My new Prius Prime electrical system would not turn on at start up
Discussion in 'Gen 5 Prius Main Forum' started by Keith S., Apr 13, 2024.
Tags:
  1. Keith S.
    Keith S. New Member
    Los Angeles
    2024 Prius Prime
    Has anyone had a problem when they try to start up their Prius pushing the Start button and brake pedal but nothing happening or in my case a very dim and flickering image of my car on the display is all that happened and the car nor accessories would turn on. My traction battery was at 100% from charging the night before. I tried using my phone Toyota app but it would not connect with the car.
    I contacted Toyota road side assistance and they sent someone out right away, He confirmed that my traction battery was fully charged at 100% but after some trouble shooting, he said the new 12 volt battery was partially discharged and that may have been the reason I was getting a weak flickering image on the display when I tried to start the car. He charged it up and my display and other functions returned to normal. I checked to see if I had left the lights or accessories on but everything looked like they were off and so did not discharge the 12 volt.
    I tried to figure out why the 12 volt had discharged. Background: I have put just a little under 1000 miles on the car with most of it from EV driving, only ~100 miles coming in ice mode. At first I thought since I did not use ice much that maybe the 12 volt just weaken and just needed charging to bring it back up to within normal range but then I thought I heard that the Prime does not have an alternator and that the 12 volt was replenished from the traction battery. The only other thing that came to mind was that it was a defective 12 volt. I am going to take it in to the dealer but I thought I would run it by other Prime owners
    Thanks for any comments you may share!
    Gokhan likes this.
  2. Mendel Leisk
    41,711
    There’s lots of threads here on 5th gen Prius with the plug-in having discharged 12 volt batteries, . One possibility is due to leaving the high voltage cable plugged in for a protracted period after charging; the car seems to keep monitoring stuff, running the 12 volt battery down in the process.
    GcinFl likes this.
  3. hill
    8,858
    Does Prius do over the air updates yet? Haven't been able to find anything to that effect.
    Gokhan likes this.
  4. bisco
    52,135
    no, but why would that matter?
    Gokhan likes this.
  5. bisco
    52,135
    Brian1954 and Mendel Leisk like this.
  6. PriusCamper
    PriusCamper Senior Member
    12,903
    5,234
    Pacific Northwest, USA
    That's like telling people to read the owner's manual... It just ain't gonna happen.
    hill, Brian1954 and Blackat like this.
  7. Gokhan
    Gokhan Senior Member
    6,375
    2,545
    Paramount CA
    He means that perhaps you could solve the battery-drain problem with a software update, like the battery-drain problem for iPhones.
    This is actually a good idea. While probably there is little a software update can do to reduce the drain, it could have pop-up warnings to the owner, such as "lights draining the battery," "AC cable plugged in for too long," "battery level getting too low—keep the car in the READY mode at least for an hour," "check for third-party accessories draining the battery," etc. Such warnings could reduce the number of instances of 12-V-battery drain tremendously.
  8. Gokhan
    6,375
    2,545
    Paramount CA
    The car needs to be driven regularly for long distances. The 12-V battery only charges when the car is in the READY mode. You could charge it through the lithium-ion battery (if it has charge) by switching the car to the READY mode in the EV mode, even without driving the car. You could also do that in the HV mode, but that's not recommended as it would fill the garage with exhaust fumes.
    Also, do not leave the AC charger plugged in for longer than overnight. That drains the 12-V battery.
    Not leaving the lights on unless the car is in the READY mode is also important.
  9. Keith S.
    Keith S. New Member
    Los Angeles
    2024 Prius Prime
    Gokhan,
    Thanks for the useful information. Appreciate it!
    Gokhan likes this.
  10. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    You probably have a bad 12V battery. That would be confirmed if after doing all the suggestions, it happens again. Just so you're prepared, your dealer will probably say the battery checks out fine. They may even try to convince you that it's all on you, either something you're doing or something you're not. Testing the voltage output right after bringing it to full charge is not an adequate test. Another member had a frustrating experience when the dealer told them several times the battery was good. The problem was the battery would not hold a charge after sitting for while like a couple days or even overnight.
    Hopefully, it doesn't happen again. But if it does, I would insist on a new replacement battery.
  11. Mendel Leisk
    41,711
    I’ve read that a car fully “on” but just sitting idling may still tax the 12 volt battery more than charging. Pretty sure this was for non-hybrid vehicles, though.
    If disconnection of hybrid battery charge cable is not practical, having a smart charger hooked up to the 12 volt might prevent it draining.
    No kidding.
  12. PriusCamper
    12,903
    5,234
    I understand this is a problem for older Prius and needs to be addressed this way... But in 2024 they still can't send enough charge to the 12v? Total nonsense!
  13. Gokhan
    6,375
    2,545
    Paramount CA
    I am not sure what you mean by fully on, as that is not a technical term for Gen 4/Gen 5 Prius/Prius Prime. I believe there are four modes: off, acc, on, and ready. In the READY mode, the 12-V battery is always charged to near 100% SOC, as the DC converter is on, regardless of the drive mode (HV/EV) or if the vehicle is parked or driven or if the ICE is running or not.
    Mendel Leisk and GcinFl like this.
  14. rhodes2020
    rhodes2020 Junior Member
    United States PST Southern California
    it is March 2025. My Prius Prime purchased in March 2024 just now went dead battery on me. Toyota roadside care is coming to pick up and take to dealer. It would be good if more of us reported back the resolutions. If the dealer is only going to charge my battery and send me home, it is a waste of time. I am super curious what READY mode is? I tap buttons in my prime, I see HV, EV, Sport, ECO, but have never seen something like READY. And there are a hundred menus still to go! How does a person put the prius prime in ready mode? should I leave it in ready mode all the time? BTW my driving habit is all electric grocery getting most of the time, occasional road trips .
  15. Gokhan
    6,375
    2,545
    Paramount CA
    The ready mode refers to the driving mode of the start–stop button, as opposed to the accessory mode or off mode. You will see a green READY on the display.
    As for information on the 12-V battery, see the many battery threads posted in this forum.
  16. Hammersmith
    Hammersmith Senior Member
    2,315
    2,355
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I'm just going to put this out there as a strategy. It worked for me, but others might not want to do it.
    First, get yourself a little battery jump starter and learn how to use it. They're good to have anyway as a safety device. If and when your 12V fails for the first time, don't bother taking it to the dealer or getting a tow, just use the jump starter. At this point, the battery has probably sustained some damage, but not enough for a dealership test to show it as damaged enough to trigger a replacement under warranty.
    Now maybe you can go out and get a battery maintainer to keep it going like Gokhan says, or you can also just let nature take its course. Let the battery go dead a few more times on its own. Don't do things to force it to go dead, but don't try to limp it along forever either. Since you've got the jump pack, it'll only be a mild inconvenience to pop the hood and get your car going again.
    Once the battery gets to the point that the car can't sit for more than a day or three before it goes dead, THEN go to the dealership. By this point, the battery will be damaged enough to easily fail the load test, and you'll get a brand new battery under warranty. Saves you time and saves the dealership time by avoiding unnecessary towing and testing that doesn't result in a replacement. At this point, you could consider using a maintainer. Now you'd be maintaining a perfectly good battery, not a somewhat damaged one.
    Gokhan and BiomedO1 like this.
  17. Gokhan
    6,375
    2,545
    Paramount CA
    The Uplus 140R/H4/LN1 AGM battery is very cheap on Amazon in case you don’t want to deal with the dealer, and it is an upgrade over both the OEM GS Yuasa and Toyota TrueStart flooded-cell batteries.
  18. BiomedO1
    3,895
    2,042
    SacTown, Ca
    +1^ @rhodes2020; in addition to the above; do you unplug the car when it's fully charged? The Operations Manual states to unplug the car when the traction pack is fully charged. Leaving it plugged-in will drain the 12V battery. The 12V battery runs the car's internal diagnostics and runs more frequent diagnostics while plugged-in.
    Hope this helps...
  19. Trollbait
    12,609
    You put it Ready mode to drive the car.
  20. thetoys
    thetoys Member
    28
    Toronto, ON
    2024 Prius Prime
    XSE Premium
    Sort of off topic Question.
    Just out of curiosity, has anyone with a Prime (PHEV) with a Solar Panel roof gotten a dead 12v battery?
