be changed at 100K, then every 50K thereafter. Coolant becomes acidic if it stays in there too long. That'll effect your sealing rings, gaskets and eat away your internals. Old timers like myself do a litmus test to prove that coolant needs replacement.
    Hope this helps.....
    Inverter coolant replacement is 150K
  8. al espenschied
    Ohio
    it does help, thanks.
  9. MrFixer
    MrFixer New Member
    UK
    2020 Prius
    Excel
    In your original post you describe the coolant tank on the left (as you face the engine) as being empty. That is your engine coolant. Poor and intermittent heater output is a classic sign of low coolant. I think you have a leak. To confirm, I would check the coolant level in the left tank on a daily basis with cold engine.
  10. al espenschied
    Ohio
    Thanks, MrFixer, I found the radiator reservoir tank empty and topped it up with prestone for asian cars cooling fluid and a couple days later drained and filled with toyota cooling fluid. After driving it for a couple days now, I am seeing no reduction in volume in the reservoir. Since I had not changed or topped up the fluid in almost nine years, it was just low due to evaporation, or a leak so slow, it makes no noticeable change to performance. When I topped it up with the prestone, it was less than 1/2 gallon, and my heater was working again immediately.
  11. al espenschied
    Ohio
    I discovered that I have been losing coolant yesterday. Today I called a toyota service center. They seemed to never have heard of this issue and noted for me that they did not see this notice so they could not perform the tests it recommended, only could schedule it in for a diagnostic. I scheduled it.
  12. bisco
    51,522
    print out the exhaust coolant heat exchanger tsb and take it with you
  13. BiomedO1
    3,125
    1,658
    SacTown, Ca
    Which one is going down? If it's the engine, passenger side coolant bottle, most likely the exhaust gas heat exchanger is leaking. That failure could be covered warranty. It's part of the catalytic converter assembly, so it may still be under warranty. Check your states emissions control laws.
    Our state has the toughest emissions standards in the country; so our is warrantied for 180 months or 150K miles. I believe the Federal warranty only covers you out to 80K miles.
    Hope this helps....
  14. al espenschied
    Ohio
    Thanks folks. In June I asked the Toyota dealer service center to perform the check listed in the tsb that I showed them. After performing the check, the service manager stated that the heat exchanger in the catalytic converter was leaking but she would not rule out a failed head gasket. I told her to order the redesigned part for the exhaust manifold w/ catalytic converter and heat exchanger. It was back ordered and was received in early July. They called me and it was replaced in mid July. Everything is working fine after the replacement with no loss of fluid. It only took 1/2 hour to replace. They also changed out my reservoir tank for weird reason I couldn't understand, saying that it was 'leaking' but there was never any fluid on my parking spaces nor on my garage floor.
    It was at around 188,000 miles I noticed this problem. I now have 201,200 miles. I need to replace my tires and will probably replace my TPMS transmitters as well. This set of Continental True Contact Touring tires currently have 92,000 miles on them, they are down to wear bars but they still have tread with no bare spots. The entire life of these tires were run at 40 psi, which I believe is the maximum sidewall pressure.
    If I were to do this job again, I would ask for the used heat exchanger (it was worth $41.00 from the metal recycle company) and I would have asked for the left over coolant (they billed me for 2 gal of coolant, it held just under 1 gal.)
    Thanks for all who replied.
    #14 al espenschied, Sep 18, 2025
    bisco and Brian1954 like this.
  15. bisco
    51,522
    congrats, thanks for the update!
    al espenschied likes this.
  16. BiomedO1
    3,125
    1,658
    SacTown, Ca
    The max pressure on those tires are probably closer to 50+psi; it's usually printed on the tire itself somewhere. I also run mine at 40 psi all the way around and mine are 55 psi max. It's a good idea to replace your TPMS every other tire replacement. Good OEM equivalent sensors will last 10+ years. Cheap low quality TPMS replacements usually will only go about 3 years before they die.
    Glad you resolved your issue......
